Mac prochamber install - Mustang Evolution
Old 03-13-2012, 12:29 PM   #1
BigB227's Avatar
Spent 3 hours trying to get the passenger side bolt off with no luck at all! Any advice on how to get that sucker off would be greatly appreciated
BigB227 is offline   Reply With Quote
Old 03-13-2012, 12:58 PM   #2
jjsg09's Avatar
Ah! The infamous passenger side bolt I hated this bolt. My advice is try swivels and impact he the best grip and hit it a few times and it should knock it loose use pb blaster first. Or you can undo the trans mount put a jack under the transmission and lower it down until you can reach the bolt easily. Take the dive shaft out first. That's all I can tell you.
Old 03-13-2012, 01:45 PM   #3
BigB227's Avatar
Thanks for the advice, yeah I used pb blaster and no use lol
Old 03-13-2012, 09:08 PM   #4
BigB227's Avatar
I got the top passenger bolt off like nothing the only problem I've been having is the bottom one, there's like no room and every extension and swivel I try to get on never connects or when I put torque on it it slips off
Old 03-13-2012, 10:21 PM   #5
jjsg09's Avatar
Yea you don't want to round off that bolt you will be in big trouble then. Try taking off the starter and it will give you more room.
Old 03-13-2012, 10:31 PM   #6
BigB227's Avatar
I'll give that a try when I can, to take off the starter anything special or just unbolt the bottoms bolt I can see while under the car?
Old 03-13-2012, 10:48 PM   #7
jjsg09's Avatar
Should be 3 bolts two on bottom then one on top. U need about 2 feet of extensions to get it but it's not bad. Just go in from the front and on top of the steering rack and if you can look down with a light you can see the bolt.
Old 03-14-2012, 06:02 AM   #8
BigB227's Avatar
Thanks for all your help man I'll try and get to this when I can
MAC ProChamber & V6 Engine robb15033 Pre-2005 V6 Mustang 8 03-24-2012 11:55 PM
99-04 prochamber secomejia Mustang Parts for Sale and Wanted 2 03-13-2012 12:09 AM
Post brake pad install help silvr002001 1996-2004 Mustang GT 7 03-12-2012 06:26 PM
Carpet Install jroth823 Classic Mustangs 3 03-10-2012 08:05 PM
CAI install issue SayNo2Pugs 2005-2010 Mustang GT 8 03-10-2012 01:01 PM
12:42 AM
