Brake pedal shuttering - Mustang Evolution
Old 03-15-2012, 07:37 PM   #1
3Maine's Avatar
This last week, on and off, my break pedal has been shuttering/turbulent feeling and as I finally complete my stop 2-3 seconds after it dissipates. I've done a moderate amount of searching but I am not finding a related cause and effect. Anyone know about this and would like to give advice? Thanks.
2003 gt
T
3Maine is offline   Reply With Quote
Old 03-15-2012, 08:07 PM   #2
meano1's Avatar
It continues to shutter after the stop?
1998 Mustang Gt, MSD coils, Ford Racing lowering springs, KYB shocks, caster camber plates, Flow Tech exhaust, K&N CAI, auto trans with shift kit, Jet Performance module, full length sub frame connectors, Redline Tuning hood struts. Oh yea, forgot to mention the Plasti Dip stripes.
meano1 is offline   Reply With Quote
Old 03-15-2012, 08:11 PM   #3
3Maine's Avatar
No it stops after the stop about 2 seconds after and after I lift my food off the pedal a moment but I think it stops even if I don't lift my foot. I think maybe a rotor is bad?
Old 03-15-2012, 08:20 PM   #4
meano1's Avatar
Sounds like a warped rotor.
---------- Post added at 08:20 PM ---------- Previous post was at 08:18 PM ----------
How many miles on the front rotors? Have they been turned that you know of?
Old 03-15-2012, 08:28 PM   #5
3Maine's Avatar
Ok, thanks. Unfortunately I don't know about the rotor history, the car is still a couple months new to me. Already costing me a clutch disk replacement. I'm a new automotive student (strictly theory at the moment) so I'm toying with finally trying to get my hands dirty.
Would this be a reasonable project for a first timer?
Thanks again
Old 03-15-2012, 08:35 PM   #6
meano1's Avatar
Depending in how warped they are they may be able to turn them. However, if you have to replace them they are pretty simple to do. I would suggest changing brake pads for a fresh rotor or rotors. Just my opinion. All you need to do is take off calipers and once that is off the rotor just slides off.
---------- Post added at 08:35 PM ---------- Previous post was at 08:32 PM ----------
Just don't remove any brake lines or you will have to bleed the system and that sucks. Also, you will probably need to open the brake resevoir because once you compress the caliper for the fresh pads, depending on fluid level, you may lose some fluid so get some rags ready to soak up any spill over.
Old 03-15-2012, 08:38 PM   #7
3Maine's Avatar
Ok thanks a lot. I'll give it a try if they do need replacing. Maybe for starters I can get a brake shop to check them cheaply.
Old 03-15-2012, 08:45 PM   #8
meano1's Avatar
Yea, a brake shop can set them up and put an indicator on them and check for runout. They shouldn't charge much to check your rotors. You may find out they just need turned. I can get mine turned for 8 bucks a piece. Better than buying new. Good luck to you.
Post brake pad install help silvr002001 1996-2004 Mustang GT 7 03-12-2012 06:26 PM
Brake pads Vegas97gt 1996-2004 Mustang GT 0 03-12-2012 12:17 AM
Custom Third Brake Light explicitrock Pre-2005 V6 Mustang 3 03-10-2012 12:36 PM
Brake Bleeding Labrat 2005-2010 Mustang GT 22 03-09-2012 08:23 PM
Help brake problems!!!!! mcvicar04 1996-2004 Mustang GT 2 03-09-2012 08:16 AM
09:56 AM
