Forged pistons & rods with stock crank?? - Mustang Evolution
Old 03-14-2012, 08:47 AM   #1
Jose08's Avatar
Was looking at a set of forged pistons and rods and was wondering how much power I could get out of the setup with the stock crank. I wanna stay around stock for a c/r. I eventually wanna turbo my car so I figured I would ask if it was worth it.
Jose08 is offline   Reply With Quote
Old 03-14-2012, 09:12 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Forged pistons & rods with stock crank??
u dont get xtra horse from that stuff.... it just keeps u from shattering pistons under boost or nitrous... let me re-phrase... reduces your chances of shattering pistons and bending rods..
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-14-2012, 02:07 PM   #3
Region: North Dakota
I'm not sure how much power your stock crank can take before it starts having problems. I would guess that it probably can't handle much over 400 to 425 HP.. I've kinda been wondering myself since I'm not sure what the metallurgy of the stock crank is. Hopefully, someone with some experience will get on here and say something.
K Twisted is offline   Reply With Quote
Old 03-14-2012, 02:27 PM   #4
CodyNelson's Avatar
Region: West Virgina
I have heard that our stock cranks are actually pretty strong and can handle a little over 550hp at the flywheel. Again this is just what i have heard.
Old 03-14-2012, 03:00 PM   #5
Here's a good article to read. It should really help.
Crankshafts:Stock and Performance: Engine Builder
Old 03-14-2012, 03:33 PM   #6
Jose08's Avatar
Well I'm not looking to make power solely on the internals. It's just something I was thinking about. Because I do have plans for a power adder eventually. I have also read that a stock crank was good for over 550 hp. I just wanted some input.
Old 03-14-2012, 03:48 PM   #7
The crank might be good, but it really depends on if it's been abused and what shape the bearings are in. I wouldn't see a problem with it, but if I was gonna do rods and pistons.. since I had the engine apart I would just go all out and to the crank so that i only had to have the engine apart once. Saves on labour.
headers with mid pipe gqsmash 2005-2010 Mustang GT 60 04-07-2012 10:52 PM
MAC ProChamber & V6 Engine robb15033 Pre-2005 V6 Mustang 8 03-24-2012 11:55 PM
2012 v6 Mustang Help.. What to do with it? xBoyDough 2011-2014 V6 Mustang 17 03-16-2012 12:01 PM
Mustangs & Mustangs Show in Florida Kimber727 2005-2010 Mustang GT 4 03-13-2012 08:47 PM
Stock stereo Karisvt Mustang Audio & Video 9 03-13-2012 03:07 PM
02:28 AM
