Quick question about RPM's - Mustang Evolution
Old 02-20-2012, 09:32 PM   #1
Mustang_Madness's Avatar
When i turn my car on from a cold start, the rpms will stay at 1500. Then maybe 30 seconds of idleing, it will drop to maybe 800. Then when i just Barely tap the gas, it goes up to 1500 or sometimes 2000 and then drop slowly... Then wait a few and back to 800. Anyone tell me why that is??
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-20-2012, 09:57 PM   #2
BigB227's Avatar
My car has been doing that lately also, what it is exactly idk, maybe someone else can chime in.
It might be the Idle air control valve but I could be wrong
BigB227 is offline   Reply With Quote
Old 02-20-2012, 09:59 PM   #3
I could have tweaked something when i took off my TB to clean it.. I dont think so though!
Old 02-21-2012, 02:54 PM   #4
murraydylan1993's Avatar
It usually does that for me everytime. Its usually just the engine gettin started.
1/4 mile at a time.
murraydylan1993 is offline   Reply With Quote
Old 02-21-2012, 02:58 PM   #5
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
+1
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 02-21-2012, 03:11 PM   #6
Originally Posted by Greeny27
+1
Except for that itll do this even when the engines been runnin for a while. Like at a stop light ill barely tap the gas and itll bump up to 1500 rpm..
Old 02-21-2012, 07:05 PM   #7
2Greeny7's Avatar
Its how the cars tuned, when o got mine retuned it jumped to 2k and went down and sat at 800rpm. Its really no big issue, so my .02 says your fine!
2001 V6
Old 02-21-2012, 07:24 PM   #8
K sounds good man
Old 02-22-2012, 06:26 PM   #9
I have 373 gears so all i do it lay my foot on the pedal and i have to shift. It doesnt take much for me to rev to 1500 rpms its just a power thing. Its not bad and if you had an exhaust it sounds bada**
1/4 mile at a time.
Old 02-22-2012, 06:42 PM   #10
Not sure if i have exhaust or not.. I have a V8 with dual pipes out the back. But i also dont know what kind of gears i have..
Old 02-22-2012, 06:46 PM   #11
Well does it have a low roar when ur at about1800 rpms? Stock mustangs are silent but exhaust is common. Is it an auto or manual?
1/4 mile at a time.
Old 02-22-2012, 07:26 PM   #12
Mile high JDF's Avatar
To check the gears, jack up the rear end and mark the driveshaft. Then rotate the tire 1 full rotation while counting how many times around the driveshaft spins. To check the exhaust just look for any sort of name on the muffler. If its aftermarket the. It should say something on it.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-22-2012, 07:54 PM   #13
LAS97GT's Avatar
Re: Quick question about RPM's
Sounds like the Stang is tuned but Dashpot is not set. i have the same problem but i know that I have to calibrate the idle. Dont have the time yet though. Lets say you set the idle and the car stalls, means its set too low. 850 is about right. Idea is when foot is off gas, clutch is depressed car rpms drop quickly to idle unless you shift quickly and so on. difficult matter. still chewing on it since i tuned.
---Las97GT
Old 02-22-2012, 09:06 PM   #14
Its a manual. Its also a 96 body with a 98 V8 in it. it would Have to have aftermarket exhaust I'm guessing then.. maybe? I will check the gears and everything tomorrow or friday as thursday is the beginning of my weekend.
Old 02-22-2012, 09:52 PM   #15
CodyNelson's Avatar
Region: West Virgina
No 96-98 were the same body style and motor. Exhaust and everything else will bolt and hook right up
Old 02-22-2012, 10:16 PM   #16
True however the 96 came stock with a v6 so there would Have to be some aftermarket mods wouldn't there? at Least the exhaust
Old 02-22-2012, 10:26 PM   #17
You would have to redo all the suspension to handle the power. And a bigger radiator alternator and beef up everything or else you wpuld tear the s*** out of a stock v6 set up
1/4 mile at a time.
Old 02-22-2012, 10:31 PM   #18
Yea the suspension is BBK but i just don't know about the exhaust. ill take a look tomorrow to see if its marked. i Really want dual side exit exhaust so it'll get swapped out eventually. whenever i can find a kit for it. lol
Old 02-22-2012, 10:33 PM   #19
Haha you should just have a shop make you one. If you find a small one they do it for cheap
1/4 mile at a time.
Old 02-22-2012, 10:37 PM   #20
a small one? exhaust? see thats another thing. is that Im gonna put in another cam because i love the sound, and i want a BADASS exhaust to go with it. but of course legal. but at the Edge of legal ya know?
Old 02-22-2012, 10:44 PM   #21
I cut off my mufflers so mines not legal but ive never gotten pulled over for it. Unless you as loud as a open heads dragster or harley they wont care bcuz theyre not gonna get on their knees and look and most of them dont even know what a muffler is
1/4 mile at a time.
Old 02-22-2012, 10:48 PM   #22
Ohh alright alright. So i should have a shop just bend the exhaust for me? What sounds beastly? I was thinkin o/r x pipes but out the sides but idk if thatll work. Or if side exit exhaust is its own thing
Old 02-22-2012, 10:50 PM   #23
You can buy side exit kits off the Internet, I'm pretty sure they just bolt on after the mid-pipe. A shop could do it pretty easy I think.
Old 02-22-2012, 10:50 PM   #24
I dont know about side exit. Google it and find out some stuff
1/4 mile at a time.
Old 02-22-2012, 10:52 PM   #25
I would probably do it,. But alright thanks!
Old 02-22-2012, 10:57 PM   #26
Its usually just a weld on just make sure it wont melt anything
1/4 mile at a time.
Old 02-22-2012, 11:00 PM   #27
I guess I should have specified. A shop could make one for you.
Old 02-23-2012, 02:52 AM   #28
Region: North Dakota
My car also has the idle problem. I'm not sure if it has stock internals or not, but the exhaust has definately been modified. It's loud. I also run rich most of the time, so that may have something to do with it, and I won't know further until I get an SCT tuner. Some tricks to help it may be to increase air flow with a cold air kit (if you do feel you're running rich), help the ignition with good plugs and upgraded coils, or get a tuner to help it settle down. I know a lot of people think that if your car came with a V6 and was upgraded to a V8 that you have all sorts of work to do.. and sometimes this may be true, however, when it comes to mustangs I've found that typically ford will share suspension set ups, and even tranny's between the V6's and V8's so as to keep production costs, and repair costs down. The only real difference between the two (besides engine size and weight) should be just the ECM, and wiring harness. Don't quote me, but that's pretty typcial. Hope this helps.
K Twisted is offline   Reply With Quote
Old 02-23-2012, 05:06 AM   #29
I know im running rich and today im getting my fuel pressure regulator so i can swap it out. Im runnin about 60 psi at an idle and 70 full throttle when it should be 30 and 40. Andi got new spark plugs for when i do this swap but no coils. Ill pick those up today. Thanks for the info!
Old 02-23-2012, 05:55 PM   #30
Hey no prob!! Lemme know how it works out!! I still run a little rich, but i've noticed a huge improvement since before I put all that in. Good luck and keep me updated!!
Say Something About The Person Above primer2tone The Bar 20516 03-02-2018 08:24 PM
GEAR HEADS HELP! Rapid exhaust popping @ WOT high rpm Brad.krieg SVT Mustang 1 02-22-2012 02:06 PM
Tire Question Msoler 2011-2014 Mustang GT 18 02-21-2012 09:59 PM
I gota question Blackedout Pre-2005 V6 Mustang 32 02-20-2012 08:47 AM
Quick Alternator Question 89Saleen141 1979-1995 Mustang GT 7 02-19-2012 09:31 PM
09:42 PM
