engine swap 01 gt - Mustang Evolution
Old 12-14-2007, 06:03 PM   #1
engine swap 01 gt
spun a rod on my 01 was wondering if an 04 4.6 will bolt right up
stangdroptop01 is offline   Reply With Quote
Old 12-14-2007, 07:01 PM   #2
MonteCitan's Avatar
Re: engine swap 01 gt
The only thing different with the 04s over the 01 was the trans, if manual.. auto was the same, as far as I know, the more knowledgeable will have some input shortly, I'm sure...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-15-2007, 02:54 PM   #3
thanks for the input might just change everytihng out
Old 12-15-2007, 05:15 PM   #4
MonteCitan's Avatar
After looking up a bit more, everything's interchangeable, but I'm still not sure on clutch/flywheel if manual... It wouldn't be hard to swap it over! Just be sure the new motor has a pilot bearing in the block, if it came out of an automatic and you're putting it into a manual car --
flex plate/auto are the same... everything else should be a direct swap
Old 12-15-2007, 11:32 PM   #5
rocknbronco's Avatar
In 01 didnt they move to the new tranny? So it should be the same right?
rocknbronco is offline   Reply With Quote
Old 12-17-2007, 10:17 AM   #6
They changed trannys mid way through 01
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 12-18-2007, 01:42 PM   #7
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
The trans will work also you just have to make some "adjustments" there is nothing that will not swap over. I put a 01 motor in my 96 and only problem i had was a wiring harness issue.The wiring problem is the 96 used two different coolant sensors and the 99-04 used 1.
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 12-20-2007, 06:21 AM   #8
KrazyPony's Avatar
better make sure the 01 computer will work with the new motor as well, not sure myself just a thought?
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 12-21-2007, 10:39 AM   #9
I am using a 96 computer with a 01 motor.
Old 04-08-2008, 09:58 PM   #10
Region: Iowa
the computers are different your right that is the only thing
stockgt is offline   Reply With Quote
Old 04-17-2008, 07:05 AM   #11
With the swap the only major issue you will have is if you decide to use the coil on plug setup.You have to have the 01 computer and a tune plus tons of wiring.I used the stock coil packs with the 96 ecu.It ran fine also you will need the 96 IAC.
Old 04-17-2008, 02:45 PM   #12
I need to swap my engine from a '01 GT. I have no idea where to go for this kind of work. I don't know nothing about parts or repairs so most terminology is another language to me.
Can you please tell me where would you go (or how to search) for a trustworthy place to do an engine swap?
beaglis is offline   Reply With Quote
Old 04-17-2008, 03:06 PM   #13
Well it isn't hard to do but if you have never pulled a motor or anything i would just pay someone.Maybe you can find someone local who will just help you do it and make sure you dont make any mistakes.
Engine swap 3.8L to 4.6L NEED HELP!!!! PonDog15 Pre-2005 V6 Mustang 23 06-29-2010 08:43 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Want to swap my v6 engine for a v8 Justin-Heath Pre-2005 V6 Mustang 10 12-08-2006 03:56 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
engine swap evilweirdo42 Pre-2005 V6 Mustang 26 11-23-2004 07:21 PM
08:16 PM
