Trick flow heads and intake. - Mustang Evolution
Old 03-24-2012, 01:07 PM   #1
Supersleepy96's Avatar
Am looking to put trick flow heads and intake manifold on my supercharged '96 any body have a set up like this and what do you think. Also some words of advice would be good too from anybody that has any In site.
Supersleepy96 is offline   Reply With Quote
Old 03-24-2012, 08:16 PM   #2
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I've heard they are great heads, but if you are supercharged I would get a forged rotating assembly and turn the boost up before I got heads. Just my 2 cents.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 03-24-2012, 08:36 PM   #3
Eturner's Avatar
Are you looking at getting the Track Heat manifold?.. Just curious as to how well a SC is going to fit there!.. Looks like for a very tight fit!..
Old 03-24-2012, 11:17 PM   #4
Region: North Dakota
Re: Trick flow heads and intake.
Trickflows are awesome heads. If you have stock heads now, you'll definately gain CFM with the new heads and intake manny. Don't be surpised though if you notice a drop in boost pressure after the install of the heads and manifold. Should you decide to up the boost with a smaller pulley at that point, just make sure you either tune for it, or increase fuel to compensate. If you don't have it already, I would look into making sure your exhaust is capable of handling more CFM. What goes in, must come out.
K Twisted is offline   Reply With Quote
Old 03-26-2012, 08:16 AM   #5
Both of these guys have given you good advise. The heads and intake will work wonders for you but you will need to address the bottom end unless you plan on only running about 5-6 lbs. of boost. The heads and intake on a stock bottom end are capable of making over 700 HP with around 14-17 lbs. of boost depending on the full build.
Gregg@TFS is offline   Reply With Quote
Old 03-28-2012, 06:46 PM   #6
Thanks for all the info. I am planing on building the block for the extra flow and the boost that I want to increase. Also I have been just looking around and those heads say they fit a 5.4L also. If so how easy would it be to that block in the car. Just courteous.
Your Favorite Clutch and Why K Twisted 1996-2004 Mustang GT 22 04-10-2012 07:02 PM
results - lowered and updated gears redfire 2005-2010 Mustang GT 30 03-27-2012 06:00 PM
fab torque reinforcments and subframe connectors dreamstang 1979-1995 Mustang GT 46 03-25-2012 09:03 PM
Transmission and torque converter Rm360 1996-2004 Mustang GT 0 03-24-2012 09:40 AM
Before and after pics! WhiteCobra94 Pictures and Videos 12 03-23-2012 05:23 PM
01:41 AM
