Need help! My stang has a miss! - Mustang Evolution
Old 03-15-2012, 11:41 AM   #1
Fatboy scott's Avatar
Let me start from the beginning. I have a 2002 gt vert. Its a 4.6 Windsor ( I know it should be a romeo but apparently the PO did a swap.) Yesterday while standing over the engine had just put a new coolant fan resistor on was watching to make sure the fan was going to come on as should, she started missing. No noise or anything just went into a dead miss on #1 cylinder. First thought coil. I had just replaced plugs and coils about a month ago. Figured got a bad one. So I swapped a couple of coils around to see if the miss moved with the coil. It didn't #1 still dead. Went and bought a new plug and dropped in. No change. Next thought injector. Swapped a couple around. No change. Then did the dreaded compression test. Range from 190 to 220. Dead cylinder being the strongest! Lol! What am I missing?! Im at a loss. Any help will be greatly appreciated!
Fatboy scott is offline   Reply With Quote
Old 03-15-2012, 12:20 PM   #2
stampde's Avatar
Re: Need help! My stang has a miss!
had a sim prob once ,IT ENDED UP BEING One of the wire leads to the coil had a break in it .....
2011 GT Auto
Old 03-15-2012, 12:40 PM   #3
Is there a way to test it without tracing the wires back?
Old 03-15-2012, 12:45 PM   #4
jwhayne0001's Avatar
Is your injector pulsing? Hook a noid like up to the connector or in a pinch get a 194 license plate bulb and straighten the wires in the bottom out and put it in the plug for the injector
---------- Post added at 12:45 PM ---------- Previous post was at 12:44 PM ----------
Should flash frequently while running
jwhayne0001 is offline   Reply With Quote
Old 03-15-2012, 01:39 PM   #5
Thanks I'll try that tonight!
---------- Post added at 01:38 PM ---------- Previous post was at 01:18 PM ----------
Will that work on the coil plug to?
---------- Post added at 01:39 PM ---------- Previous post was at 01:38 PM ----------
And if I use a tester on the coil what kind of voltage should I see?
Old 03-15-2012, 02:29 PM   #6
Never tried the coil plug, wouldn't recommend the tester on a coil, put a plug in the end of the numb 1 wire and ground it to a exhaust manifold bolt
Old 03-15-2012, 05:46 PM   #7
LAS97GT's Avatar
Hi folks,
When your done with this, look me up. I have a tick or two I need to get rid of but my skill is lacking more than my enthuaism to correct the problem. No deep pockets here either. I'll stay posted on the results here too. Thanks.
---Las97GT
Old 03-20-2012, 06:24 PM   #8
After going through a wiring harness, it was a corroded plug at the PCM. Guess I should have checked there first and now I wouldn't be going through so much tape and wire harness!
02 transmission help Nate98stang 1996-2004 Mustang GT 28 03-15-2012 11:28 PM
American Muscle Vinyl Stripe Help Darenc86 2011-2014 Mustang GT 12 03-15-2012 10:24 AM
if you could have ANY stang in the world, which one would it be?? zeltik General Car Discussion 80 03-14-2012 08:46 PM
need some tire ideas 2300turboford Mustang Wheels & Tires 0 03-14-2012 08:35 PM
96 running bad need a solution Hdavis013 Pre-2005 V6 Mustang 0 03-14-2012 07:52 PM
04:04 AM
