short shifter? - Mustang Evolution
Old 02-21-2012, 04:43 PM   #1
short shifter?
I was thinking about putting a short shifter In next but don't know much about them. what would you guys suggest as the best one
04vertgt is offline   Reply With Quote
Old 02-21-2012, 05:36 PM   #2
clark98gt's Avatar
Re: short shifter?
I really liked the Pro 5.0 I had in my fox body and I will probably go with that same one in my sn95 once I buy a new trans. Just make sure whatever one you go with has the shifter stops or you will end up like me, I broke the 3-4 shift fork, powershifting at the track.
1998 Gt- current progress
Engine back in car some reassembly required
clark98gt is offline   Reply With Quote
Old 02-21-2012, 05:53 PM   #3
Are those so you don't over shift pretty much?
Old 02-21-2012, 06:10 PM   #4
clark98gt's Avatar
Re: short shifter?
yeah there is stops, which pretty much are bolts, that you have to set to keep from shoving the shifter too far forward or pulling it too far back.
Old 02-21-2012, 06:12 PM   #5
Cobrarunnin9s's Avatar
Re: short shifter?
MGW makes an awesome shifter as well, I've never missed a shift yet and you can bang them as hard you want without issue. Plus there probably the best looking shifter on the market and definitely the most adjustable.
Cobrarunnin9s is offline   Reply With Quote
Old 02-21-2012, 06:17 PM   #6
clark98gt's Avatar
Re: short shifter?
I have heard good things about them also. Does the Mgw guide? the shifter into 3rd?
Old 02-21-2012, 06:23 PM   #7
Mustang_Madness's Avatar
HEY!! my names clark to. And i have a 98 V8 in my 96' lol
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-21-2012, 06:31 PM   #8
Are the installs pretty much the same? What Should.i look out for when I install it
Old 02-21-2012, 06:40 PM   #9
LAS97GT's Avatar
Re: short shifter?
Hi folks,
I have a Boss 5.0 (1990s) shifter on my T 45. There are four bolts, we'll call them north, south, east, west for directions. The method is simple, the bolts are what make the short throw effective. First, engage 3rd gear, release the shifter, adjust the north bolt to within a milimeter, select fourth gear, release the shifter, and adjust the south bolt to within a milimeter. Ok, now for the other two. Engage fifth, the shifter should not touch the east bolt, if it does adjust clearance to allow the shifter to pass. Now do the same with the west by selecting second. Ok, that just about gets the basics down. Now start the engine, engage all 5 gears, release the clutch (slowly but not all the way) just enough to put strain on the motor to,verify engagement of the clutch. Fine tune from there. Its easy.
Beauty about mine is that I can hear the metal to metal contact when I check neutral. Note that certain trannys dont allow for fast shifting, sometimes you just have to know your tranny and go with it. There are ways to compensate. My T45 forces me to delay about a second or more between shifts (seems more like 2), but it transfers the torque I need from the engine to the rear wheels.
---Las97GT
Old 02-21-2012, 06:40 PM   #10
clark98gt's Avatar
Re: short shifter?
Clark is actually my last name, lol. Nathan is my first.
Old 02-21-2012, 06:42 PM   #11
Re: short shifter?
Ya it has two stops, front and back
Old 02-21-2012, 06:44 PM   #12
Thank you that helps a bunch im guessing it would make much more sense adjusting it with it actually in front of me
Old 02-21-2012, 07:59 PM   #13
Damn... Ive only hear of 2 other people with it as their first name
Old 02-21-2012, 08:39 PM   #14
2002VertGT's Avatar
Mgw is a great shifter! And as for the OP, you have a 3650 tranny which has INTERNAL stops. You do not need shifter stops on your car. Shifter stops can damage your tranny. Get the MGW and read the book. Install is simple. Should take a novice mechanic no more than hour and half-two hours to install. Guides shifts into third from second beautifully. I absolutely love mine!
ID:	41422   Click image for larger version
4.10 Gear/RPM thread
Old 02-21-2012, 10:48 PM   #15
Mile high JDF's Avatar
I have a pro 5.0. It's nice but not as good as a Steeda Tri-ax in my opinion. MGW definitely has the smoothest shift but I haven't gotten to test drive a car with one yet. If you had the money then I would do the MGW.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-22-2012, 04:20 AM   #16
2002VertGT's Avatar
X10000
Old 02-22-2012, 10:21 AM   #17
Re: short shifter?
MGW, Steeda, Pro 5.0 those seem to be the top 3. I personally recommend MGW as you can see its built very nice and the 360 rotation handle works great for adjustments and reach in 94-04 cars.
Old 02-22-2012, 10:37 AM   #18
Jsansom's Avatar
I have a 04 gt and when I bought it it came with a mgw shifter in it and i love it. I've nvr had any problems with mine.
Jsansom is offline   Reply With Quote
Old 02-22-2012, 10:48 AM   #19
CodyNelson's Avatar
Region: West Virgina
Re: short shifter?
another vote for MGW here. I LOVE mine!
Old 02-22-2012, 01:49 PM   #20
Bryangb7's Avatar
Where can u buy it and how much is it?
Bryangb7 is offline   Reply With Quote
Old 02-22-2012, 02:02 PM   #21
2002VertGT's Avatar
It's a little pricey, I bought mine used for $110!!! A steal!!!!
http://www.mgwltd.com/mustang_shifter.shtml
Old 02-22-2012, 02:56 PM   #22
blackhawk 1's Avatar
Re: short shifter?
short shifters are great
blackhawk 1 is offline   Reply With Quote
Old 02-23-2012, 11:57 AM   #23
GTdevildriver's Avatar
Region: Arkansas
Re: short shifter?
Just ordered mine last week. Can't wait to get it in.
I Could ****ing Care Less.
GTdevildriver is offline   Reply With Quote
I have a New Short throw Shifter and new jlt cai saxxx 2005-2010 V6 Mustang 15 02-20-2014 09:25 AM
Throttle body and short throw shifter Mayhem48 General Mustang Discussion 14 01-28-2014 09:22 AM
TCI Ratchet Shifter? JR_GT500 2005-2010 V6 Mustang 4 02-17-2012 06:10 PM
04 gt shifter still sticking... some advice? imhooked 1996-2004 Mustang GT 18 02-11-2012 09:15 PM
Ebay short shifter throw choppa5307 1979-1995 Mustang GT 4 02-09-2012 12:49 AM
01:49 AM
