Help Me Spend My Tax Return - Mustang Evolution
Old 03-12-2012, 10:52 AM   #1
jjsg09's Avatar
I got just under $3000 back and it's going to the stang.
I'm looking to do 4.10s 1st then clutch (daily driver) but not sure which one every clutch has good and bad reviews. AM swears by the new Exedy clutch for dd. Next is H&R lowering springs with new shocks struts.
Does this sound good, because I would like to get stage II comp cams after that, I really want to do cams after that and do them myself. I've seen all the vids on YouTube and some write ups and they are not very detailed. So let me know what you think.
---------- Post added at 10:52 AM ---------- Previous post was at 10:46 AM ----------
Or should I just do a Vortech Supercharger and be done.
Old 03-12-2012, 10:58 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
What mods do you already have?
New quick exhaust video
AUGUST 2012 MOTM!!!!
GrabberBlue5.0 is online now   Reply With Quote
Old 03-12-2012, 11:07 AM   #3
jjsg09's Avatar
Oh should have done that. Here it is
1. JLT CAI
2. Steeda underdrive pulleys
3. MAC H-pipe and Cat back
4. Diablo tuner
5. Steeda Shifter
6. I have adj. clutch cable kit
7. Wheels and tires 245 front 315s rear
Old 03-12-2012, 11:16 AM   #4
The Blue Dragon
1. JLT CAI
4. Diablo tuner
5. Steeda Shifter
LT headers
Cams
A bada$$ handling pack(not sure what's offered for your yr model)
Or a blower, that would be awesome. But with only $3000 you're probably better off with the first option. That's what I would do anyways
---------- Post added at 11:16 AM ---------- Previous post was at 11:13 AM ----------
O yea, forgot about the gears. Everyone seems to love 4.10's but personally I love my 3.73's. For a dd 4.10 seems a little much especially with gas prices, but it's your car so do what makes you happy
Old 03-12-2012, 01:00 PM   #5
Titus Wadicus
svtlx's Avatar
Re: Help Me Spend My Tax Return
wut gear is in your car now? if its at least 3.27, i would say get the blower. then other lil stuff if u got anything left.
ur gonna get the most babng for ur buck wit the blower... hands down.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-12-2012, 01:11 PM   #6
jjsg09's Avatar
Yea it's just a stock gear. I'm leaning towards the supercharger but it's hard to find a cheaper one used. Corral forum has them but I can't post or reply to anything it blocks me says I don't have access.
Old 03-12-2012, 01:26 PM   #7
Titus Wadicus
svtlx's Avatar
i dont know wut the stock ratio is for ur car... i thought it was 3.27 for a v8. how much is a new blower?
im not a fan of used blowers. unless u trust who ur gettn it from. even more importantly if it is ur first blower.
are u gonna install it yourself or no?
there r sum cheaper kits on ebay that are new. educate urself on blowers and their components. cause their are sum builders kits available also.
Old 03-12-2012, 01:41 PM   #8
if you dont plan (really plan) to go much above stock power level and you dont drag race the car at the strip an OEM style clutch might be just what you need and can save you some cash.... plus a stiff clutch gets old (but many now have good holding but are not stiff... they just dont feather as much so they are either on/off)
with 3k you can either do one big thing you wouldnt normally get to do or a few little... hard to decide.
Old 03-12-2012, 02:23 PM   #9
jjsg09's Avatar
Yea I do more street driving and would like a lighter clutch. I've had the ford racing king cobra and it wasn't comfortable to drive everyday, it was on my last car. Yea not sure if I just want to do the supercharger or do a lot of little things. My worry with a supercharger is even if I do a lower hp kit I can still spin a rod bearing or throw a rod.
Old 03-12-2012, 02:46 PM   #10
373 gears , Comp Cam, Bilistein struts n shocks, Eibach springs !!!!!!
Don't do the blower unless its a new one man.
SNK3BTE04 is offline   Reply With Quote
Old 03-12-2012, 03:04 PM   #11
Titus Wadicus
svtlx's Avatar
lets say u do a 6lb kit... a properly tuned blower isnt any harder on the motor than if it wasnt there.
most ppl wit a blower, not all.... but most will tell u they wish the blower was their first mod.
im one of them... getn cams, heads and intakes is great... but the blower is most bang for ur buck.imo
i make more hp with stock heads, cam and blower than my counter parts with waaay more money in their motor naturaly aspirated.
they got aluminum this, and forged that, big valves... and i still blow their doors off.
im running a pushrod.... but im sure it would be the same on a 4.6 with 6-8psi. and a decent tune. versus running a set of stage 1 or 2.
again, im not a mod motor expert, its just my opinion.
if someone here is making more power with a standard stroke 4.6 and cams, than with a blower... im sure they will stand up and correct me. cause i can learn a thing or also...lol.
Old 03-12-2012, 06:07 PM   #12
504gt's Avatar
A mustang with a blower will beat me all day, and I got full bolt ons and cams
504gt is offline   Reply With Quote
Plastic Dip my Hood 06Ghost 2005-2010 Mustang GT 19 03-17-2012 06:19 PM
02 transmission help Nate98stang 1996-2004 Mustang GT 28 03-16-2012 12:28 AM
Post brake pad install help silvr002001 1996-2004 Mustang GT 7 03-12-2012 07:26 PM
95gt auto. tranny help today b4 i spend anotha $500 durtyred69 1979-1995 Mustang GT 9 03-11-2012 08:08 PM
Transmission help!!! 89 Foxloco 1979-1995 Mustang GT 12 03-11-2012 06:47 PM
07:30 AM
