iAC! - Mustang Evolution
Old 03-01-2012, 10:58 AM   #1
Mathew r Wright's Avatar
iAC!
Ok so I have owned this 00" gt for lil over a month, and I really hate how it takes like 10sec to idle down... I want to know how to mod the idle air control valve so it doesn't take so long. I'm just kinda lookin for the faster idle is it possible surely it is right...
Mathew r Wright is offline   Reply With Quote
Old 03-01-2012, 11:08 AM   #2
Titus Wadicus
svtlx's Avatar
Re: iAC!
i think you should leave it alone and be happy your iac works....once you start modding you will have a new appeciation for consistant idling. lol
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-01-2012, 12:15 PM   #3
BigB227's Avatar
+1^ my buddy made the mistake of trying to mess with it on my his stang, has never idled right afterward
BigB227 is offline   Reply With Quote
Old 03-01-2012, 12:37 PM   #4
02PONY's Avatar
Yes tried the mods to the iac my self I had to buy new one cause I flubbed it up $75 ill just deal with the rpm delay
02PONY is offline   Reply With Quote
Old 03-01-2012, 06:18 PM   #5
Re: iAC!
Oh ya I think ur right I'll leave it be but hey I'm a die hard fan glad I own one now, new to the game, and it looks like u know a lot about stands so I was wounderin about cams and n2o? What do u think should I go there or no? Man I have a million Q's and ideas just wish someone with time an patients would guide me there is a lot to learn...
Old 03-01-2012, 07:38 PM   #6
02PONY's Avatar
No to nos yes to heads and cams but these modular motors are expensive to build
Old 03-02-2012, 07:30 AM   #7
Titus Wadicus
svtlx's Avatar
Re: iAC!
+1^
Old 03-03-2012, 08:05 PM   #8
mhobbs's Avatar
Re: iAC!
no nos. Tune, cams, heads or port, exhaust
mhobbs is offline   Reply With Quote
Old 03-04-2012, 06:32 AM   #9
Re: iAC!
if i could do it all over again id have a pushrod motor. mod motors are so expensive
gregor185 is offline   Reply With Quote
Old 03-04-2012, 06:40 AM   #10
Eturner's Avatar
They are expensive to mod, but they respond better to those mods!..
Old 03-04-2012, 06:47 AM   #11
Re: iAC!
true
Old 03-07-2012, 10:03 AM   #12
Re: iAC!
So why no nitrous? What wrong with that idea?....
Old 03-07-2012, 06:24 PM   #13
Jlt00bluegt's Avatar
Man it's good that your excited about your mustang but like the above said there expensive. So you need to be selective unless you have some deep pockets or great credit lol. You can find a lot of info on these cars just start doing searches. The first thing you probably should do is a compression test to see if your engine is health enough to handle a power adder.
Jlt00bluegt is offline   Reply With Quote
Old 03-07-2012, 06:56 PM   #14
Re: iAC!
So how and where do I get that done? The compression test?
---------- Post added at 07:56 PM ---------- Previous post was at 07:46 PM ----------
So I found a kit by trickflow for cams that is... The kit has everything even new longer gear bolts... The kit is at summit for $699.00 what do you guys think?..
IAC Issues Cajunick 1996-2004 Mustang GT 20 01-08-2012 08:51 AM
2000 v6 rmps after iac change CHILE10_STANG Pre-2005 V6 Mustang 6 05-06-2011 06:24 PM
iac restrictor plate white 98 gt 1996-2004 Mustang GT 3 10-15-2007 10:30 AM
IAC 98StangGT 1996-2004 Mustang GT 0 09-12-2006 03:45 PM
IAC motor? Fast93Coupe 1979-1995 Mustang GT 3 06-25-2006 03:54 PM
12:32 PM
