It just died - Mustang Evolution
Old 03-12-2012, 08:20 AM   #1
1lowGT's Avatar
It just died
O I started my car this morning 2003 GT 5 speed. Letting it warm up for 10 mins then went to leave. I got it seen that it was idling low rpms so a gave it so has then pushed in the clutch to back up and it just died. It started right up but the check engine light was on. Any ideas? I though it was the MAF but I haven't messed with it.
Old 03-12-2012, 10:48 AM   #2
jjsg09's Avatar
Sounds like the IAC is clogged. All it took was pushing the throttle and letting of to push anything in it to block airflow. Common problem in these cars.
Old 03-12-2012, 11:08 AM   #3
1lowGT's Avatar
What's the iac
---------- Post added at 10:08 AM ---------- Previous post was at 10:04 AM ----------
Would it be easy to clean it?
Old 03-12-2012, 01:23 PM   #4
Arron's racecar's Avatar
Region: Nevada
IAC is the idle air control. I believe it tis the tube with the black rectangular box on it that comes off your intake. Somebody please correct me if I'm wrong.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 03-12-2012, 05:05 PM   #5
BigB227's Avatar
No your right it's bolted right on the side of your throttle body
BigB227 is offline   Reply With Quote
Old 03-12-2012, 05:08 PM   #6
BigB227's Avatar
Old 03-12-2012, 05:57 PM   #7
1lowGT's Avatar
Well I cleaned it out it just idles low
Old 03-12-2012, 08:40 PM   #8
Region: Nevada
I notice the CEL is still on. did you remove the negative terminal on the battery to clear the light?
Old 03-12-2012, 09:16 PM   #9
1lowGT's Avatar
I was gonna but it still is weird sounding I think I might have the shop look at it before. I take it off
Old 03-12-2012, 09:30 PM   #10
BigB227's Avatar
That's about where my stang idles at also
Old 03-12-2012, 09:41 PM   #11
1lowGT's Avatar
Aight well it also makes a knocking noise it sounds like it coming from the pulleys idk if it's hitting somewhere on the pulleys but I want to just get UDP ANYWAY
Old 03-12-2012, 09:48 PM   #12
BigB227's Avatar
Usually when the pulleys go bad youll hear squeaking from them but knocking could be possible also I guess, and make sure you get UDP that arnt the piggy back style for the crank
Old 03-12-2012, 10:02 PM   #13
1lowGT's Avatar
Yeah steeda a good choice?
Old 03-12-2012, 10:10 PM   #14
DaBluedude's Avatar
Your stock idle should be around 600~650... If you have a tuner you can set it.
2003 Mach 1
Old 03-12-2012, 10:17 PM   #15
BigB227's Avatar
Yes I've heard nothing but great reviews from them and there not the piggyback so your good
Old 03-12-2012, 10:24 PM   #16
1lowGT's Avatar
Well I think
My birthday I might get cams idk
Old 03-12-2012, 11:07 PM   #17
1quick4.6's Avatar
Could be the ignition control module, when they heat up after running for a while it cause ur car to die out, if its bad
1quick4.6 is offline   Reply With Quote
Old 03-13-2012, 07:44 AM   #18
larryjr1's Avatar
Do you have cats on your exhaust? Mine did that and it was knocking and it turned out it was the cats. On one side the stuff inside the cat broke up a little and it sounded like the motor was about to blow up. Mine had low rpm's and no power. Hope this helps.
larryjr1 is offline   Reply With Quote
Old 03-13-2012, 07:47 AM   #19
1lowGT's Avatar
Is it possible to clean that?
Old 03-13-2012, 07:54 AM   #20
larryjr1's Avatar
What I did was took the x pipe off and cut the cats off and gutted them a cheaper way then buying an o/r pipe and I welded it back. So no not really any way to clean. If you can take your exhaust off and shake it you will hear the pieces but you might be able to go under the car and hit it softly with a hammer or rubber mallet and try to see if you hear any rattling.
Old 03-13-2012, 08:40 AM   #21
AgentOrange's Avatar
You need to check your PCV
AgentOrange is offline   Reply With Quote
Old 03-13-2012, 09:27 AM   #22
jjsg09's Avatar
+1
Old 03-13-2012, 09:32 AM   #23
1lowGT's Avatar
Re: It just died
where is that located
Old 03-13-2012, 09:57 AM   #24
Region: Nevada
Are you still able to pass smog?
Old 03-13-2012, 09:59 AM   #25
larryjr1's Avatar
We don't have that here where I live in NC they just look under the car.
Old 03-13-2012, 10:09 AM   #26
Region: Nevada
They don't plug into the obd II port?
Old 03-13-2012, 10:11 AM   #27
larryjr1's Avatar
Well that they do but my light is not on. Donut passes I thought you meant putting a machine behind the cars exhaust.
Old 03-13-2012, 12:17 PM   #28
Should be in the valve cover.. Has a tube sticking out that leads back up to your intake. Take it out, spray it out with carb cleaner or w/e, and blow on each end. Should only flow one way. Most of them have a little rattle too, so don't let it scare you if it sounds like something is loose in there.
Old 03-13-2012, 02:32 PM   #29
Region: Nevada
Ahh ok so the the cats are just there for show got it.
Old 03-13-2012, 03:03 PM   #30
1lowGT's Avatar
Okay I seen that. When I turn Mu car off it sounds like there is still air coming from somewhere then it stops after like 5 seconds
Old 03-13-2012, 04:13 PM   #31
Okay probably isn't the PCV but yank it real quick and inspect it. After that we move on to finding your vacuum leak since thats what out sounds like to me.
Old 03-13-2012, 05:08 PM   #32
1lowGT's Avatar
I took my PVC off and cleaning it right now
Old 03-13-2012, 05:10 PM   #33
Nice, let me know how that works for you and we'll go from there.. A.hissing when you turn the car off CAN be an indicator of a leaking vacuum line. Hope its the PCV..
Old 03-13-2012, 05:11 PM   #34
1lowGT's Avatar
I hope so too It don't leaking for very long just right after I kill it
Old 03-13-2012, 05:13 PM   #35
Hmm. yeah idk bud sometimes these things were tough to diagnose this way.
1 Gotta Have it Green Future Owner..with ???s Gtzzoom 2011-2014 V6 Mustang 57 05-21-2012 09:20 PM
Just got a heavy detail Davey4.0 2005-2010 V6 Mustang 6 03-13-2012 07:32 AM
Buddy of mine bought an 86 gt and it had no air filter. lilrafe87 1979-1995 Mustang GT 6 03-11-2012 06:46 AM
Is it worth the money?? SwatKatz901 1996-2004 Mustang GT 2 03-10-2012 03:40 PM
Just suppose ... What are some mods / changes u would make Regancmmd 2005-2010 Mustang GT 5 03-10-2012 12:42 PM
04:09 PM
