Sound from speakers... - Mustang Evolution
Old 03-15-2012, 02:05 AM   #1
Mustang_Madness's Avatar
I hear a really high pitch tone coming from my rear speakers. Theyre hooked up to an amp the tone follows the sound of the car. If i rev, it gets higher, when it idles low, the sound gets low and stays low. My speaker wire is pretty close to the power wire from the battery, so im thinking its just picking up that sound from the engine compartment that way. Could i be right? Yes i ran the power wire on one side of the car and rca on the other, but theres a little jumble of extra wire on each that are mixed around...I dont usually ask about audio stuff but never dealt with this before! Or even heard of it!
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 03-15-2012, 03:37 AM   #2
dmax8709's Avatar
Yes ur speaker wire can pick that up but also can be ur alternator getting weak. Check ur voltage coming to the amp. If it has a low voltage can also cause it. Do u have an inline converter for ur rca ? Or is it coming straight off the back of the radio?
dmax8709 is offline   Reply With Quote
Old 03-15-2012, 08:34 AM   #3
BigB227's Avatar
My speakers would do the same thing yours are doing and come to find out my alternator was dying on me. Might want to check that out
BigB227 is offline   Reply With Quote
Old 03-15-2012, 11:10 AM   #4
Re: Sound from speakers...
Its coming straight off the deck. have RCAs for my subs, my rear speakers and my fronts. i might need to swap the Alt... and probably upgrade it. I'm running a lot off my battery.. but I also know it could be from the power wire and rcas being that close to each other, so I'm going to actually mount my amp and clear up the wiring. Thanks though!
Old 03-15-2012, 11:12 AM   #5
Snapple750's Avatar
Make sure your positive power cable or your REM isn't crossing your RCAs or speaker wire
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 03-15-2012, 11:19 AM   #6
01mineralgreyv8's Avatar
I have the same setup and same problem. I was thinking maybe a capacitor would help the situation?
01mineralgreyv8 is offline   Reply With Quote
Old 03-15-2012, 01:10 PM   #7
dmax8709's Avatar
Check ur voltage also
Old 03-15-2012, 02:50 PM   #8
I know a cap wouldn't help that. Thats meant for constant power and i don't need it yet. however it would be nice. hah i am going to rerun my wires back and probably use that electromagnet field resistor RCA cable stuff for it. It literally could be anything i suppose.. although i think that the mess of wires are a contributor being as i haven't mounted the amps yet...
Old 03-15-2012, 02:53 PM   #9
dmax8709's Avatar
U check ur voltage yet? U need at least 12v Iraq u could get feedback from the strain of the amp
Old 03-16-2012, 02:00 AM   #10
ohhh no i haven't.. Im gonna check that out. Im going to get a bigger alt. so ill be able to push more without a new battery...
Old 03-16-2012, 06:49 AM   #11
KATO's Avatar
A CAP would eliminate you needing to buy a higher Alternator.
07 GT. SCT: CUSTOM TUNE by "MUSTANG SPECIALTIES". LMR: GEN2 2010 STYLE HEADLIGHTS, RAXIOM: 2010 SMOKED COYOTE TAIL LIGHTS, WHEELS: STAGGERED WHL 22X8.5F-22X10R.
Alabama anybody from Bama on here? dmax8709 Regional Mustang Discussion 9 04-19-2012 03:17 PM
post clips of your exhaust sound 1quick4.6 Pictures and Videos 37 04-02-2012 11:34 PM
Rev from idle problem CoyoteXII 2011-2014 Mustang GT 11 03-27-2012 08:50 PM
New from Florida Zeph Fire New Member Introductions & Greetings 18 03-19-2012 10:07 PM
New noise from the rear 2002VertGT 1996-2004 Mustang GT 7 03-16-2012 09:17 PM
07:09 AM
