Any COP suggestions? - Mustang Evolution
Old 03-22-2012, 06:44 PM   #1
Arron's racecar's Avatar
Region: Nevada
I'm looking to get a new set of COPs and im wondering what brand is the best?
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 03-22-2012, 07:16 PM   #2
imhooked's Avatar
Re: Any COP suggestions?
i'm not sure, but the accel set looked pretty good.
i was looking myself, and the other sets sold by AM didn't seem to get a very good review
i was planning on getting the NGK Irium plugs too, but hadn't really gotten to look at any of the other manu's options
imhooked is offline   Reply With Quote
Old 03-22-2012, 07:23 PM   #3
Mzilla's Avatar
Please spend your money else where you are not gonna get any gains from any time of after market cops. I also would recommend keeping with NGK TR7 if you are naturally aspirated gapped at factory setting. If you are super charged run TR6 gapped at .032. We have had cars on the dyno with just new aftermarket COP and zero hp gains hope that helps. Many of the aftermarket COP are rebranded different color parts.
Mzilla is offline   Reply With Quote
Old 03-22-2012, 07:26 PM   #4
Region: Nevada
The motorcraft plugs work great in our cars.
---------- Post added at 05:26 PM ---------- Previous post was at 05:24 PM ----------
Not looking for any gains I'm having a power loss issue and I'm just need to replace them and I want to know wich are the best in terms of durability.
Old 03-22-2012, 07:27 PM   #5
imhooked's Avatar
hey guys,
thx... i was wondering if anything would be gained! my car still runs great (55K0 on the original plugs.
i'll consider the tr7 ngk(prob pretty reasonable at rockauto)
thx again-
joe
Old 03-22-2012, 07:34 PM   #6
Mzilla's Avatar
Originally Posted by imhooked
hey guys,
thx again-
joe
The thing is with COPs is when one goes bad your car will start missing and running like crap. Typically you will only replace one at a time when it is needed.
Old 03-22-2012, 07:38 PM   #7
Region: Nevada
---------- Post added at 05:38 PM ---------- Previous post was at 05:37 PM ----------
Old 03-22-2012, 08:17 PM   #8
stay OEM many manuf have so many issues just stay factory
Old 03-23-2012, 06:51 AM   #9
Region: North Dakota
I use MSD COP's. I recommend them to everyone. You may not gain HP persay, but you will notice that you don't have a power/torque drop off at the RPM range you do on stock COP's. Your power/torque curve will be higher. This is because you're getting a far better spark at high RPM that can keep up with that much less of time you have to fire off the air/fuel mixture. Typically OEM coils can't provide good spark at high RPM because they have too much dwell time. MSD coils help maintain a lower dwell time at high RPM (through better design and stronger magnets) which helps produce a better spark in a shorter amount of time with higher voltage. This causes your top end to last longer. Couple this with a good spark plug (like the NGK Iridium IX's or a quality motorcraft/autolite plug) and you'll notice a difference in top end. It is possible to gain HP if you couple these upgrades with a better intake system and a tune. Add a proper exhaust system and some extra fuel, and you'll definately want a better spark to burn off the air/fuel mixture. Don't listen to nay-sayers who didn't notice anything or had 1 bad experience or even "knew" someone who had a bad experience. Take it from an engineer who uses them and has first hand experience. They're worth it, and I can prove it.
K Twisted is offline   Reply With Quote
Old 03-23-2012, 06:59 AM   #10
imhooked's Avatar
thx man... will keep it on my to do list! msd was the other brand i was thinking about in addition to the accel kit
p.s. i've always liked the autolite plats and was thinking on trying their iridium version rather than the ngk's
Old 03-23-2012, 07:50 AM   #11
Eturner's Avatar
Dyno numbers?... Track times?... Because I have first hand experience with them and know several others as well!.. Zero gains on mildly modded cars!... Slightly better throttle response on some bolt on cars!...
And I'm talking cars, as in more than just Mustangs!...
And what type of engineer are you?.. I know several engineers that still don't know S*** about cars!...
Old 03-23-2012, 08:04 AM   #12
imhooked's Avatar
e-t,
e-z man... don't tear his head off.
everyone entitled to opinion. just ask and maybe he'll send some substantiation
Old 03-23-2012, 08:13 AM   #13
02PONY's Avatar
I replaced my factory cop's with the msd when i got my car less than 6 months ago and felt no difference and have had 2 go bad already and i think another is on its way out
02PONY is offline   Reply With Quote
Old 03-23-2012, 08:20 AM   #14
Eturner's Avatar
e-t,
Not trying to tear anyones head off!.. Just getting tired of hearing him say how he is an engineer so he should know!.. Sharing ones opinion and first hand experience is one thing!... Trying to throw a degree in peoples faces and there fore trying to make your opinion as fact is some thing else!..
Old 03-23-2012, 08:31 AM   #15
Calm down bro. My car is mildly modded (although I do have a 75 shot of nitrous) and they helped a lot. I was running rich and after installing these I noticed I was back at very close to stoichiometric ratio, and had better pull at around 5500 RPM than I used to. Stock RPM drop for HP is right around 5250, and at 5500 RPM I still had throttle response (non spray). They also help with the nitrous because they help burn the extra air/fuel mixture at higher RPM's preventing detonation/misfire/late-fire. I have a degree in Automotive Technologies and High Performance Engineering. I'm qualified to build everyday crate engines, all the way up to 8000 HP Nitro-Methane 500 CID BB Pro NHRA drag motors. You want an 850 HP 358 CID 9000 RPM revving NASCAR engine? I can build it. You want a 2000+ alcohol injected 575 CID Monster Truck engine? I can build it. You want a 85+ MPG gas/electric or gas/hydrogen hybrid running on 3 cylinders making 110 HP? I can build it. IF you are considering any upgrades in your 4.6 liter (or any engine for that matter) internals but aren't sure if they will work or not, I can and WILL blueprint your engine based on your wants/needs for you and make recommendations based off of head CFM flow/velocity, fuel type, rod length vs. crank stroke, metallurgy, piston speed, ring type, cam duration/lift, power adder, or fuel type, type of driving, type of car, etc. Free of charge. Most places would charge you anywhere from $150 to $200+ for that info. I do it for fun, but only for friends/family/mustang guys. Otherwise I charge.
---------- Post added at 09:27 AM ---------- Previous post was at 09:25 AM ----------
I'll try to find some dyno rags around here somewhere for you nay-sayers. No tracks where I live ..
---------- Post added at 09:28 AM ---------- Previous post was at 09:27 AM ----------
Engines are designed through Scientific Analysis and Physical Fact. You can't dispute physics bro. We didn't get to where we are by just slapping sh** together.
---------- Post added at 09:31 AM ---------- Previous post was at 09:28 AM ----------
Oh.. and don't be jealous because I paid to be able to back up and know first hand what most people try to learn by word of mouth, reading in a mag, or going on a forum. Don't be mad because I can make $120K+ a year working out of a shop doing what I love. You don't have to get all p***y about it..
Old 03-23-2012, 09:09 AM   #16
Region: Nevada
I really didn't start this thread to start arguments guys. I just wanted to know which COP are a good (and cheaper) alternative to OEM.
Old 03-23-2012, 09:13 AM   #17
Eturner's Avatar
Just because you say you can do some thing know all about it don't make it a fact "bro"!... And trust me I'm not pissy about how much cash you can make!... Just getting tired of you trying to throw your opinion down peoples necks as facts!... And then trying to back it up by showing what looks good on paper!.. What looks good on paper and what actually works is not always the same thing!..
Old 03-23-2012, 09:37 AM   #18
What's fact is fact. When its my opinion, I say so. Show me one example in history of an internal combustion engine that wasn't designed on paper first before being built. Etuner, your knowledge on building engines compared to mine is like comparing a worms knowledge of aviation to that of an eagle's. You just can't comprehend and that's why you make such ridiculous statements. I'm done with this thread.
Old 03-23-2012, 10:08 AM   #19
Eturner's Avatar
In my opinion Accel is a good and cheap alternative to OEM!.. But they showed no gains!.. MSD is another good one but only showed any real gains with some higher HP motors!.. MotoBlue is no different than OEM, they just look pretty under the hood!..
Sorry about any arguing on your thread!.. Hope this helps ya some!..
Old 03-23-2012, 10:12 AM   #20
Mzilla's Avatar
We can talk all day about what we have learned in a book and the degrees we have on our walls. The difference is actually building engines, beta testing program software for major companies like SCT and racing the cars we build. We have tested cars that make in excess of 750rwp and they have not made a difference. They look pretty and cost 3-500 dollars and don't waste the money guys unless you have a bad COP. My 2 cents.
Old 03-23-2012, 10:19 AM   #21
Eturner's Avatar
+11
Old 03-23-2012, 06:06 PM   #22
Region: Nevada
Ok thanks I think I'll go with the accels
Old 03-24-2012, 02:57 AM   #23
imhooked's Avatar
hey arron,
before you buy hit me on private message... wanted to see what price you got.
i saw a great price on 'em.
joe
Old 03-24-2012, 04:09 AM   #24
It's not me, it's you.
primer2tone's Avatar
Buy the pretty ones!
Any Florida Stangs? BigB227 Regional Mustang Discussion 62 07-13-2012 06:53 AM
Any other bullitts out there 01bullitt Other Special Edition 17 04-25-2012 10:45 PM
Any opinions on Pyle Subs? meano1 Mustang Audio & Video 9 03-31-2012 01:06 AM
any mustangs around Columbus MS? Ballard281 Regional Mustang Discussion 2 03-22-2012 05:52 PM
Any crazy 2V Gt Videos out there? FORDGT14 1996-2004 Mustang GT 0 03-22-2012 02:54 AM
02:16 PM
