Transmission swap. - Mustang Evolution
Old 02-18-2012, 01:22 PM   #1
03fastblack's Avatar
Transmission swap.
How much do you guys think it's cost to switch a 2003 mustang gt from an automatic to a 5 speed?
03fastblack is offline   Reply With Quote
Old 02-18-2012, 02:35 PM   #2
2002VertGT's Avatar
Depends on how mechanical you are...
4.10 Gear/RPM thread
Old 02-18-2012, 03:09 PM   #3
1lowGT's Avatar
Well I'm his cousin with the faster cal lol but he said he knows people idk
Old 02-18-2012, 03:42 PM   #4
Jamesgt08's Avatar
I went from auto to 5 speed I spent a total of about 950 for everything and I did all labor myself. It was easy to do.
Jamesgt08 is offline   Reply With Quote
Old 02-18-2012, 03:49 PM   #5
1lowGT's Avatar
Do you have a lot of experience though
Old 02-18-2012, 03:53 PM   #6
Jamesgt08's Avatar
Yes I do. I can take a comple car apart and put every piece back together myself. If u check out the threads I started I think I have a few pics and I explained how I did it.
Old 02-20-2012, 07:08 AM   #7
jjsg09's Avatar
How hard would it be for me to go to auto then, I might be interested in a swap. My wife can't drive a 5-spd if her life depended on it.
Old 02-20-2012, 08:01 AM   #8
MustangGT02's Avatar
Re: Transmission swap.
were do you live, im dying for a manual!
MustangGT02 is offline   Reply With Quote
Old 02-20-2012, 08:50 AM   #9
Jamesgt08's Avatar
It's the same amount of work goin from auto to 5 SPd or 5 Spd to auto. The hardest part of the swap is switching out the pedal assembly.
Old 02-20-2012, 09:01 AM   #10
jjsg09's Avatar
Indianapolis, the only reason I havnt done this is my car is a daily driver.
Old 02-20-2012, 01:17 PM   #11
Mzilla's Avatar
Keep the auto do a custom valve body and a 3200 stall converter. Oh and don't forget the 4:10 rear gears. Ha that's the set up I have with my 4R75W trans. I have several different trans tunes with my SCT 4 position tune switch.
Mzilla is offline   Reply With Quote
Old 02-20-2012, 03:20 PM   #12
Hansen01's Avatar
I need a 4.6L 5 speed Trans.
Hansen01 is offline   Reply With Quote
Old 02-20-2012, 03:23 PM   #13
2002VertGT's Avatar
Tremec 3650 is the 5speed tranny
Old 02-20-2012, 03:27 PM   #14
Hansen01's Avatar
I'm pretty sure you right... I blew something on the driveshaft. Do you think it's cheaper to rebuild or replace
Old 02-20-2012, 04:06 PM   #15
2002VertGT's Avatar
Depends on what u blew
---------- Post added at 06:06 PM ---------- Previous post was at 06:05 PM ----------
If u are eventually gonna build your car for power, replace it and rebuild your current one slowly to be better than it was
Old 02-20-2012, 07:26 PM   #16
Jamesgt08's Avatar
T-45 is also a 5 Spd tranny.
---------- Post added at 09:26 PM ---------- Previous post was at 09:24 PM ----------
If you can find a good used 5 spd for cheap I would replace it and like the other guy said just rebuild your current one so you can have a spare. There easy to rebuild.
Old 02-20-2012, 07:45 PM   #17
2002VertGT's Avatar
Yes the t45 is a 5 speed for the older sn95 (94-98) I'm sure there are some mounting differences...and I would assume that the 3650 is a step up from the t45 or ford f'ed up..
Old 02-20-2012, 08:26 PM   #18
Jamesgt08's Avatar
I have a t45 in my 2000 gt. There is no mounting differences at all. The 4.6 is all the same in all these years.Heck if you really want to you could put a t45 on a 03 cobra lol. I think they started using the 3650 in the 2001 gt.
Old 02-21-2012, 07:22 PM   #19
Hansen01's Avatar
[QUOTE="2002VertGT"]
I blew the output shaft
Does everyone like there mt82 transmission GE3G 2011-2014 Mustang GT 66 03-29-2016 09:13 AM
Tremec TR-3650 Transmission Gear Ratios DarkHorse 1996-2004 Mustang GT 33 06-27-2013 02:13 PM
Transmission noisy! MustangCaracas 2005-2010 Mustang GT 26 02-17-2012 10:54 AM
Clicking near transmission MTilly 2005-2010 V6 Mustang 4 02-07-2012 03:29 PM
Ford racing manual transmission cooler air scoop gt 2011-2012 avengnd 2011-2014 Mustang GT 3 02-03-2012 09:30 PM
01:33 AM
