Need help - Mustang Evolution
Old 02-13-2012, 04:52 PM   #1
Blackconv98's Avatar
Need help
Have been working on my 04 f150 5.4 it has had a miss replaced coils plugs etc. now it seems to have a loss of power, unhooked one hole bank never set off an engine light. Disconnected tps again no engine light. Miss is gone but lose of power. My only guess is the computer needs reflashed. Help!
Blackconv98 is offline   Reply With Quote
Old 02-13-2012, 05:01 PM   #2
2002VertGT's Avatar
Go to f150forum.com....i too have a 04 f150. How many miles? Have the spark plugs been changed?
4.10 Gear/RPM thread
Old 02-13-2012, 05:03 PM   #3
Been changed twice, 89,000
Old 02-13-2012, 05:09 PM   #4
Re: Need help
Damn, those engines can be tricky.
I wonder if the plug gap is set correctly...should be .052-.056".
Old 02-13-2012, 05:12 PM   #5
You cannot gap 3valve 5.4 engines
Old 02-13-2012, 05:14 PM   #6
2002VertGT's Avatar
I would go check codes anyway...your light could have blown..
Old 02-13-2012, 05:15 PM   #7
No codes, I do not have a clue. You can disconnect any thing and it will not set a code off
Old 02-13-2012, 05:36 PM   #8
Re: Need help
Oh that's right, the 5.4 and 6.8 3v's can't be adjusted, my bad.
I would try the F150 forum...someone over there might have had the same issue and can help out more.
Ford F150 Forum - Community of Ford Truck Fans - Powered by vBulletin
Old 02-13-2012, 05:39 PM   #9
Thanks guys ,on the f150 forum now, but if anyone has any idea don't hesitate thanks
Old 02-13-2012, 05:39 PM   #10
2002VertGT's Avatar
They have a iPhone and android app as well...I'm over there....same name
Old 02-13-2012, 05:42 PM   #11
Installed, thanks same name there as well
---------- Post added at 06:42 PM ---------- Previous post was at 06:41 PM ----------
Sorry it's blackstang98 over there
Old 02-13-2012, 05:43 PM   #12
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
How's your intake gaskets? Had a buddy with a 03 5.4 f250 that had the miss and ran doggy. He ended up replacing the intake gaskets(it def helped), injector o rings, then plugs, and coil packs that finally fixed it.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 02-13-2012, 05:45 PM   #13
Gaskets are new, deleted butterfly's in the intake kept getting stuck
Old 02-13-2012, 05:51 PM   #14
Pete Jones
Ever changed the fuel filter?
90 LX hatchback
89 LX Notchback
Old 02-13-2012, 05:54 PM   #15
Yes, 3000 miles ago. I love fords, have owned nothing but. I'm ready to see this one go. Have owned since new , ford replaced motor once. Think I'll stick to my stang and my 96 f250
Old 02-13-2012, 05:55 PM   #16
Here is my reliable truck
Old 02-13-2012, 05:58 PM   #17
2002VertGT's Avatar
My two vehicles...mines great!!
Old 02-13-2012, 05:59 PM   #18
Re: Need help
Yah those 5.4's in the 04/05 F150's had a ton of problems - cam phasers, bearings, injectors, 1 piece spark plugs, the list goes on...supposedly they solved most of them by 07, which is what I have but we'll see..I've only got 36k on her so it's too early to say. I do have the infamous tick but that's normal with that engine. I'm not spending a dime to get rid of it either lol.
Old 02-13-2012, 06:04 PM   #19
Wish you both all the luck in the world, it's my fault for buying first model year. They didn't fix the plug issue till 08. So don't wait 100000 miles before changing. Only good for about 30 to 36000
Old 02-13-2012, 06:11 PM   #20
Re: Need help
Thanks, I honestly don't plan on keeping it much past 50k but I'll probably do the plug change shortly before the 5yr 60k warranty is up in august.
Old 02-13-2012, 06:13 PM   #21
My first motor was replaced by ford at36000 due to bad bore tolorences
Old 02-13-2012, 06:17 PM   #22
Re: Need help
Wow, yah an engineer at my work had his 05 hydrolock on him at ~32k..replacement engine from Ford, he's got 88k now and hasn't had any problems but damn, should not be replacing engines at 36k miles
Old 02-13-2012, 06:21 PM   #23
Just have more faith in 97 f250 and my 98 conv
Old 02-13-2012, 06:30 PM   #24
Re: Need help
That 97 have the 7.3 Powerstroke?
Old 02-13-2012, 06:33 PM   #25
351w 5 speed
Old 02-13-2012, 06:38 PM   #26
Re: Need help
Ah just as good, coolness.
Old 02-13-2012, 06:48 PM   #27
Easy to fix, but haven't had any trouble
---------- Post added at 07:48 PM ---------- Previous post was at 07:39 PM ----------
Your 03s lookin good
Old 02-13-2012, 06:56 PM   #28
Re: Need help
Thanks, mostly cosmetic work but it's my baby. Finally did my drop last season after owning the damn car for 6 years lol. Next is a tuner and maybe some cam work...then it's v8 time
Old 02-13-2012, 07:02 PM   #29
I bought mine as a bank repo for 500 ! Put a new top wheels 315 rear tires hood , off road pipe, fuel pump. No one thought it would run. Fuel pump was the trick. I have a 85 t top and a 90 conv also . Both are in pieces at the moment, but getting close to complete
---------- Post added at 08:02 PM ---------- Previous post was at 08:01 PM ----------
Lowered it also , but then raised the back. Had bottoming out issues
Old 02-13-2012, 07:07 PM   #30
Re: Need help
Wow, nice..love how something simple is all it takes, for ~1k you got a nice looking GT...I'm hoping to get a Deep Impact Blue (new sonic blue) GT in 2013 or 2014, and then an old fox or 67-68 to restore...that's the plan anyways.
The 03 won't be going anywhere...that biatch is staying right here
Old 02-13-2012, 07:14 PM   #31
Just sold my 68 coupe , to many projects.the 85 is for my son when hes of age
---------- Post added at 08:14 PM ---------- Previous post was at 08:11 PM ----------
My dream car is a 67/68 cougar
Old 02-13-2012, 07:18 PM   #32
Re: Need help
That'll be a nice first car...my local ford dealership gave away a 68 cougar a few years ago for some promo...I came close, was in the top 10 and won a damn autographed football instead, dammit.
The car was a mess though, even had a hole in the passenger's floor pan, but I still would've taken it.
Old 02-13-2012, 07:22 PM   #33
I found one for 2000 but the guy out of his mind it's complete , but there is fiberglass holding the strut towers and frame together and you can flintstone it
Old 02-13-2012, 07:24 PM   #34
Re: Need help
Hmm, sounds like a full body resto..2k definitely sounds steep...engine?
Old 02-13-2012, 07:29 PM   #35
Most of the motor was there. The only thing that didn't need fixed was the cowl and its always the first to rust
---------- Post added at 08:29 PM ---------- Previous post was at 08:27 PM ----------
My dads daily commuter was a 68 growing up so you can see the attachment
03:59 AM
