Oil Pressure Guage Problem - Mustang Evolution
Old 03-03-2012, 12:46 PM   #1
FORDGT14's Avatar
Nyone know if a 99 Gt has a relay or a fuse for the oil pressure guage? It drops to 0 pressure and then jumps up to normal at an idle..i checked my oil and theres plenty in it. Its a brand new oil pump..so i think my guage might be broken? Help please?
FORDGT14 is offline   Reply With Quote
Old 03-03-2012, 12:49 PM   #2
FORDGT14's Avatar
It goes from the low side like this to the high side all the time
Old 03-03-2012, 12:50 PM   #3
FORDGT14's Avatar
And the just drops like in the pic above
Old 03-03-2012, 01:47 PM   #4
Titus Wadicus
svtlx's Avatar
Re: Oil Pressure Guage Problem
prolly sendn unit and not gauge itself..if the pump is new.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-03-2012, 03:27 PM   #5
FORDGT14's Avatar
It was doing the samething with old pump accept it wasnt dropping all the way down to 0. But wheres this "sending unit" located?
Old 03-03-2012, 04:21 PM   #6
Mustang_Madness's Avatar
Should be next to the filter. I had a massive oil leak and that was the problem. Its a small piece.
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 03-03-2012, 06:54 PM   #7
FORDGT14's Avatar
Wait..so the sending unit was leaking all of your oil out? And its by the oil filter right?
Oil sending unit? Taxman 1979-1995 Mustang GT 6 03-07-2012 01:44 PM
Smoking problem with the 5.0 1995boss 1979-1995 Mustang GT 20 03-07-2012 10:13 AM
guage problem fastback67 Classic Mustangs 7 03-02-2012 08:33 PM
Tire problem Jack Israelyan 2011-2014 Mustang GT 12 02-28-2012 11:44 AM
Clutch Pedal Problem 89Saleen141 1979-1995 Mustang GT 11 02-26-2012 08:55 PM
10:37 AM
