Making the hoodscoop functional - Mustang Evolution
Old 02-26-2012, 12:06 PM   #1
TXstang125's Avatar
I was wondering if there is a way to make the stock hood scoop functional with out having to remove the entire hood installation.
TXstang125 is offline   Reply With Quote
Old 02-26-2012, 12:17 PM   #2
Eturner's Avatar
I've looked into this too a couple years ago!.. And basically it would take a ton of fab work (that's putting it mildly)!... The time and money would be better spent elsewhere!..
Old 02-26-2012, 12:30 PM   #3
TXstang125's Avatar
I've seen some challengers that have a small cut out in the installation and it had some kind of plastic chamber (bet its not plastic ) leading from the opening of the in insulation to the scoop could this work with our cars
Old 02-26-2012, 12:40 PM   #4
Eturner's Avatar
Not in the way your thinking!.. The Scoop on our cars sits to far back from where the filter and MAF sit!.. In order for it to work you need to make the path for the air to be as direct into the intake as is possible!.. Otherwise it's just a waist!.. If your really wanting a "RamAir" setup then just get the Mach1 Shaker Scoop for your Stang!..
Old 02-26-2012, 01:29 PM   #5
StackeStang's Avatar
Re: Making the hoodscoop functional
drill a hole (or holes) in the hood under the scoop. won't look good if you take the scoop off, but it was put there for a reason, right?
StackeStang is offline   Reply With Quote
Old 02-26-2012, 01:33 PM   #6
TXstang125's Avatar
Like this
Old 02-26-2012, 01:40 PM   #7
Eturner's Avatar
Like this
Are you talking about makeing a Ram Air setup or just bringing more air under the hood?...
Old 02-26-2012, 02:03 PM   #8
TXstang125's Avatar
Just more air. no ram air setup
Old 02-26-2012, 02:11 PM   #9
Eturner's Avatar
Then drill out the honey comb crap in the front (or just remove it all together)!.. Then drill out, or cut out, that small portion of the hood (underside that is) that looks like the same shape of the front of the hood scoop!..
This is just a basic run down of what to do!.. But keep in mind that there is no real benefit to this!..
Got the new wheels on Rapinator126 Mustang Wheels & Tires 36 03-27-2012 03:40 PM
New best at the track 04machazblue 1979-1995 Mustang GT 11 03-07-2012 10:07 PM
Help from the 6er community!! 2002VertGT Pre-2005 V6 Mustang 13 02-26-2012 05:39 PM
Just came back from the autorama 351mustang 1979-1995 Mustang GT 3 02-25-2012 08:00 PM
Check it out. Posted some pics of the ol' stang. Nog51 Pictures and Videos 38 02-25-2012 01:53 PM
04:45 AM
