Wierd idle shakes and engie light - Mustang Evolution
Old 03-14-2012, 09:03 AM   #1
Dylanbest's Avatar
So I just took my 2000 gt out of the garage to clean it up and get ready to go back on the road and the first time I started it up the cai came apart, the tightening straps where loose so I put it back into the sleeve and tightened it up nice and snug, after this happened the check engine light came on and now it's idleing Wierd anybody have this happen? Hopefully there's a quick fix
Dylanbest is offline   Reply With Quote
Old 03-14-2012, 10:23 AM   #2
Arron's racecar's Avatar
Region: Nevada
Remove the neg batt terminal for 1 minute then reattach to clear the DTC s from the computer( you could do this with a tuner or scan tool) start it back up CEL should be off and idling normal. If it comes back on you may have a vacuum problem.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 03-14-2012, 02:10 PM   #3
Dylanbest's Avatar
Thanks I'm gonna give this a try I'll let you know the outcome
Old 03-14-2012, 02:15 PM   #4
Region: Nevada
Alright good luck *fingers crossed*
Old 03-15-2012, 09:37 AM   #5
Dylanbest's Avatar
No more check engine light thanks man hopefully it'll stay off now
Old 03-15-2012, 09:43 AM   #6
Region: Nevada
No problem man.
Old 03-15-2012, 02:57 PM   #7
Dylanbest's Avatar
So the check engine light came back on and now it bogs down pretty noticeably through every gear and 5th really bad between 2000 and 2500 rpm does that sound like the vacum
Old 03-15-2012, 03:36 PM   #8
1lowGT's Avatar
Well I would start cleaning. iac, pvc, and maybe cai.
Old 03-15-2012, 03:45 PM   #9
Region: Nevada
+1 once you've check those then start looking into vac leaks.
Old 03-15-2012, 03:52 PM   #10
Dylanbest's Avatar
Alright I'm gonna pick up some throttle body cleaner and clean everything up and let you know how it goes
Old 03-15-2012, 05:14 PM   #11
1lowGT's Avatar
Good luck!
Old 03-15-2012, 11:45 PM   #12
Region: Nevada
Also forgot to mention if the CEL is on you can take it to your local auto zone or advanced auto parts store and they can read the codes for you.
Old 03-16-2012, 06:42 AM   #13
1lowGT's Avatar
Yeah thatd be the easiest for now if it's on
Old 03-16-2012, 09:10 AM   #14
Dylanbest's Avatar
Thanks guys I'm going into town today, I live in upstate new York and the closest store other than a gas station is 30 miles away so I'm gonna head to autozone buy some throttle body cleaner and ask them if they could hook it up like you said
Old 03-16-2012, 11:41 AM   #15
CodyNelson's Avatar
Region: West Virgina
Re: Wierd idle shakes and engie light
May also want to clean your MAF sensor while your at it. I doubt it is your problem but it never hurts. The MAF sensor should be the cleanest part on your whole car
Old 03-16-2012, 12:46 PM   #16
Dylanbest's Avatar
Is it okay to clean the maf iac, cai and PVC with throttle body cleaner?
Old 03-16-2012, 01:49 PM   #17
1lowGT's Avatar
Where do you get tb cleaner?
Old 03-16-2012, 02:59 PM   #18
Dylanbest's Avatar
Advance auto parts
---------- Post added at 03:59 PM ---------- Previous post was at 03:57 PM ----------
When I was paying the guy behind the counter tried to convince me to get sea foam and not the throttle body cleaner, I didn't get it I'd rather go through each thing and clean it by hand like you guys said, but what do you think about sea foam? Maybe down the line like before i change the oil? Idk if i even wanna use with sea foam to be honest lol
Old 03-16-2012, 06:03 PM   #19
Region: Nevada
I'm not sure about tb cleaner. But I used a light application of brake cleaner on mine. And I mean lightly you don't want the pressure to damage the MAF's fillament. Also you said you went to the auto parts store did you have them use a scanner and read what codes it's throwing?
Old 03-16-2012, 07:05 PM   #20
clark98gt's Avatar
For the maf sensor you may want to use electronic parts cleaner, also sold at advance auto. I bet if they check you cel code it is going to be for the maf sensor if you cai came apart while it was running. When you clean the maf sensor make sure the connection is tight, your car would run like crap if it is not getting a good reading.
1998 Gt- current progress
Engine back in car some reassembly required
clark98gt is offline   Reply With Quote
Old 03-16-2012, 07:21 PM   #21
1lowGT's Avatar
if i went to autozone and got a can of seafoam would i just pour it in my gas tank?
Old 03-16-2012, 08:18 PM   #22
CodyNelson's Avatar
For your MAF sensor you really need to use MAF cleaner. It's only like 5 bucks a can and you will be sure everything is right. Many many people have screwed up their MAF trying to use tb cleaner, carb cleaner or things like that
Old 03-17-2012, 12:26 AM   #23
19foxbodylx93's Avatar
Deadpan is best used in the vacuum line just take a line of and put it in the can about an inch and let it suck it up make sure you are out side when you do this because it does make slot of smoke but it cleans just about everything out
---------- Post added at 12:26 AM ---------- Previous post was at 12:25 AM ----------
Seafoam*
19foxbodylx93 is offline   Reply With Quote
Old 03-17-2012, 07:11 AM   #24
Dylanbest's Avatar
It was pouring rain so I didn't drive the stang and have it hooked up to their handheld computer thing, but I did get all the necessary cleaners and not just tb cleaner maf cleaner also, hopefully it'll clear out all the carbon and nasty stuff. Thanks for all the help guys I'd be so lost on my own. Thank god it's finally Saturday and I have all the proper information on how to clean this stuff out
Old 03-17-2012, 09:42 AM   #25
Dylanbest's Avatar
Would unhooking the negg terminal make me lose my tune? Because I did this to shut the engine light off..
Old 03-17-2012, 12:00 PM   #26
Region: Nevada
Do you have a tune? If you have a tuner you didnt need to remove the neg terminal. You can just clear the codes with the tuner. If you don't have a tune the factory computer is reset when you remove the neg terminal. Thereby clearing any DTC's wich removes the CEL.
Old 03-17-2012, 12:11 PM   #27
Dylanbest's Avatar
I don't have a tuner but the car was tuned to the bolt ons it has when i bought it
Old 03-17-2012, 12:20 PM   #28
Region: Nevada
Ahhh I see. Well to answer your question no you wouldn't lose your tune if the car was tuned its factory tune would have been erased to be replaced by the one the previous owner put on it.
Old 03-18-2012, 12:13 PM   #29
Dylanbest's Avatar
P0304 is the code that showed up, cylinder misfire cylinder #4
Old 03-18-2012, 02:38 PM   #30
Region: Nevada
I would check the spark plugs make sure they are gapped properly an change if necessary. How many miles on the car? Maybe some new coil on plugs? If none of the above then I would have a compression test done( last option of course). Start with the cheapest first and see what your plugs look like.
Old 03-19-2012, 09:01 AM   #31
Dylanbest's Avatar
90000
Old 03-19-2012, 09:23 AM   #32
CrimsonGT's Avatar
Be ultra mega careful with your spark plugs this happened to me because a plug shot itself out the top stripping the threads out with it
Aluminum heads can be a pain in the *** when it comes to the threads that hold in your spark plugs
I had to have the dealership helicoil out new threads in my cylinder #8
500$ cause my pony decided she didn't like a spark plug anymore
Was a sad day
CrimsonGT is offline   Reply With Quote
Old 03-19-2012, 04:30 PM   #33
Dylanbest's Avatar
How would I know if the gap is okay an if it might be my coil
Old 03-19-2012, 04:33 PM   #34
CrimsonGT's Avatar
Get a gapper from auto zone or advance 50 cents and only way to know about the coil is to have it tested or maybe swap coils with a different cylinder and see if the code moves cylinders
These are things I would try or just pay the 95$ diagnostics fee at ford
Old 03-19-2012, 11:12 PM   #35
Region: Nevada
Agreed, the gap should be .052-.056 I believe. If they seem to be gapped properly, I would try to swap the coil and see if the misfire follows as was stated previously. If a faulty coil is to blame I would replace all of them. If one has failed the other 7 won't be far behind.
UMI upper and Lowers captain78 1979-1995 Mustang GT 51 04-01-2012 07:00 PM
Wheels/Tires Possibly for sale and GT OEM Strut Tower avengnd Mustang Parts for Sale and Wanted 7 03-28-2012 08:07 AM
Rev from idle problem CoyoteXII 2011-2014 Mustang GT 11 03-27-2012 07:50 PM
Updated mods pics and installs CrimsonGT 1996-2004 Mustang GT 32 03-17-2012 12:46 PM
Get up and Go Problems SilverBullet12 2011-2014 Mustang GT 7 03-14-2012 04:05 AM
01:43 PM
