Do I Have To - Mustang Evolution
Old 03-14-2012, 08:56 AM   #1
jjsg09's Avatar
Do I Have To
M getting ready to swap out my clutch and all the write ups I've read say to drain the trans fluid. Is this a must?
Old 03-14-2012, 09:16 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Do I Have To
if u r doing it at home on a jack... chances are u will spill most of it outa the tail anyway when u r taking it out. so its best to go ahead and drain it before u take it outa the car giving u an opportunity to change it. and a clean area to work in..lol
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-14-2012, 10:39 AM   #3
Vegas97gt's Avatar
Region: Nevada
Yeah or at least don't have your face under it, I got showered on my first clutch swap. Lol
Vegas97gt is offline   Reply With Quote
Old 03-14-2012, 11:28 AM   #4
jjsg09's Avatar
Ok that makes sense to me the write ups didn't say why but I understand now.
Old 03-14-2012, 02:08 PM   #5
clark98gt's Avatar
Re: Do I Have To
you can try using a plug that is made to slide into the end of the transmission. I bought one from harbor freight but any parts store should carry it. The one I have is bright red and it fit my t5 in my old fox better but it does fit into the end of my t45 also. You still will have to be careful though or you definitely will look like you got a blood bath, lol
1998 Gt- current progress
Engine back in car some reassembly required
clark98gt is offline   Reply With Quote
Old 03-14-2012, 06:20 PM   #6
I've used a zip lock bag and a few rubber bands before. Pull driveshaft out and plug the hole with whatever you can find. If it's been a while since you changed it go ahead and change it
Old 03-21-2012, 07:52 PM   #7
LAS97GT's Avatar
Careful, "plug the hole with whatever you can find," I believe that means a clean rag! LOL. I recall 2 dudes doin a tranny in a lift bay next to mine doin the slip slide on tranny oil while trying to remote the shaft to the engine;9 was funny as hell. Yeah, I used a plug.
---Las97GT
What did you do today? Qwik Four Six The Bar 20466 01-14-2017 03:24 PM
Whats all needed to lower my stang ? F4m0usfr34k 2005-2010 Mustang GT 5 03-17-2012 12:35 AM
2012 v6 Mustang Help.. What to do with it? xBoyDough 2011-2014 V6 Mustang 17 03-16-2012 12:01 PM
if you could have ANY stang in the world, which one would it be?? zeltik General Car Discussion 80 03-14-2012 08:46 PM
Starting to come together, got a little cruising in today. Otlaw80 1979-1995 Mustang GT 5 03-14-2012 09:20 AM
09:53 PM
