OBD codes - Mustang Evolution
Old 02-28-2012, 08:11 PM   #1
OBD codes
check engine light has been on a while, just wondering what others thoughts are. p0420 p0430 p0304 and it was c1264 then i ran the car for a little bit and that code went away now its c1200. im not even sure where to start with this car. i love the thing but it was never taken care of and im getting all of the problems. paid 4800 for it and should have just spent another 1500 and got a better car.
Bosaliniee is offline   Reply With Quote
Old 02-28-2012, 08:18 PM   #2
AgentOrange's Avatar
Sorry if this is a crummy response, but thats a lot of different codes. I'd start with a google search on each. Just do something like "P0420 Mustang". There's a good chance a few of those codes are related.
AgentOrange is offline   Reply With Quote
Old 02-28-2012, 08:25 PM   #3
Re: OBD codes
sorry, i did do that. i was going to post them up but was double checking the codes
P0304 Cylinder #4 Misfire Detected
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
C1264 Lamp Warning Relay Circuit Short To Battery
C1200 ABS Inlet Valve Coil LF Circuit Short To Battery
does this mean i have a bad cat? how do i check for shorts?
Old 02-28-2012, 08:40 PM   #4
Start with the easier problems. Electrical diagnosis can be extremely difficult depending on where the fault is. I'd check the spark plug and coil on #4. If the plug looks suspect, a haynes manual or a google search will show you what plugs look like under different circumstances. It is possible that the misfire, if really bad, could give your O2 sensors a fit. How does the car run? is your ABS light on?
Old 02-28-2012, 08:52 PM   #5
Re: OBD codes
it was running fine until i sprayed engine degreaser then rinsed it off. now every once and a while it likes to shutter on acceleration. abs is on and traction control off and cant be turned on.
Old 02-29-2012, 07:56 PM   #6
Re: OBD codes
how do you test for shorts to battery and shorts to ground?
Old 02-29-2012, 08:24 PM   #7
sean03gt's Avatar
Does your car have cats on it still?
sean03gt is offline   Reply With Quote
Old 03-01-2012, 08:36 PM   #8
Re: OBD codes
took it to exhaust shop for a leak, they didnt say i didnt. but the previous owner cut out the h pipe so he put one in for me. i havent looked though.
Old 03-02-2012, 06:08 AM   #9
Enderthreesix's Avatar
I had the same misfire code on mine. Mine was a coil pack that went bad and that is why your shuttering on acceleration. Learn from my mistake if that does turn out to be the coil pack and not the plug. I replaced one of mine and a week and a day later a second one went on me. I found out later you should really change them all at once. I could be wrong but that's what I was told and it is a little suspect that they both went in a weeks time. That's probably what caused your O2 code as well.
Enderthreesix is offline   Reply With Quote
Old 03-02-2012, 11:51 AM   #10
sean03gt's Avatar
Well if the exhaust stop said they put cats on the h pipe then it should take care of the codes for the cats
Old 03-02-2012, 06:47 PM   #11
Re: OBD codes
he didnt do anything with the cats. just added an h pipe. the previous owner cut it out and had it running without.
Old 03-02-2012, 08:29 PM   #12
sean03gt's Avatar
Oh ok well sorry i miss read the post then
Old 03-02-2012, 09:10 PM   #13
Re: OBD codes
it happens. hopefully i have time this weekend to check the plugs and coils. but how do i check for shorts? i dont know if this is related to my code for the short, but my battery dies if i let the car sit for 2 days. but the battery tests good.
Old 03-03-2012, 01:36 PM   #14
Check the battery cables. I had a battery cable loosen up on me and the battery would die over night. One morning I jumped it and the computer kept resetting causing the needles to go crazy and the car to stall out. I had to do all I could to move the car 100 feet into a parking space and it turned out to be just the cable coming loose. Originally it would take a couple days for it to die but it steadily got worse.
Old 03-03-2012, 08:57 PM   #15
jdmeaux's Avatar
Re: OBD codes
Look at it this way. You washed the engine down and THEN got the codes. Possibly got water to short the coil on #4 which will cause the O2s to go crazy sometimes. Water will also short out other sensors. Try to make sure everything is dried out, clear the codes, and run it again.
1997 CVPI ** ex-U.S. Marshall Service (the CAR) I don't think it was stock from them ** 13.26@107.24 MPH w/ me, my tools, and a full tank Added CAI, Niche 19 x 8.5" wheels with 245/45ZR19 rubbers, and a complete front end rebuilt with poly
A Super Duty Mustang Sedan
My Avatar is a picture of my Dream Machine
jdmeaux is offline   Reply With Quote
Old 03-04-2012, 05:46 PM   #16
Re: OBD codes
the 420 and 430 were always there, the others are the ones that showed up after washing it. ive tightened the battery but it still happens. if i unhook the battery before leaving it set a couple days, i hook it up and it fires right up.
Old 03-04-2012, 06:20 PM   #17
jdmeaux's Avatar
Re: OBD codes
Do an online search for DIY correcting the 420 and 430 codes. It will probably lead you into a bunch of forums. Then you can see what others found out to correct them.
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 2 01-23-2012 10:28 PM
ok i have a 95 gt 5.0 getting codes 311 and 314 durtyred69 1979-1995 Mustang GT 5 01-19-2012 08:58 PM
Codes p1401 and p0340 Blackedout Pre-2005 V6 Mustang 0 12-01-2011 04:07 PM
Best OBD II Scan Tool? shipwreck_98 Pre-2005 V6 Mustang 2 11-26-2011 07:15 PM
Obd codes nickysixx 1996-2004 Mustang GT 3 10-03-2011 02:12 PM
02:54 AM
