Sway bar - Mustang Evolution
Old 03-11-2012, 03:25 PM   #1
1lowGT's Avatar
Sway bar
As anyone ever painted their rear sway bar?
Old 03-11-2012, 06:36 PM   #2
LAS97GT's Avatar
Re: Sway bar
Why not? Does it matter?
---Las97GT
Old 03-11-2012, 07:05 PM   #3
runvsofthisbull's Avatar
Re: Sway bar
I painted mine. Since the V6 didn't come with one but the holes were pre-drilled anyway I bought one for $40 and sanded it down first. Primer x 2-3 coats. Then gloss Red x 2-3 coats. Still looks nice to the day and its been about a year and a half.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 03-11-2012, 07:43 PM   #4
1lowGT's Avatar
I'll probably paint me sometime. Will it be okay to take off and put back on?
Old 03-11-2012, 08:33 PM   #5
Re: Sway bar
Off course....as evident the V6 cars do not even come with them. I didn't really feel a difference installing one to tell you the truth. I'm sure it makes a difference during twisty roads and/or road racing, but for daily drivers and even a little racing here and there its fine. You can defintely drive without one without doing any harm. Easiest Install ever too. Two bolts on each side and then it slides up into the control arms = piece of cake.
Old 03-12-2012, 07:13 AM   #6
1lowGT's Avatar
I saw that I'll take mine off this week
Old 03-12-2012, 09:55 AM   #7
Re: Sway bar
you can sometimes see them but not all the time~ just depends on the angle.
Old 03-12-2012, 10:05 AM   #8
1lowGT's Avatar
That's what I was thinking what's the difference between stock sway bar and a steeds sway bar?
Old 03-12-2012, 12:50 PM   #9
Re: Sway bar
the only difference you need to look at is the diameter of the sway bar, no idea what yours is stock but... you probably can find a 96-98 cobra or 01 bullitt sway bar for cheaper if its bigger (and it might be not sure) or you can find a used one.
Old 03-12-2012, 01:59 PM   #10
1lowGT's Avatar
So it's just the diameter
Old 03-12-2012, 03:21 PM   #11
Bigger diameter = less your car will lean
Bbak91 is offline   Reply With Quote
Old 03-12-2012, 05:02 PM   #12
1lowGT's Avatar
Makes sense. I haven't gotten off yet brake line it just right in the way
fox body sway bars 2300turboford 1979-1995 Mustang GT 3 03-02-2012 08:02 PM
Panhard bar 11stangGT 2011-2014 Mustang GT 20 02-12-2012 08:52 AM
Steeda rear bar silver98mustang 1996-2004 Mustang GT 1 12-21-2011 04:23 PM
Panhard bar needed for lowering? mcvicar04 1996-2004 Mustang GT 3 12-20-2011 08:47 AM
Has anyone installed eibach pro plus springs/anti sway bar kit? 2011 mustang gt 2011-2014 Mustang GT 0 11-22-2011 03:44 PM
09:10 PM
