O2 sensor help? - Mustang Evolution
Old 02-18-2012, 10:13 PM   #1
redfox48's Avatar
O2 sensor help?
I have a 97 gt. 2 fault codes p0136, both say same thing circuit bank 1 sensor 2. would these be the downstream ones? Any help very appreciated!!!!
redfox48 is offline   Reply With Quote
Old 02-18-2012, 10:37 PM   #2
Cobrarunnin9s's Avatar
Re: O2 sensor help?
Yes it's the downstream sensor on the passenger side pipe
Cobrarunnin9s is offline   Reply With Quote
Old 02-19-2012, 01:01 AM   #3
KillaGT's Avatar
Region: New Hampshire
Re: O2 sensor help?
with my race tune I put in I turned off the O2 sensors & passes inspection no problem! Just a idea if its a inspection concern
KillaGT is offline   Reply With Quote
Old 02-19-2012, 08:35 AM   #4
redfox48's Avatar
Re: O2 sensor help?
ok thanks guys. its not an inspection problem, I just get tired of the ugly check engine light!!!!!!! I think i will just get those MIL eliminators and put them on there, because I keep having this problem. I replaced all 4 about 4 months ago and keep having the same fault codes
Old 02-19-2012, 08:46 AM   #5
jwhayne0001's Avatar
If all 4 were replaced and you still getting the code either a wire is cut somewhere or shorted out or you have a blown fuse for the O2's
jwhayne0001 is offline   Reply With Quote
Old 02-19-2012, 08:56 AM   #6
redfox48's Avatar
Re: O2 sensor help?
Ok. I will check both of those and see what i find. hopefully it is just a blown fuse. I did see the connector for that sensor did look a little ruff. Actually part of the connector is broken off so it doesnt lock together. It was like that when i bought it. The guy used a zip tie to hold it together. I guess zip ties fix everything temporarily.
HELP!!!!! jacob.a.gasparp 1979-1995 Mustang GT 41 04-29-2012 08:07 PM
Wheel spacers help! jamin22786 2005-2010 V6 Mustang 9 02-26-2012 07:32 PM
Dynomat help with drone? Jmoss 2011-2014 Mustang GT 5 02-18-2012 01:52 PM
exhaust help!? reeg2010 2011-2014 Mustang GT 28 02-18-2012 03:36 AM
Wheel decision, help me out! Brock23 2011-2014 Mustang GT 26 02-17-2012 02:09 AM
07:29 AM
