Bad shock thingy.... - Mustang Evolution
Old 03-20-2012, 10:29 AM   #1
MustangGT02's Avatar
Ok so we went into the shop that is putting my gears in and saw a shock like thing covered in oil, I think this is what makes my car have weird noises after I floor it. Heres a pic, Anyone know what it is and does?
MustangGT02 is offline   Reply With Quote
Old 03-20-2012, 11:25 AM   #2
CodyNelson's Avatar
Region: West Virgina
Re: Bad shock thingy....
That is your quad shock. Someone correct me if im wrong, but i believe it just helps with rear axle torque/twisting when you hammer down on it.
Old 03-20-2012, 11:29 AM   #3
Mathew r Wright's Avatar
Yep Cody's right just pick em up at auto store there not bad at all... Or if you like online shopping then late model resto has em for pretty cheap Im sure...
Mathew r Wright is offline   Reply With Quote
Old 03-20-2012, 11:44 AM   #4
CodyNelson's Avatar
AM has them as well. Like Mathew said, they arent expensive so Im sure anywhere you look it wont be too bad
Old 03-20-2012, 11:46 AM   #5
quad shocks are a bandaid for wheel hop, you can remove them or just buy a replacment
Old 03-20-2012, 11:53 AM   #6
Ok thanks for the help guys, I will pick some up when I get the money.
Old 03-20-2012, 12:59 PM   #7
you can run to a pull a part junk yard and find some in good shape and yank them.
Old 03-21-2012, 08:20 AM   #8
imhooked's Avatar
so i guess i don't really need to replace mine?!
i knew they were called quad shocks, but was not sure wut they really did, and if i was going to replace my rear shocks if i should be doing those too
thanks for bringing it up!
imhooked is offline   Reply With Quote
Old 03-21-2012, 09:51 AM   #9
when the rear end (with all its rubber) gets wheel hop the quad shocks help limit it~ they really dont do much else. Many remove them for wider tires etc. Might as well keep them unless you are planning on other upgrades.
bad headlights, even worse person angelofrat42 2005-2010 V6 Mustang 7 04-08-2012 01:16 AM
96 running bad need a solution Hdavis013 Pre-2005 V6 Mustang 0 03-14-2012 08:52 PM
running pretty bad 82stang224 1979-1995 Mustang GT 10 02-27-2012 10:38 PM
Really bad news. GMSPNKR 2005-2010 Mustang GT 23 02-26-2012 11:52 PM
A little bad news choppa5307 1979-1995 Mustang GT 4 02-21-2012 04:44 PM
04:27 PM
