Is it really that hard?? - Mustang Evolution
Old 02-28-2012, 08:56 AM   #1
98StangKid's Avatar
Hey everybody. I'm still kinda new to the mechanics world. Lol. But I'm wanting to do my first full tune up to my Mustang myself. But I've heard horror stories from the heads and plugs. Is it really that bad? Just thought I'd get some insight. All input is appreciated! Thanks!
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 02-28-2012, 09:44 AM   #2
Jsansom's Avatar
No. I did mine and I don't have any problems. Just be careful when u put them back in.. Make sure they aren't cross threaded.. I Put them in then startin tightening them by hand (with an exstention) to make sure they were goin in right them tighten them down..
Jsansom is offline   Reply With Quote
Old 02-28-2012, 10:51 AM   #3
Re: Is it really that hard??
taking your time and not forcing things generally solve most issues people have
Old 02-28-2012, 11:32 AM   #4
98StangKid's Avatar
Ok. Thanks guys. I appreciate it. Any pointers for this? Anything I need to know?
'01 Cobra
Old 02-28-2012, 11:38 AM   #5
jjsg09's Avatar
I did it on my 01 GT and took my time and was very carful and I still blew two spark plugs. Not at the same time but I had to have one heli-coiled from Ford but the mechanic at Ford said it looked like I did them right and used the right plugs.
Old 02-28-2012, 11:44 AM   #6
98StangKid's Avatar
See.. That's what I'm scared of.. And I can't afford for my car to be down.. :/
'01 Cobra
Old 02-28-2012, 11:49 AM   #7
jjsg09's Avatar
Yea my 02 GT has 90kmiles on it and it's time to do it on this car. My buddies F150 did it too and Ford changed them out and they wouldn't replace his heads they just heli-coiled it too. I guess just be careful and use the stock plugs you might have more luck than me, plus I don't know if the last guy who owned the car changed them and damaged the threads. Fords buggiest mistake on these cars was the threads for the plugs.
Old 02-28-2012, 11:59 AM   #8
DaBluedude's Avatar
The 96-98gt is a little tough to do plugs on but if your careful (and get a good spark plug socket!!!) You'll be ok. Some guys take the fuel rail off to give them better access. The passenger side is a bit of a ***** for sure! Make sure u use quality anti siez compound and good electric grease and u should be ok. Take an afternoon and be prepared to take things nice and slow. Do as much of it by hand as u can to avoid thread damage. I used high quality iridium tipped plugs. Make sure they are gapped perfectly tho because one of mine wasn't.
2003 Mach 1
Old 02-28-2012, 02:12 PM   #9
Randl114's Avatar
Not that bad of a job. Something that might make it go a little smoother that I would recomend, after you remove the wires from the plugs, spray a little PBblaster down each hole. Let is sit for a bit, then remove the plugs. Definatly take your time.
Your enemy is doing what you can not. When you meet he WILL defeat you.
Randl114 is offline   Reply With Quote
Old 02-28-2012, 02:21 PM   #10
Mustang_Madness's Avatar
I literally just did mine on my 98 v8 and it went without a problem. It runs So much better now to because i had a misfire and leaks and such. I cant afford to not have my mustang running either but i got this done in a few hours! Just take your time like they said! Get a goooood gapper. Not that cheap circle thing. Doesnt have to be Great either but nice and durable. Also, when i pulled them, i noticed a part of the rubber boot that goes over the plug got severed off. Dont let that happen to you! Just take your time, maybe get some boot pullers, although needlenose works to, and be gentle. Your workin on the 3rd most important instrument in a car! Besides fuel and oxygen! Btw i got double platinum because iridium didnt seem like it was worth the jump in cost. As well as E3
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-29-2012, 08:14 AM   #11
98StangKid's Avatar
Nice. Thanks. I think I'm gonna do it Friday if I get the chance. Thanks for all the input!
'01 Cobra
Old 02-29-2012, 09:01 AM   #12
jjsg09's Avatar
Sorry for my horror story I thought you had pi heads if you have the non pi heads you'll be fine.
Old 02-29-2012, 09:02 AM   #13
ChuckD's Avatar
I got my mustang from my brother in Oct. And havnt done anytjhing to it myself, but he complained about how annoying they were to work on the whole time he had it. The way he made it sound anytime he had to change something he spent more time taking off other parts to get to it then actually fixing it, but that was mostly not engine stuff.
ChuckD is offline   Reply With Quote
Old 02-29-2012, 09:04 AM   #14
98StangKid's Avatar
Yea it's all good. No worries. But thanks. That's good to hear.
'01 Cobra
Old 02-29-2012, 09:11 AM   #15
If theyre annoying dont have one! I Love working on my car. Its awesome. And im willing to invest time and energy into making it run better or look nicer. That goes with most people with mustangs. Especially on this forum! True, you do have to take some stuff off to get to others but thats with every car! And if you aint willing to get your hands dirty, dont get the car and expect to be "in tune" with it.
Old 02-29-2012, 09:19 AM   #16
32vNomad's Avatar
From the R&D team at Ford
303-07B-1 Engine Ignition -- 4.6L (2V) 303-07B-1
REMOVAL AND INSTALLATION
Spark Plugs
NOTICE: Do not remove the spark plugs when
the engine is hot or cold soaked. Spark plug
thread or cylinder head damage can occur. Make
sure the engine is warm (hand touch after
cooling down) prior to spark plug removal.
1. Remove the ignition coil-on-plug. For additional
information, refer to Ignition Coil-On-Plug in
this section.
2. NOTICE: Only use hand tools when
removing or installing the spark plugs or
damage can occur to the cylinder head or
spark plug.
NOTE: Use compressed air to remove any
foreign material from the spark plug well before
removing the spark plugs.
NOTE: If an original spark plug is used, make
sure it is installed in the same cylinder from
which it was taken. New spark plugs can be
used in any cylinder.
Remove the spark plugs.
o To install, tighten to 18 Nm (159 lb-in).
3. Inspect the spark plugs. Install new spark plugs
as necessary. For additional information, refer
Removal and Installation to Section 303-00.
4. To install, reverse the removal procedure
Copyright ã 2004, Ford Motor Company
Last updated: 8/10/2009
32vNomad is offline   Reply With Quote
Old 02-29-2012, 09:23 AM   #17
98StangKid's Avatar
Spark Plugs
this section.
spark plug.
Thank you sir.
'01 Cobra
Old 03-06-2012, 08:30 PM   #18
ChuckD's Avatar
As I said, that is what my BROTHER told me from his experience working on my car, and clearly he doesn't have it anymore if he sold it to me. Lol
Old 03-06-2012, 09:09 PM   #19
Vegas97gt's Avatar
Region: Nevada
Yeah it's not difficult to do the plugs just have a few extensions different sized and a swivel extension and you'll get them all in and out in a flash but I would recommend doing changing the wires also because I broke one when I was reinstalling and it was missing so bad i thought something was seriously wrong but after a new set of wires firing good on all 8 again.
Vegas97gt is offline   Reply With Quote
Old 03-06-2012, 09:16 PM   #20
1995boss's Avatar
Don't forget to gauge the spark plugs.
1995boss is offline   Reply With Quote
Old 03-07-2012, 11:02 AM   #21
CodyNelson's Avatar
Region: West Virgina
Just did mine today. Just put a little antisieze on the threads then take your time and run them in by hand first before torquing them down. I torqued mine to 135 in/lbs then just snugged them one last time. Let it idle for about 5 minutes then drove it for about 30 and have no problems. As said above, just take your sweet time and all willl be fine
Old 03-07-2012, 04:41 PM   #22
jjsg09's Avatar
I think where I messed up was I didn't let the engine completely cool down before I changed mine out and I herd that makes the difference.
Old 03-07-2012, 05:26 PM   #23
32vNomad's Avatar
I did post ford instructions and I believe it stated to let engine cool but not to change then cold as well.
Old 03-07-2012, 06:39 PM   #24
CodyNelson's Avatar
Yep you want it cool but not cold. I drove mine for like 10 minutes and then let it sit for like 30 before i started
« gears | iAC! »
What it takes for forced induction and much more... dreamstang 1979-1995 Mustang GT 2687 10-31-2012 12:50 PM
if you could have ANY stang in the world, which one would it be?? zeltik General Car Discussion 80 03-14-2012 09:46 PM
Easy or hard? Mustangg5 Mustang Audio & Video 10 03-07-2012 11:53 PM
99 mustang misfiring during hard throttle 1quick4.6 1996-2004 Mustang GT 5 02-28-2012 12:53 PM
Convertible hard top Yellow50 2011-2014 Mustang GT 3 02-28-2012 11:06 AM
02:01 PM
