New Brakes; now mushy? - Mustang Evolution
Old 03-18-2012, 10:47 AM   #1
ColeJohnson's Avatar
Just installed new ceramic brake pads and it was a pretty snug fit. Now my brake pedal feels mushy like I have no brake pressure. When I heavily apply brakes it doesn't pull to either side, I have no pinches in the lines and when I checked brake fluid it seemed full. Maybe the brakes just feel different because of how new they are? It's just a little unnerving..
2016 Comp Orange GT (current)
Old 03-18-2012, 11:34 AM   #2
TaylorF25's Avatar
Did you bleed everything good?
TaylorF25 is offline   Reply With Quote
Old 03-18-2012, 11:42 AM   #3
This happened to me. Make sure you bleed all the breaks and the reservoir where you pour in the break fluid I think there is a place to let that air out. That's what I did and it worked.
04vertgt is offline   Reply With Quote
Old 03-18-2012, 12:03 PM   #4
DaBluedude's Avatar
Sounds like you need to break the pads in. 60-20 mph, 8 times. Drive around for a few mins, then do it again. Some pads need to have the bonding agents cooked out of them. If your smelling the brakes during break in your doing it right. Avoid stopping with your foot in the brakes. That's how rotors warp.
2003 Mach 1
Old 03-18-2012, 12:09 PM   #5
Depending on the pads it may take more heat. My hawk hps pads took 6 100 - 20 stops to really get them bedded
Old 03-18-2012, 12:27 PM   #6
Re: New Brakes; now mushy?
I just drove around for a good 45 mins running some 55-25 stops and everything is all good now. Getting better each stop. :]
Old 03-18-2012, 12:35 PM   #7
DaBluedude's Avatar
Get them good and hot. When they start to smell there just staying to break in. you want to very ask of your break in done fast or they will never break in fully.
2003 Mach 1
Old 03-18-2012, 09:54 PM   #8
Region: North Dakota
Um... what??
K Twisted is offline   Reply With Quote
Old 03-18-2012, 10:33 PM   #9
DaBluedude's Avatar
Originally Posted by K Twisted
Um... what??
The binding agents in the pads need to be cooked out our the pads end up "green". It can cause premature pad degradation, uneven wear on the rotor. If a pad is half broken in the binding agents deeper in the pad don't cook out and you end up with squeaky brakes and pads that only work properly at the edges. Break them in hard.
2003 Mach 1
Old 03-18-2012, 11:28 PM   #10
Mile high JDF's Avatar
But only on performance pads that recommend it
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-21-2012, 11:58 PM   #11
Bleeding brakes is a two man job one man pumps the brakes. Several times then holds the pedal down while the other slightly opens the valve at the back of you caliper if only fluid comes out your good but usually you'll hear a bubbly sound and air nd fluid will squirt out you then close it. Then he let's off the brakes repeat until satisfied and owe bout the bonding agent I usually get some very fine sandpaper and sand a very little off I find it helps
Crunch9876 is offline   Reply With Quote
New headlights or rims? Mustang 4pt0 2005-2010 Mustang GT 38 03-29-2012 08:41 PM
New AM Wheels and tires ... stampde 2005-2010 V6 Mustang 29 03-19-2012 04:44 AM
New SC pulley w/ Tuner SNK3BTE04 SVT Mustang 9 03-18-2012 10:27 AM
New 20" stealth black FR500's installed! Benzo 2011-2014 Mustang GT 34 03-18-2012 08:52 AM
New Vossen Wheels Msoler 2011-2014 Mustang GT 21 03-17-2012 09:47 PM
09:22 AM
