Seriously.. i need help. - Mustang Evolution
Old 02-23-2012, 06:23 PM   #1
Mustang_Madness's Avatar
I have in my hands a fuel pressure regulator. I need to swap it out for the old one which seems to have went bad. BUT its literally CONNECTED to the fuel rail. what the hell do i do. my mustang mechanic said i needed the FPR that i have in my hands after he checked up on my mustang but it doesn't look like i can use it! like i have to get a whole new fuel rail!! FRICK. please help.. maybe I'm not looking in the right spot but i am 95% sure I'm not..
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-23-2012, 06:27 PM   #2
Cobrarunnin9s's Avatar
Re: Seriously.. i need help.
first of all what fuel pressure regulator did you buy?
second there is 2 bolts that hold it on the rail, and 2 gaskets you need to swap from the stock one to your new one after you relieve the fuel pressure of course.
Cobrarunnin9s is offline   Reply With Quote
Old 02-23-2012, 06:32 PM   #3
I Bought the motor craft one. and i don't see it on the rail! Ill attach a pic. i relieved the pressure already
Old 02-23-2012, 06:33 PM   #4
Here are some pics
ID:	41649   Click image for larger version
Old 02-23-2012, 06:37 PM   #5
Thats the FPR i bought.
ID:	41652   Click image for larger version
Old 02-23-2012, 06:39 PM   #6
what year is your car? they went from return style to a returnless system in 1998. if it is returnless, the pcm regulates the voltage to the pump which varies the fuel pressure. you wont need a regulator you will need a fuel pump driver module.
Old 02-23-2012, 06:47 PM   #7
DAMNIT. its a 98 v8.
---------- Post added at 08:47 PM ---------- Previous post was at 08:46 PM ----------
the mechanic said i was running about 65 psi at an idle and 70 full throttle, when it should be at 30 and 40...
Old 02-23-2012, 07:04 PM   #8
ok thats good to know right there, its either the pump, the fuel pump driver module or the pcm or the circuits in between. the fuel pump driver module should be in the trunk somewhere. I personally havent dealt with this problem before since ive never owned a mustang newer than 97.
---------- Post added at 08:04 PM ---------- Previous post was at 08:00 PM ----------
i cant find specs for proper resistance or voltage to the FPDM. so I would take it back to him and have him put an osciloscope on those parts and find the bad piece. based off what you gave for info i would say its probably not the wiring or pcm but don't quote me on that.
« cowl hood | jack »
98 3.8 in need of power.. cam? trixinahat Pre-2005 V6 Mustang 33 02-26-2012 08:40 PM
I need some advice Cajunick 1996-2004 Mustang GT 9 02-22-2012 08:13 PM
done styling need to beef it up. murraydylan1993 1996-2004 Mustang GT 1 02-22-2012 07:41 PM
Need help!!!! WhiteCobra94 1979-1995 Mustang GT 6 02-21-2012 10:37 PM
Need some advice from you mustang experts ArmyScout 1996-2004 Mustang GT 7 02-21-2012 08:54 PM
11:47 PM
