loud drive train - Mustang Evolution
Old 02-19-2012, 02:52 PM   #1
loud drive train
I have an 04 mach1 5 speed with 28k miles. I've noticed an increasing drive train noise after 45 mph. its a loud whine increasing to a roar. also once the drive train is warm when idling in neutral I can hear what sounds like pieces rattling around in the transmission until I push the shifter against a gear to engage the synchro. Any ideas would be helpful.
rix71gt is offline   Reply With Quote
Old 02-19-2012, 03:09 PM   #2
Black99Snake's Avatar
Maybe your pilot bearing, or throwout bearing. Other than the noises does it seem to shift fine? If you can get the car jacked up high enough or maybe on a lift and have the rear wheels off the ground have someone in the car running and press the clutch in while u look at the throwout bearing. U can see it if u take off the shift fork cover on the driverside of the tranny. Shine a flashlight up there and see if the throwout bearing is sliding properly or if its wobbling or just thrashing back and forth. The throwout should only move with the shift fork.
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 02-19-2012, 03:51 PM   #3
The clutch effort seems to vary, sometimes its heavy sometimes less. Also shifting can be hard sometimes.
---------- Post added at 05:51 PM ---------- Previous post was at 05:16 PM ----------
Also, just drive the car, and the noise its only prominent when accelerating or maintaining speed. Anytime you lift off the throttle the sound vanishes.
loud pipes 03gt5.4l 1996-2004 Mustang GT 16 02-23-2012 09:32 AM
What could be causing a loud popping under my dash and behind the stereo? bluestorm52 2005-2010 Mustang GT 2 02-19-2012 05:41 PM
Under Drive Pulleys Aggiesrok 2005-2010 Mustang GT 18 01-27-2012 09:50 PM
To drive or not to drive 2011 Kona Blue 2011-2014 V6 Mustang 41 01-26-2012 09:53 PM
11:33 AM
