Pictures of my intake and gaskets. - Mustang Evolution
Old 03-19-2012, 04:18 PM   #1
Mustang_Madness's Avatar
The gaskets are extremely dirty and the intake itself wasnt sealed on i think because of that. Since its off already, what should i do to clean it and check it an all that? I barely have any money so.. Yea. I found a TON of twigs and leaves and crap in the well under my intake manifold and i dont know why! Help!
ID:	44270   Click image for larger version
ID:	44272   Click image for larger version
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 03-19-2012, 07:48 PM   #2
Common guys!!
Old 03-19-2012, 08:35 PM   #3
Region: North Dakota
Re: Pictures of my intake and gaskets.
Replace all your gaskets when you re-install. I recommend going with Felpro gaskets when you buy them. When cleaning, make sure you don't get any debris down in your engine. You shouldn't really need to clean the inside of your manifold, but make sure that the gasket surfaces are clean and smooth. If you can, block your intake ports, and make sure you blow off all the debris.
K Twisted is offline   Reply With Quote
Old 03-19-2012, 08:56 PM   #4
Dude you are the only one that really answers what i need answered so thank you. I really cleaned the surfaces and the gaskets, because i cant spend alot of money right now, but ill look to see whats out there. I made sure nothing fell in! What would happen if something did?
Old 03-19-2012, 09:51 PM   #5
Your welcome bro. Anything I can do to help. I'll answer whatever I can to the best of my knowledge, and some things I get curious about as well, I'll research and share. I know how it can be a problem with not having a lot of money. Just make sure you get a good valve sealant when you're ready to put your manifold and gaskets back on. If something fell in your engine, it's really going to depend on what it was. If you got some dust in there, it's not good, but it's not horrible. Sand is bad. Leaves and twigs i wouldn't even bother trying to put the manifold back on. I'd just disassemble the top of the engine and thoroughly clean everything. The gap that may have been from a bad gasket between your intake manny and head wouldn't have been large enough to let "debris" in, but it could have gotten some dust. Your oil would more than likely catch it and bind with it and flow it to the oil filter. But if it's sand or anything larger, I'd consider taking the heads off and cleaning it all. There is a chance that the intake valve could be closed and the debris is sitting behind the valve and didn't make it down into the combustion chamber. At that point you could try to vacuum whatever fell down in there out, and then blow it clean with air, but it's risky and you would have to know for certain that the valve was closed all the way. If you got some grease, or grime, it's not as bad as sand.. but it's not going to blow up your engine. Just be really careful and you shouldn't have any problems.
Old 03-19-2012, 11:48 PM   #6
Alright. I dont think i let anything in there but i want to take the heads off just to clean them out to. I probably got a little dirt in there because i didnt cover them up but i put a vacuum in each hole so that might have gotten it!
Old 03-20-2012, 12:31 AM   #7
Vegas97gt's Avatar
Region: Nevada
How difficult was pulling the intake manifold off because my gaskets look pretty tired and are a little leaky it would be for my daily driver on a Saturday about how long did it take you?
Vegas97gt is offline   Reply With Quote
Old 03-20-2012, 01:16 AM   #8
Taking them off is no easy task... Requires a lot of man hours and you really need to know what you're doing. Just a warning.
Old 03-20-2012, 09:36 AM   #9
It wasn't Bad because I've done it before on other Fords and my own, But you need to know whats up with your engine and where everything is. I took off my throttle body, Cold Air Intake, Fuel Rail, and Alternator, and i pulled the thing right out. as long as you dont forget any connections or force anything to come off, you'll do fine. I Really want to take the heads off too and clean those because while the intakes off, i have more room, But i can't seem to get a wrench or anything into a few bolts because the metal in the engine compartments in the way. i probably have a few inches between the bolt and metal wall. so ill have to figure that out.. Oh and I got plastic bags and labeled where the bolts came from. That way everything gets back in order.
---------- Post added at 09:36 AM ---------- Previous post was at 09:34 AM ----------
Wouldn't i just unbolt the million bolts they have in it?
Old 03-20-2012, 04:19 PM   #10
[/COLOR]
Wouldn't i just unbolt the million bolts they have in it?[/QUOTE]
Well yeah.. but putting it all back together is the problem. Taking it apart is pretty messy as well.. Just remember to torque everything back to the proper specs and in the right order.. Don't wanna warp a head...
Old 03-20-2012, 04:23 PM   #11
Ohh ok. Well is it worth it?
Old 03-20-2012, 07:16 PM   #12
I wouldn't.. especially if you know that you didn't drop anything into the engine.
Old 03-20-2012, 08:56 PM   #13
imhooked's Avatar
hey guys,
was wondering, if any of you know...
1. is there a way to remove the wire harness clips (without ruining them). they are the 3 pronged that attach the harnesses to the valve cover studs. i've been working on cleaning my engine, and thinkin' about doing the plugs and possibly upgraded coils(ngk iridium and accel), and would like to get them off without breaking the tabs. NOTE: i tried doing it myself with two small screwdrivers, and it's a daunting task for 1 person with 2 hands (and 3 tabs!) and broke the first one!
2. also, i want to try and lower op temp of cooling system, and is changing to 180 degree thermostat enuff, should i just add some RP ice, or just run straight water(or NO thermostat) for the summer?
thanks!
joe
imhooked is offline   Reply With Quote
Old 03-20-2012, 09:45 PM   #14
Originally Posted by imhooked
hey guys,
thanks!
joe
Are you talkin about the spark plug wire holders that are on the heads?
Old 03-20-2012, 11:02 PM   #15
Vegas97gt's Avatar
Region: Nevada
hey guys,
thanks!
joe
I'm not a hundred percent sure it's the right thing but most likely you'll just need a trim removal tool I use it every day doing body work taking stuff apart I will post up a picture at work tommorrow you can get them from harbor freight or sears for like $10-15 post a picture of the clips you have to take off if you can.
Old 03-21-2012, 06:35 AM   #16
imhooked's Avatar
yes, the harnesses house spark plug and injector wiring
Old 03-21-2012, 10:16 AM   #17
Thats easy! I had a hard time for about 5 min. But figured it out! But just to open the tops, the top section lifts up! You need to pull out the clip from the hook on the side and itll just lift right up! Want me to show you a picture? Im not sure how to take those clips completely off the heads though!
Old 03-21-2012, 11:24 AM   #18
What about if coolant fell in the hole.
Old 03-21-2012, 12:46 PM   #19
imhooked's Avatar
not sure but yours sound different... i have an 04 gt. i'll take a closer look today, but think a closeup pic of 1 of the clips 'opened' might be helpful
yours sounds more like the clips i had on my old tbird. i'd send you a pic, but my phone and 'puter don't like each other!
thx-
joe
Old 03-21-2012, 04:33 PM   #20
It's not a problem as long as it wasn't a huge amount. It'll burn off and smoke a bit when your engine runs, but will clear out soon after.
Old 03-22-2012, 05:32 PM   #21
imhooked's Avatar
hey m_m,
were you able to snap a pic of the wire harness clips... i'm curious to see if they are same/different than the ones on my '04
thx again-
joe
Old 03-22-2012, 05:40 PM   #22
Originally Posted by imhooked View Post
hey m_m,
thx again-
joe
I will get a picture up in a few minutes alright?
Old 03-22-2012, 05:44 PM   #23
imhooked's Avatar
thx man-
Old 03-22-2012, 06:40 PM   #24
Sorry to make you wait! Here they are!
ID:	44652   Click image for larger version
Old 03-22-2012, 09:08 PM   #25
imhooked's Avatar
yeah dude, that's what i was thinking! what year is your car!
that's totally different than my 04 gt which is a 2v SOHC engine with COP's.
those are like on my old t'bird, and yes they just flip open.
my harnesses have individual "tri-clips", which lock onto the valve cover studs
Old 03-22-2012, 09:15 PM   #26
its a 96 mustang with a 98 V8 in it! Its a 4.6 SOHC as well! but you have the COPs and i have the coil packs with 4 terminals each. Ive never seen the tri clip ones!?
Old 03-22-2012, 09:21 PM   #27
imhooked's Avatar
no sweat man... i'll prob just ask the guys at the dealership. i swear these things are made NOT to be removed, or there must be a special tool!
yeah yours is just like my old tbird for sure!
pics of every ones stang svo Pictures and Videos 268 04-29-2012 10:03 AM
I Got Myself and 9 other Mustangs pulled over... Beav General Mustang Discussion 19 03-25-2012 04:51 PM
New member of the Forced Induction club!!! CodyNelson 1996-2004 Mustang GT 31 03-19-2012 06:45 PM
Whats the difference in the 5.0gt and the boss Mustangpower5.0 2011-2014 Mustang GT 5 03-19-2012 03:37 PM
Update on my car Gobabygo67 1996-2004 Mustang GT 0 03-19-2012 02:27 PM
04:58 AM
