Cyl #2 miss fire - Mustang Evolution
Old 02-18-2012, 02:55 PM   #1
99redgt's Avatar
Cyl #2 miss fire
Hey can anybody help me with trouble shooting ?
99redgt is offline   Reply With Quote
Old 02-18-2012, 03:15 PM   #2
Cajunick's Avatar
Swap coils with a different cylinder. If the misfire moves to cylinder you switched coils with then replace that coil if not then replace cylinder 2 spark plug.
Cajunick is offline   Reply With Quote
Old 02-18-2012, 03:55 PM   #3
99redgt's Avatar
Okay thanks, I got my oil changed at this mr lube and they put to much oil in and the wrong filter I have a bad feeling this might be why I'm have issues I usually change my own oil it's just hard in the winter when there's a foot of snow lol
---------- Post added at 05:55 PM ---------- Previous post was at 05:54 PM ----------
Can there be lots of damage done if there is to much oil?
Old 02-18-2012, 07:30 PM   #4
Cajunick's Avatar
It's possible a misfire could be a long list of possible problems. What I told you to do is the simplest and most common things you see when you get a misfire fault. If that doesn't fix it I would take it to a ford dealership and get everything on paper and make sure they list the problem is fault due to oil over fill and take it back to the lube place and have them pay for your repairs.
Old 02-19-2012, 07:07 AM   #5
99redgt's Avatar
Alright thanks I'll try the coil thing
Old 02-19-2012, 07:20 AM   #6
jwhayne0001's Avatar
Swap number 2 and number 6 both are 2nd cylinders back #2 is on passenger side all fords have 1234 on passenger and 5678 on driver even for 6 cylinders I'd almost promise its the coil I replace atleast 15 a month at the ford dealer I work at
---------- Post added at 08:20 AM ---------- Previous post was at 08:19 AM ----------
Also helps if you have a scan tool with a power balance to note the miss or atleast a scanner with mode 6 so you dont have to clear the light and wait it to reset
jwhayne0001 is offline   Reply With Quote
Old 02-19-2012, 07:26 AM   #7
99redgt's Avatar
Okay I'll give it a shot do u have any recommendation on what after market coils I should put on it if I do need to replace it ? 99 gt
---------- Post added at 09:26 AM ---------- Previous post was at 09:26 AM ----------
I'll probably order from AM if it needs replacing
Old 02-19-2012, 07:29 AM   #8
The yellow accell ones from AM seem to be the rage ive never messed with after markets much jut OEM fords
---------- Post added at 08:29 AM ---------- Previous post was at 08:28 AM ----------
Thing with aftermarkets like the accells is you'll have to match all 8 for it to run right but Oreillys should have some quality ones
Old 02-19-2012, 10:08 AM   #9
99redgt's Avatar
I have so much water under the coil? And the springs inside the coil look rusted...
---------- Post added at 12:08 PM ---------- Previous post was at 12:07 PM ----------
I rolled a paper towel and put it in there to absorb some water but now it says coil f isn't working on my reader..
Old 02-19-2012, 10:21 AM   #10
99redgt's Avatar
Let me know if you have any suggestions on how to keep the water out
ID:	41141   Click image for larger version
Old 02-19-2012, 10:53 AM   #11
Blow it out with a blow gun (the plug hole) go to Autozone and get a new boot they are available seperate
---------- Post added at 11:50 AM ---------- Previous post was at 11:48 AM ----------
Oh and don't hose the engine off with water! Number one thing customers do when their is water I ask and everyone of them says they sprayed it off with water get a steam cleaners much safer
---------- Post added at 11:53 AM ---------- Previous post was at 11:50 AM ----------
Also just saw your rusted spring sometimes the boot comes with a spring it just pulls off, note the arrow on the coil and flat spot on the boot as they must line up
Old 02-19-2012, 11:06 AM   #12
jhagan1980's Avatar
Is it possible to put some dielectric grease on it?
jhagan1980 is offline   Reply With Quote
Old 02-19-2012, 11:11 AM   #13
99redgt's Avatar
Still no luck says coil f fail..
Old 02-19-2012, 12:14 PM   #14
Not sure it would hold up to heat probly turn liquid
---------- Post added at 01:14 PM ---------- Previous post was at 01:13 PM ----------
It says coil F?
Old 02-19-2012, 01:30 PM   #15
99redgt's Avatar
Yeah
Old 02-19-2012, 01:47 PM   #16
That's a cool driver code, is it plugged in? Possible wire damage such as mice chewing it or corrosion or worst case bad PCM, also RF interference between radio PCM and other electronics causing it
---------- Post added at 02:47 PM ---------- Previous post was at 02:46 PM ----------
Coil not cool I hate this friggin phone
Old 02-19-2012, 02:32 PM   #17
99redgt's Avatar
What about drilling small holes to let the water out sounds like a crazy idea? But every time it rains, snows or I wash my car this is going to happen
---------- Post added at 04:28 PM ---------- Previous post was at 04:27 PM ----------
No it wasn't plugged in and I havnt done anything to the electrical lately
---------- Post added at 04:32 PM ---------- Previous post was at 04:28 PM ----------
So it looks like I'll just have to replace the coils to solve the problem im just worried that this problem is going to keep happening...
Old 02-19-2012, 03:24 PM   #18
Drilling holes will only permit more water.
The coil was NOT plugged in? This is why your getting a code for it then.
I'd start with replacing just the one coil before you blow 700 plus bucks
Apple red on fire red? ReggStang 2005-2010 Mustang GT 3 01-30-2012 08:23 PM
Cyl 8 Reinkey 2011-2014 Mustang GT 8 01-16-2012 10:39 AM
miss in rain? johnmcillwain 1996-2004 Mustang GT 7 01-02-2012 10:19 PM
Miss my Stang ! RVAStang05 General Mustang Discussion 1 12-23-2011 05:37 PM
09:02 PM
