shifting - Mustang Evolution
Old 02-21-2012, 05:41 PM   #1
br10301's Avatar
shifting
does anyone know why when I shift from first to second gear it feels like my car drops into second like a little buck idk wat it could be I've tried shifting slower coming off the clutch like a sloth and it still bucks 95% of the time..
br10301 is offline   Reply With Quote
Old 02-21-2012, 05:43 PM   #2
jhagan1980's Avatar
I believe it's a mustang thing cuz mine does it and do does my buddies.
jhagan1980 is offline   Reply With Quote
Old 02-21-2012, 05:48 PM   #3
br10301's Avatar
yea I've heard that but I've also driven my cousins he has the exact same car and it's smooth idk might bring it to get checked out
Old 02-21-2012, 06:00 PM   #4
wheelman's Avatar
Re: shifting
Been banging on that clutch by chance?
wheelman is offline   Reply With Quote
Old 02-21-2012, 06:45 PM   #5
br10301's Avatar
well to be honest this is my first manual car but I have drivin stick for a while before I naught the car I didn't brake the clutch in right but I don't think that's the problem and yes I do go through gears but not all the time.. wat do you think?
Old 02-21-2012, 08:28 PM   #6
wheelman's Avatar
Re: shifting
Dont know for sure but it seems to do it more as my car ages so I was just thinking that maybe its clutch disk wear. I think the stock clutch sucks as Ive been through 2 clutches in my last three Stangs, despite never burning one in another car and driving stick exclusively for 25 years.
Old 02-21-2012, 09:41 PM   #7
AgentOrange's Avatar
My car is clunky unless I am really, really deliberate with my shifting. I wouldn't classify it as a "buck" though. Sometimes a little studder. Nothing that bugs me. Car seems to take it well, and it smooths out a bit as the tranny warms up.
AgentOrange is offline   Reply With Quote
Old 02-21-2012, 09:44 PM   #8
br10301's Avatar
I agree with both of you but I used the word buck because i didn't know how else to describe it lol and even after the tranny worms up its still 90% that it happens
Old 02-21-2012, 09:47 PM   #9
It sounds like yours is more pronounced than normal. If you slip the clutch a bit can you eliminate the buck? Not that you should have to, but i'm curious.
Old 02-21-2012, 11:02 PM   #10
br10301's Avatar
yea most times but I honestly think its my clutch cuz like I said I didn't brake it in right at all u no
Old 02-22-2012, 07:27 AM   #11
imhooked's Avatar
Re: shifting
hey guys,
also sim prob here... a couple ideas-
1. have you drained and refilled tranny yet? this could help, and b4 going synthetic check with someone! i called tremec on my t-3650; guy there was very helpful, and said they only recommend mobil1 synthetic ATF, period.
2. along lines of above, if u do have 3650 be sure to fill to correct level; conflicting reports on how much recommended (manual does say 3.7 liters). some say fill till starts to spill from fill (with car LEVEL), others 1/2" below.
3. have you considered replacing clutch cable???
4. and how about new s-t shifter?!
imhooked is offline   Reply With Quote
Old 02-22-2012, 08:40 AM   #12
ColeJohnson's Avatar
Re: shifting
My car does "buck" a little unless I am deliberate in shifting, like Agent. However mine also bucks coming off the throttle fast. It's the pilot bearing allowing a little bit of play in the clutch's engagement. Might be something for you to consider. Did you replace it when you replaced the clutch?
2016 Comp Orange GT (current)
Old 02-22-2012, 08:49 AM   #13
br10301's Avatar
no I didn't replace the PB it's still the old one and I'm using sinthetic but I doubt it's that
---------- Post added at 10:49 AM ---------- Previous post was at 10:47 AM ----------
now that I think of it it prolly is my pilot bearing
Old 02-22-2012, 10:35 AM   #14
The pilot bearing being worn will cause that "bucking" and "jolting" motion when you get on and come off the throttle. Also a little when you go into gear, but once engaged with clean steady throttle it will be smooth again.
Old 02-22-2012, 05:46 PM   #15
jhagan1980's Avatar
I replaced fork,clutch disk,pressure plate,TOB,pilot bearing,cable,flywheel, and the quadrant and I still have this happen. I believe it's just a mustang thing.
Old 02-22-2012, 06:37 PM   #16
jwhayne0001's Avatar
+1
jwhayne0001 is offline   Reply With Quote
Old 02-22-2012, 06:55 PM   #17
br10301's Avatar
what kind of clutch for did u get!
Old 02-23-2012, 12:35 AM   #18
jhagan1980's Avatar
King cobra
Old 04-19-2012, 10:08 PM   #19
Lorraine's driver
ab_mach1's Avatar
My Mach does this and gets better when warmed up as you have mentioned. I'm wondering if it's the TR3650 trannys cause my '92 fox GT did not do this. I believe it was a T5. TR3650 was middle of 2001 till the Mustangs started using T56 I think.
Instagram: @ab_mach1
Old 04-20-2012, 05:43 AM   #20
jjsg09's Avatar
Mine does it too I have a 02 GT with the TR3650 and I had a 01 with the T45 and it wasn't as bad but on certain occasions it did it.
Old 04-20-2012, 06:05 AM   #21
My 2002 GT has a 3650 and doesn't shutter or buck at all in any gear. Hm..
Shifting in sloped driveway ReggStang 2011-2014 Mustang GT 7 01-30-2012 07:04 PM
Down shifting vinnygt General Car Discussion 34 12-17-2011 05:40 AM
Sound when shifting at high sppeds! deaser84 2011-2014 V6 Mustang 12 12-07-2011 05:14 AM
Vibrations on the trim around the shifting Knob phobik General Mustang Discussion 0 11-14-2011 07:23 PM
04 cobra shifting problems NickGeezy General Mustang Discussion 7 09-21-2011 10:41 AM
11:23 AM
