Trickflow Heads & Cams - Mustang Evolution
Old 02-28-2012, 10:44 PM   #1
FORDGT14's Avatar
Ive decided to skip all of the "bolt-ons" and order some trickflow heads and cams with my extra income tax $. But ive got a small problem. The engine in my car is a "windsor" but Ive got an '04 "romeo" block stripped apart. I was thinking i could just drive the car with my fresh built engine (the windsor block) thats in it, and build up the romeo block on the side with the trickflow heads and a forged bottom end.
So my obvious question is, can i put the romeo engine in my car after im done building it? And what will i have to change to make it work?
My other question is, will i have to special order the trickflow heads for the romeo block? Or do trickflows fit both romeo and windsor blocks?
Thanks for any help and/or ideas for my build!
Pics of my current set up bellow. Its pretty much stock.
ID:	42092   Click image for larger version
ID:	42094   Click image for larger version
FORDGT14 is offline   Reply With Quote
Old 02-29-2012, 12:32 AM   #2
The blocks are pretty much the same, the names are because of where they were built only thing
I believe is different is valve covers but yes the heads will fit both blocks
96gt014.6 is offline   Reply With Quote
Old 02-29-2012, 01:33 AM   #3
FORDGT14's Avatar
The valve covers and crank flange.
Windsor valve covers - 13/14
Crank flange is 8 bolt
Romeo valve covers - 10/11 i believe
Crank flange is 6 bolt
I know because my windsor engine has a romeo crank in it. I went through ALOT of bull**** to figure that out lol
But i just need to know if the heads from a romeo will bolt on to a windsor or vise versa. If they interchange then i can just order a set of heads for a 99-04 Gt..if they dont, will i have to order it specifically for a romeo or a windsor block?
Old 02-29-2012, 01:40 AM   #4
Well then lol and yeah they will fit, the block itself is the same, it maybe made of different metal idk but windsor and romeo are just basically where they are built.
---------- Post added at 02:40 AM ---------- Previous post was at 02:39 AM ----------
In other words yes the heads will bolt on. Did Where you get them from not say that ?
Old 02-29-2012, 01:53 AM   #5
FORDGT14's Avatar
I dont understand that last question lol
If your asking where i heard that from? Ive heard alot of things about the 2 being different, especially when i was getting ready to rebuild mine. But since i have my car setup for a romeo crank anyways, the romeo block should have no problem bolting right up considering it has a romeo crank! Lol
So all i have to do is order the heads and they would fit on either one of my blocks right? So for whatever reason, if i decided to just pull my current windsor engine and slap the heads on it..it would work?
Old 02-29-2012, 03:36 AM   #6
I meant as in the site or whatever you go the heads from didn't have info saying that you could and yep you can. Just slap then on and you are good to go.
Old 02-29-2012, 05:31 AM   #7
jjsg09's Avatar
You might have seen this but if not look what summit racing has
http://m.summitracing.com/parts/TFS-K519-390-375
There is 4 different kits they sale with the same set up its a nice deal. I wish I could do this to my car.
Old 02-29-2012, 11:04 AM   #8
FORDGT14's Avatar
Ive heard that i could run into "piston to valve" problems with these heads and cams though. Anyone know anything about it?
Old 02-29-2012, 11:39 AM   #9
02PONY's Avatar
Yes u can use tf heads on either Windsor/Romeo
The only differences I remember we're the amout of bolts for the crank/& valve covers also some cam sprockets were fixed to the cams some bolted to cams
02PONY is offline   Reply With Quote
Old 02-29-2012, 11:43 AM   #10
FORDGT14's Avatar
Is there any piston to valve issues with these things?
Old 02-29-2012, 11:46 AM   #11
I never heard that at all.
Old 02-29-2012, 12:21 PM   #12
02PONY's Avatar
I didn't have any
Old 02-29-2012, 01:37 PM   #13
FORDGT14's Avatar
Ok then it should be fine, what kind of power increase did you see with them?
Old 02-29-2012, 03:03 PM   #14
02PONY's Avatar
I had them on my f150 liitle bit power but mostly liked the lope lol I haven't done head work yet on my stang
Old 02-29-2012, 03:42 PM   #15
CodyNelson's Avatar
Region: West Virgina
Absolutely not. They actually give you more room than stock heads
Old 02-29-2012, 04:00 PM   #16
03GT88's Avatar
Do you know which has the cam sprockets bolted?
03GT88 is offline   Reply With Quote
Old 02-29-2012, 04:57 PM   #17
02PONY's Avatar
I believe the Romeo are bolt on sprockets
Old 02-29-2012, 07:38 PM   #18
03GT88's Avatar
So if you have the Romeo and you upgrade cams you wouldn't have to buy new cam gears I'm guessing since they aren't pressed on?
Old 02-29-2012, 07:40 PM   #19
02PONY's Avatar
True unless u want the adjustable sprockets
Old 02-29-2012, 07:44 PM   #20
03GT88's Avatar
That's great savings of 249.99 haha
Old 03-01-2012, 01:07 AM   #21
FORDGT14's Avatar
How much hp can you gain from just camming the it? I might just do that for now if the increase in hp is worth what cams cost. If its not much then ill just do the heads/cams all at once i guess.
Old 03-01-2012, 04:30 AM   #22
02PONY's Avatar
AFM test showed like 70-90 gains with moderate port and polished heads +stage 2 cams they didn't say if any other bolt ons were present
Old 03-02-2012, 04:23 PM   #23
FORDGT14's Avatar
So do you think its worth the extra hp? Lol how much are you putting to the wheels?
Old 03-02-2012, 04:49 PM   #24
02PONY's Avatar
I still haven't put them in I'm still using stang as daily driver until I buy a beater and think I'm going to put them on my 5.4
Old 03-02-2012, 11:10 PM   #25
FORDGT14's Avatar
Cool, and then the 5.4 in the stang? Its gona be crazy!
Old 03-02-2012, 11:29 PM   #26
02PONY's Avatar
Ya that's the plan soon as the funds come in for another vehicle hopefully soon but it'll prob be next winter when I get loan paid off from dads funeral
Old 03-03-2012, 12:37 AM   #27
FORDGT14's Avatar
Sorry about your dad man..
Thats kinda what im doing, i wana have a dependable little beater before i tear the stang back apart
Old 03-10-2012, 03:12 PM   #28
FORDGT14's Avatar
How much hp could you gain from just getting heads for a 2V 4.6l ported and polished? I was just quoted $350 to have mine done at a local machine shop, should i have my heads done or just buy the trickflow heads? Id save a few grand having the heads ported and polished but is the power gain anywhere near what trickflows can make?
Help please?
Old 03-10-2012, 05:02 PM   #29
Newline's Avatar
This really depends on what other work you have done, how much power your ooking for and is it the best upgrade at this time . I like patriot performance heads for the price they are great and cheaper than trick flow by a serious amount. But, if you have a nice setup with cams and exhaust etc. ported and polished is nothing to shy away from. If your looking for 350 to 400. Go for it
Newline is offline   Reply With Quote
Old 04-18-2012, 10:37 AM   #30
Newline's Avatar
Doing bump steer kit on a 03 Mach 1. . . My helper takes out the inner tie rod and vacates the radiator with a nice big hole. My day rules
exhaust & warranty 04TRV6 2011-2014 V6 Mustang 20 03-04-2012 06:26 PM
Dual Exhaust Conversion & Smog Soccerluvr4 2005-2010 V6 Mustang 2 02-29-2012 10:11 PM
CMS Stage 1 N/A Cams 01mineralgreyv8 1996-2004 Mustang GT 8 02-28-2012 11:02 AM
P&P p/i heads 02PONY Mustang Parts for Sale and Wanted 3 02-27-2012 05:26 PM
K&N or Air Raid br10301 1996-2004 Mustang GT 6 02-27-2012 12:01 PM
02:38 AM
