Headers!? - Mustang Evolution
Old 03-18-2012, 07:33 PM   #1
Jord05's Avatar
Headers!?
So I have a 2000 mustang gt and was just wondering if any one has a step by step guide to instant long tube headers thanks
Jord05 is offline   Reply With Quote
Old 03-18-2012, 07:55 PM   #2
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Headers!?
I got this from BBK's web site hopefully this helps.
Step 1 Raise front of vehicle on safety ramps or jackstands to allow clearance for long header installation, if available a vehicle hoist would be highly recommended.
Step 2 Disconnect negative battery terminal, make sure vehicle is securely raised with safety chocks in place, etc.
CAUTION
Use extreme caution when working under vehicle.
Always use a secondary safety jacking device
Step 3 Working from under the vehicle, first remove the exhaust H-pipe by disconnecting at the exhaust manifolds, mufflers pipes and also be sure to unplug all 4 oxygen sensors.
Step 4 Working from under the hood, disconnect the emissions tubes from both exhaust manifolds, then unbolt and remove the strut tower brace to allow for clearance while lifting the engine on the passenger side.
Step 5 Working from under the vehicle unbolt and remove the starter and then the passenger side exhaust manifold.
Step 6 Unbolt the steering shaft pinch bolt (located on the driver’s side just above the steering rack at the rubber coupler or “rag joint”). Pull the steering shaft up off of the splines on the steering rack and swing the shaft to the driver’s side of the engine compartment. Unbolt and remove the driver’s side exhaust manifold.
Step 7 To facilitate installation of the header on the passenger side, first remove the engine crossmember support bar (G-load brace), then remove the motor mount nut on the passenger side to allow the motor to be jacked up approximately 3-4 inches.
Step 8 Using a floorjack and a piece of wood placed on the oil pan bolt rail, slowly raise the motor enough to allow the header to be slid in place. Place another piece of wood as a safety block between the motor mount and engine crossmember until the header is installed completely with supplied gasket/hardware. The starter motor must also be installed simultaneously with the passenger side header due to tight clearances.
Step 9 Lower the motor and reinstall the motor mount nut, then simply slide the driver’s side header into place and install with supplied gasket/hardware.
Step 10 Reinstall the steering shaft to steering rack and torque the bolt to factory specifications, then reinstall the crossmember support bar. At this point check for any interference or clearance problems between the driver’s
side header and steering shaft.
Step 11 Install the new BBK H-pipe assembly using the supplied hardware, first tighten the flanges at the header
collectors, then tighten at the muffler pipes.
NOTE
Install the oxygen sensors to the H-pipe before
fitting to the vehicle to ease installation
Step 12 From under the hood simply reconnect the emissions tubes to the appropriate fittings on the headers and reinstall
the strut tower brace.
Step 13 Safely lower the vehicle and reconnect the negative terminal to the battery, start your vehicle and check for leaks
or loose hardware.
CAUTION
Make sure the steering shaft bolt has been tightened!
SaturnMan8227 is offline   Reply With Quote
Old 03-18-2012, 09:43 PM   #3
Jord05's Avatar
CAUTION
NOTE
or loose hardware.
CAUTION
Thanks man now I just need the headers to come in
Old 03-18-2012, 11:13 PM   #4
Re: Headers!?
you're welcome. let us know how the install went. good luck.
Old 03-18-2012, 11:29 PM   #5
Jord05's Avatar
I hope it will go o I don't have much room in my garage to work on her
Old 03-18-2012, 11:39 PM   #6
Re: Headers!?
what brand headers and x-pipe/h-pipe did you purchase?
Old 03-19-2012, 12:01 AM   #7
Jord05's Avatar
Bbk header and I'm getting a x pipe built here from a shop
Old 03-19-2012, 01:03 AM   #8
Re: Headers!?
ok cool but it would be better if you got the BBK X-Pipe / H-Pipe as these are made to go with the BBK LT Headers. you will have less of head ache when matching everything up.
Old 03-19-2012, 09:24 AM   #9
Jord05's Avatar
Ya very true and in your opinion what would be better x pipe or h and have you heard anything good with the bbk ones?
Old 03-19-2012, 09:31 AM   #10
1lowGT's Avatar
X pipe will give you a more raspy NASCAR sound H pipe will give you a more deep sounding growl.
Old 03-19-2012, 10:44 AM   #11
Jord05's Avatar
Hmm gives me something to think about
Old 03-19-2012, 10:56 AM   #12
1lowGT's Avatar
I'm gonna run an h pipe
Old 03-19-2012, 06:52 PM   #13
Re: Headers!?
I ran with an X-pipe with my BBK headers on my V6 for years. I loved the raspyness the car made. I currently run an X-pipe on my GT again I love that raspyness.
Headers for 2012 V6 USAF2754 2011-2014 V6 Mustang 46 04-29-2014 12:22 PM
LT Headers DannyDoright 2011-2014 V6 Mustang 15 03-19-2012 07:16 AM
BBK Chrome Tuned Length Shorty Headers 2004GT 1996-2004 Mustang GT 8 03-18-2012 11:59 PM
SLP headers are in!!! SkoSter06 2011-2014 Mustang GT 28 03-18-2012 06:34 PM
Headers AmericanMetal 1996-2004 Mustang GT 25 03-16-2012 11:38 AM
11:33 AM
