x pipe help - Mustang Evolution
Old 02-28-2012, 09:54 PM   #1
secomejia's Avatar
x pipe help
Would a 1999-2004 x pipe(pypes) fit a 2003 mustang cobra??????
secomejia is offline   Reply With Quote
Old 02-28-2012, 10:14 PM   #2
Titus Wadicus
svtlx's Avatar
Re: x pipe help
u should just call pypes and ask them. they are the ones that told me my entire fox body exhaust would fit sn95 when doin my swap. from wut they told me i think the xpipe would work. like i said. just ask them
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-28-2012, 10:24 PM   #3
deadsp0t's Avatar
It will if you use SN95 headers, the SN95's ball/sockets are bigger then the Foxes. To the op, some posted a similar question a while back and it was said that it would work. I do know they list cat-backs for cobras separately cause of the IRS. May need some modification to work.
That's unimpressive
Old 02-28-2012, 10:30 PM   #4
Eturner's Avatar
Are you talking about a X-pipe off a GT?.. If so I would give them a call to find out for sure!.. My guess would be probably not!.. Or find a pic of each and compare!..
Old 02-28-2012, 10:32 PM   #5
deadsp0t's Avatar
Think only the cat back is slightly diff. Idk.
Op be sure to let us know.
That's unimpressive
Old 02-28-2012, 10:40 PM   #6
secomejia's Avatar
Ok guys thanks
Old 02-28-2012, 10:44 PM   #7
Eturner's Avatar
Thats what I'm thinking too but I don't know for sure!.. A buddy of mine did a 4V swap on his '98 GT, then a couple years later swapped in the IRS setup!.. Said at that time all he had to do for the exhaust was get another cat back system!.. So the X-pipe might be interchangeable between the two but I don't know for sure!..
Old 02-28-2012, 10:45 PM   #8
Titus Wadicus
svtlx's Avatar
Re: x pipe help
not true dude. i got 86-93 headers on my 96 right now. it bolts up front to back. at the same token...that means u can do a mod motor swap on a fox and have full exhaust already there. which is kinda cool.
Old 02-28-2012, 10:48 PM   #9
deadsp0t's Avatar
It's most certainly true. The ball(smaller) goes into SN95 socket(larger) If you had SN95 headers you can't use a Fox mid pipe. Get what I'm saying??????
That's unimpressive
Old 02-28-2012, 10:48 PM   #10
Titus Wadicus
svtlx's Avatar
Re: x pipe help
yea, only the catback is different for that application. it goes under the rear end instead of over to accomadate the flexible axles.
Old 02-28-2012, 10:49 PM   #11
Eturner's Avatar
Isn't 86-93 a 5.0 pushrod motor?.. And the '96 a 4.6 SOHC motor?...
Old 02-28-2012, 10:50 PM   #12
deadsp0t's Avatar
65'-95' are push rod engines
That's unimpressive
Old 02-28-2012, 10:53 PM   #13
Titus Wadicus
svtlx's Avatar
Re: x pipe help
noooo, its that egr pipe that changes the header part number. on foxbody that egr is connected further down the h-pipe. on sn95 its on the header. i never heard that stuff bout da ball socket, i dont think that is accurate
---------- Post added at 12:53 AM ---------- Previous post was at 12:52 AM ----------
you can ask pypes or bbk, they will tell you the same thing
Old 02-28-2012, 10:53 PM   #14
deadsp0t's Avatar
Ok
Maybe the aftermarket parts match, but stock parts are different.
That's unimpressive
Old 02-28-2012, 10:56 PM   #15
Titus Wadicus
svtlx's Avatar
Re: x pipe help
yup, that is true. but you can swap the two cause all da way up to 03 is fox body based chassis. putting 4.6 in fox bodies isnt new...not super popular, but definatley not new. and droping 5.0 and 351 in 03 body is more popular though.
Old 02-28-2012, 10:57 PM   #16
Eturner's Avatar
Ya I know!.. What I'm getting at is that they have different heads!.. And I don't see how headers from one can bolt up to the other unless Ford used the exact same bolt pattern on both!.. Lol.
Old 02-28-2012, 11:00 PM   #17
deadsp0t's Avatar
The fox-fox4 platform runs through 04'
The fox4 cars are longer then the 79-93 foxes
That's unimpressive
Old 02-28-2012, 11:03 PM   #18
Titus Wadicus
svtlx's Avatar
Re: x pipe help
i think i know wut u r getn at.
the mid section and cat back are the same for 86--03....
the header itself is differnt though from pushrod motor to mod motor if that makes any sense
---------- Post added at 01:03 AM ---------- Previous post was at 01:00 AM ----------
oops 04...and how much longer is the fox 4?
Old 02-28-2012, 11:07 PM   #19
deadsp0t's Avatar
Don't now the exact number, but when I put a Tremec 3550 in my 1st 95 I had to have a DS made(the spacers were not available then) think the spacers for putting fox t5 in a 95 are 5/8's. It's un-drivable otherwise. It will vibrate really bad
That's unimpressive
Old 02-28-2012, 11:17 PM   #20
Eturner's Avatar
Then how were you able to fit a header from a 5.0 to a 4.6?.. Little confused here!... Lol
Old 02-28-2012, 11:26 PM   #21
secomejia's Avatar
Im more confuse tgan before :'(
Old 02-28-2012, 11:30 PM   #22
Eturner's Avatar
Sorry if I added to that!!... Lol
Old 02-28-2012, 11:40 PM   #23
secomejia's Avatar
So the question is:. Does it fit or not lol
Old 02-28-2012, 11:49 PM   #24
Eturner's Avatar
It might but I would still call Pypes and make sure if I were you!..
---------- Post added at 01:49 AM ---------- Previous post was at 01:48 AM ----------
I know that don't help ya much but it's all I can give bro!.. Lol
Old 02-29-2012, 12:35 AM   #25
secomejia's Avatar
Lol thanks bro!!
Old 02-29-2012, 05:38 AM   #26
Eturner's Avatar
Lol thanks bro!!
No problem!.. Lol
Old 02-29-2012, 09:51 AM   #27
Titus Wadicus
svtlx's Avatar
Re: x pipe help
no, no....the headers are definatley different. im just sayn the mid-pipe will bolt up to both 4.6 or 5.0 headers.
---------- Post added at 11:51 AM ---------- Previous post was at 11:40 AM ----------
your right...its 5/8s. i had to take a grinder and cut the input shaft down 5/8s as well as the bearing retainer sleeve (throw out bearing rides on). or you can just order the two parts for 86-93 t-5. they are shorter than 94 and up t-5 stuff. they added the 5/8s to move the shifter rearward in the card. your vibration came from the bearing retainer sleeve pushing the clutch disc into the flywheel.....
thats how i mated a 96 v-6 t-5 to a 5.0
but i dont think the car is actualy longer though. i swaped shocks, springs, upper and lower control arms, sway bars, full exhaust (headers to tips) from my 92 to my 96. it was pretty much a straight swap
Old 03-01-2012, 04:30 PM   #28
deadsp0t's Avatar
On the lift you could see where the front yoke was no where near as deep inside the tail shaft, the shifter was further up in the console. As far as the car being longer, this info is easily found with quick google search or Wikipedia, almost 70% of Fox 4's are new/different then the 79-93 Foxes.
http://auto.howstuffworks.com/1994-1...d-mustang3.htm
That's unimpressive
Can't get out of park, help! 97greenstang Pre-2005 V6 Mustang 8 03-21-2012 10:22 AM
help me please jstn_hasty 1996-2004 Mustang GT 11 03-01-2012 08:11 PM
help with decision about full exhaust angelofrat42 2005-2010 V6 Mustang 11 03-01-2012 09:35 AM
Tuner help 2002VertGT 1996-2004 Mustang GT 43 02-28-2012 07:16 PM
need help Robbie94gt 1979-1995 Mustang GT 3 02-28-2012 10:59 AM
10:33 AM
