Insufficiant flow to my EGR - Mustang Evolution
Old 03-07-2012, 03:57 PM   #1
Chelley's Avatar
Hey guys, I got a code that I'm getting insufficiant flow to my EGR. I've looked at it but nothings loose or leaking. Should I just replace the whole thing as in the three main parts?
Chelley is offline   Reply With Quote
Old 04-06-2012, 09:13 AM   #2
Sonicblue03gt's Avatar
Old post but clean the egr ports on the intake were the egr attaches they will be filled with carbon build up
Sonicblue03gt is offline   Reply With Quote
Old 04-07-2012, 09:22 PM   #3
Chelley's Avatar
I'll do that, thanks dude.
Old 04-08-2012, 03:15 AM   #4
Let me know how it works out
Old 04-08-2012, 09:37 AM   #5
TXzMAN's Avatar
Haha thats the main code ford has lol. After u replace everything make sure u use premium gas in ur car.
TXzMAN is offline   Reply With Quote
Old 04-11-2012, 08:22 PM   #6
LAS97GT's Avatar
Don't use forced air on the valve, disconnect the metal tube at the valve, if possible avoid unscrewing the pipe fitting from the exhaust manifold; if you strip it your in for a nightmare that could put ur Stang down for some time till you find a fitting. Early model, Pre 2005 or so are tough to find EGRs tubes for. If you do however run into trouble, remember that it's a plumbing fitting, not automotive. Pull the Cats before you start to avoid clogging them. Maybe a 10 second start up would help after cleaning to blow manifold clean. Re-assemble. Don't forget the 1 or 2 small tubes that feed other sensor, disconnect them first.
If I had to do it, this is how. I had worse but figured it out when I could not find one, not even junk. 1997 GT vert here.
---------- Post added at 10:22 PM ---------- Previous post was at 10:17 PM ----------
PS: the advice above is in addition other advice on this problem. I am a DIY not pro. Thanks
---Las97GT
Old 04-12-2012, 03:50 AM   #7
t0t4lbl4ck0ut's Avatar
Lol just get the egr delete kit from lethal performance for 30 and save yourself the trouble. It's super simple and can be done in I believe 30 minutes. That's about what it took me. Slap on a tuner and program it out and boom problem solved.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 04-20-2012, 04:35 PM   #8
LAS97GT's Avatar
How' that equate with perf. & fuel use? am a daily driver.
---Las97GT
Old 04-20-2012, 04:43 PM   #9
It's a little better for performance but not anything noticeable and same with fuel. It's just a waste to have the egr. Flowing exhaust into your intake? What would that be any good except in emissions
Starting my tribute car Seattle66 Classic Mustangs 23 04-25-2012 09:24 PM
pics of my 96 efi conversion svtlx 1979-1995 Mustang GT 26 03-09-2012 08:46 AM
Injustice to a Mustang GT. Mustang_Madness 1996-2004 Mustang GT 52 03-09-2012 07:29 AM
Drums to discs conversion.... BigpapaDean Classic Mustangs 2 03-07-2012 01:29 PM
need help with adjusting headlights to RHD traffic AlpineCY 2005-2010 Mustang GT 3 03-07-2012 10:56 AM
04:46 AM
