New clutch - Mustang Evolution
Old 03-01-2012, 11:34 AM   #1
Califas gt's Avatar
New clutch
I have a 2003 gt it needs a new clutch what do you guys recommend?
Califas gt is offline   Reply With Quote
Old 03-01-2012, 12:22 PM   #2
Titus Wadicus
svtlx's Avatar
Re: New clutch
just an oem/stock replacement unless your making some decent horse..
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-01-2012, 01:08 PM   #3
Califas gt's Avatar
I'm thinking to upgrade some more to it but not right now, I have a few upgrades I look at some stage 1 clutches but I'm not sure which to put
Old 03-01-2012, 03:37 PM   #4
Titus Wadicus
svtlx's Avatar
Re: New clutch
wuts your hp goal? that will dictate clutch... lotsa ppl over clutch their cars, so that is y i am askn
Old 03-01-2012, 08:06 PM   #5
Califas gt's Avatar
Well I have a cold air intake, a flow master, under drive pulleys, it's not a lot but may be in the future if I get a cheap super charger I would put it in. A friend told me it would be good a stage 1 but I don't know the a decent brand and I'm gonna need a flywheel too right?
Old 03-01-2012, 09:08 PM   #6
Jsansom's Avatar
I got a spec stage one clutch in mine.. It holds up pretty well
Jsansom is offline   Reply With Quote
Old 03-02-2012, 04:02 AM   #7
Califas gt's Avatar
Ok cool thanks man
Old 03-02-2012, 07:33 AM   #8
Titus Wadicus
svtlx's Avatar
Re: New clutch
Sorry im not more help. i just have limited experience with manuals, and my clutch is stock
Old 03-02-2012, 07:39 AM   #9
deadsp0t's Avatar
Center Force Dual friction. They have the best release bearing, lightest pedal and if adjusted properly will last a long time.
That's unimpressive
Old 03-02-2012, 12:33 PM   #10
jjsg09's Avatar
I'm glad you started a thread on this because I'm now looking for a clutch. I'm looking between a SPEC stage 1 or center force but who sells the center force for a good price. Mine is a everyday driver and I don't want a heavy peddle.
Old 03-02-2012, 01:31 PM   #11
Ruben3's Avatar
I have an 04gt I put in a Ram Hdx and love it had it for over a year with no issues both me and my wife liked the feel of it better than what I had stock....u might wanna look @ that too
Ruben3 is offline   Reply With Quote
Old 03-02-2012, 04:44 PM   #12
Califas gt's Avatar
Thank you for all your help I'm gonna start looking at a few more
Old 03-03-2012, 07:36 AM   #13
Csnow99gt's Avatar
I would just go with the ford racing clutch, I have had problems with specs stage 1 and stage 2. I do here nothing but good about ram clutches also!
Csnow99gt is offline   Reply With Quote
Old 03-03-2012, 08:03 AM   #14
jjsg09's Avatar
I had a ford racing clutch in my previous mustang and it was a very stiff clutch. Plus they don't make one for the 02 GT by what I've seen. Is your clutch peddle heavier than stock?
Old 03-03-2012, 09:34 AM   #15
Csnow99gt's Avatar
My clutch is just barely stiffer then stock, its nothing compared to the spec clutches
Old 03-03-2012, 12:00 PM   #16
br10301's Avatar
I have a few friends that have spec clutches.. they are really good I've drive. there cars but they all made the same mistake wen they bought the clutches.. u have to buy the ford racing throw out bearing and ford racing pilot bearing to use with spec clutches they all broke within 3000 miles they replaced them and the clutches are great now might as well skip the head ache
br10301 is offline   Reply With Quote
Old 03-03-2012, 10:54 PM   #17
Csnow99gt's Avatar
Yes but I had a spec clutch disc come completely apart within a few months I blamed it on not being adjusted properly so I bought a second spec and ya your definitely right on the Throwout bearing, cause it didn't last long and shavings of metal got on the clutch disc and rubbed metal to metal, so I went basically stock with ford racing and so far it has worked for me flawlessly
Old 03-04-2012, 06:39 AM   #18
Califas gt's Avatar
Any places that I can buy it at? Another question, do I have to buy the flywheel also or I can use the one it has right now? If I use the stage 1 clutch
Old 03-06-2012, 10:27 PM   #19
br10301's Avatar
I'm pretty sure u can only use a spec clutch with the spec flywheel actually I'm 100% thinking about it but go to American muscle and read the technical. ite at the bottom of the description of the clutch u want I'm pretty sure the stage 1 works best with the steel flywheel
Old 03-07-2012, 03:17 AM   #20
MiGT01's Avatar
Re: New clutch
Same here, bought it last month had it installed and love it vs stock!
01 Black Beauty GT
Eibach pro kit,Tokico shocks/struts,BBK CAI,75mm TB/ Plenum,4.10 FRPP gears,BBK o/r X pipe,Magnaflow Catback,SCT Tuner running 91 Tune,Bama Tunes for Life Member,RAM HD Clutch,BM shifter with MGW "GT" knob,AM smoked Headlights/Sylvania zXe bulbs,VHT smoked tails/3rd brake,Redtop Optima,Mach 1 grille delete,Mach 1 chin spoiler,BULLITT Pedals,20% tint all round,4.6 High Performance Badges
MiGT01 is offline   Reply With Quote
New where do you live thread hottcobra The Bar 795 03-03-2018 01:33 PM
Clutch Goes Chirp! jjsg09 1996-2004 Mustang GT 10 03-07-2012 07:26 AM
New magazine 86droptopgt 1979-1995 Mustang GT 6 03-02-2012 01:22 PM
new fuel pump Robbie94gt 1979-1995 Mustang GT 6 03-01-2012 10:29 AM
How much for a new top??? Plz help!! 98StangKid Pre-2005 V6 Mustang 4 03-01-2012 08:37 AM
03:24 AM
