Vibration after getting my 4.10's installed - Mustang Evolution
Old 02-24-2012, 04:47 PM   #1
99redgt's Avatar
Just got my 4.10 installed in 3rd and 4th around 60kmh 3,0000rpm,
there is a bad vibration and getting on the high way there is a bad vibration, the mechanic said that I don't have to break them in.. But it vibrates so bad on the highway.. Should I just take it easy and void what the mechanic said?
Some forums state that people leave the shop with the car side ways just going full out others say to break it in ?
99redgt is offline   Reply With Quote
Old 02-24-2012, 04:59 PM   #2
Re: Vibration after getting my 4.10's installed
I personally have never "BROKE IN" gears. I am on it from the get go! Vibration could be from the driveshaft.... Had the u-joints replaced?? Or as i did when I went to 4.10's I went with an aluminum drive shaft.
rk122075 is offline   Reply With Quote
Old 02-24-2012, 05:04 PM   #3
Gibby's Avatar
Take it back to the shop!!!! That vibration could ruin the seals in you rear end and tranny.
Gibby is offline   Reply With Quote
Old 02-25-2012, 07:50 AM   #4
99redgt's Avatar
Hope it's not the drive shaft... I'm bring it today
Old 02-25-2012, 08:12 AM   #5
x2 Hopefully it's not the driveshaft but you're spinning it alot faster now. Let us know how you make out.
Old 02-25-2012, 02:58 PM   #6
99redgt's Avatar
The pinion is bent thanks AM!
---------- Post added at 04:57 PM ---------- Previous post was at 04:56 PM ----------
Now I have to spend an other 400$ to get it taken out and put the old one back in so I can drive to work and then spend an other 400$ to get the warranty part installed again....
---------- Post added at 04:58 PM ---------- Previous post was at 04:57 PM ----------
Does anybody have any advice on how to get my labour covered since its not my fault that the part came bent from the factory ?
Old 02-25-2012, 03:05 PM   #7
deadsp0t's Avatar
It's not AM's fault if it came from the factory that way. If the pinion is in fact out of factory spec from the factory that's who you need to contact. Chances are they will claim they were installed incorrectly and try to refuse the claim. Are they FRP gears?
That's unimpressive
Old 02-25-2012, 03:08 PM   #8
99redgt's Avatar
Yeah ford racing
---------- Post added at 05:07 PM ---------- Previous post was at 05:07 PM ----------
It just sucks because now I have to miss work due to no car...
---------- Post added at 05:08 PM ---------- Previous post was at 05:07 PM ----------
I just hope they will cover labour or part of it
Modified my Race Red '11 5.0 GT Brembo M3hunter 2011-2014 Mustang GT 32 03-06-2012 05:11 AM
ticking sound under my car? Vile87 Pre-2005 V6 Mustang 29 03-04-2012 07:42 PM
my mustang lost its mojo!! XXSTEVEO66 1979-1995 Mustang GT 15 02-26-2012 02:54 PM
can someone give me info on putting heard in my 02 gt automatic scottiep101 1996-2004 Mustang GT 2 02-24-2012 07:26 PM
3.73 vs 4.10 gears on a daily driver lConnerl 1996-2004 Mustang GT 13 02-24-2012 07:25 PM
11:05 AM
