Lowering springs - Mustang Evolution
Old 03-24-2012, 11:34 PM   #1
03fastblack's Avatar
Lowering springs
What is a good set of lowering springs to settle with?
03fastblack is offline   Reply With Quote
Old 03-24-2012, 11:59 PM   #2
Mile high JDF's Avatar
What sort of drop are you looking for? Do you want a soft ride or a stiff ride?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-25-2012, 03:01 AM   #3
I have h&r 2' lowering springs I like them
Ryan7racin is offline   Reply With Quote
Old 03-25-2012, 09:03 AM   #4
Gobabygo67's Avatar
I have Eibach lowering springs for the convertible of our generation of mustang
Gobabygo67 is offline   Reply With Quote
Old 03-25-2012, 10:01 AM   #5
silvr002001's Avatar
Re: Lowering springs
Eibach pro kit here. Very pleased
silvr002001 is offline   Reply With Quote
Old 03-25-2012, 10:10 AM   #6
Ballard281's Avatar
I ordered the drop zone 2" for 179 on eBay very pleased
Ballard281 is offline   Reply With Quote
Old 03-25-2012, 10:13 AM   #7
I had the drop zone springs & shocks and wasn't pleased at all. They were installed on a 94 GT w/ a 2' drop and the things road like s***. It's a very cheap setup and spending extra for reliable set such as Eibach is preferred.
SNK3BTE04 is offline   Reply With Quote
Old 03-25-2012, 04:37 PM   #8
Ya I would like a 2 inch. I'll prolly go with h&r
Old 03-25-2012, 04:43 PM   #9
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I have H&R race springs and am very happy. About 1.5" up front, and 1.25" out back.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 03-25-2012, 05:32 PM   #10
2002VertGT's Avatar
I have a question. What is the difference between very and coupe springs?? Steeda says there is no difference in their springs but h&r say coupe only and eibach says there's are for coupe and vert V6 only...wtf??? What spring will fit the v8 vert?? I'm looking for a 1.5-2" drop
4.10 Gear/RPM thread
Old 03-25-2012, 06:02 PM   #11
02GT Poud Owner's Avatar
I have the H&R springs....easy install and love the look and ride.
02GT Poud Owner is offline   Reply With Quote
Old 03-25-2012, 06:42 PM   #12
Sonicblue11's Avatar
Would I be able to just change the springs out or do I need to get all new stuff as well????
Sonicblue11 is offline   Reply With Quote
Old 03-25-2012, 07:19 PM   #13
The main difference between a coupe and convertible is weight. A v6 convertible weighs about as much as a GT coupe due to added bracing to add rigidity, so they will be able to use the same springs. The V8 convertible is even heavier, so the drop will be a bit more aggressive, and it would put a little more stress on the springs making them feel slightly softer than a coupe with the same springs.
---------- Post added at 01:19 AM ---------- Previous post was at 01:13 AM ----------
Depending on the age/ mileage of your suspension components, you may want to change your shocks/ struts as well as changing to polyurathane bushings.
Old 03-25-2012, 07:29 PM   #14
I ordered from american muscle and ordered the new bushing with them. Had it dropped in an hour.
Old 03-25-2012, 08:21 PM   #15
Mathew r Wright's Avatar
Yah im going with h&r I looked at the photos on American muscle, it looks like the h&r lower a lil more than the eibachs do...
Mathew r Wright is offline   Reply With Quote
Old 03-25-2012, 08:22 PM   #16
Ballard281's Avatar
Yea they ride like **** but when you lower a car it ain't gonna ride like a Cadillac
Old 03-25-2012, 08:43 PM   #17
H&R Super Sports are what you want. They will give you the closest drop to 2". Probably see around 1.6"-1.75" without taking out isos. Removing them will get you right around 2". The Eibach Sportlines come close but I have heard of them sagging after time.
I have the Super Sports and couldn't be happier. Yes the ride is stiffer but you sacrifice some ride quality for the looks and performance Plus I took out my isos so I'm sure that loss of buffer had an impact on ride quality.
I'd recommend a set of CC plates along with a bumpsteer kit if you drop with H&R SS's. As said if your car has higher miles, say 60k or above get new bushings. Shocks and struts wouldn't hurt either since aftermarket ones are rated to handle more aggressive springs like H&R's, and you're tearing that area apart anyways.
Be sure to get an alignment afterwards. The aftermarket CC plates (4 bolts please) will make re-alignment much easier.
Old 03-25-2012, 08:47 PM   #18
2002VertGT's Avatar
The super sports for verts 51658.77 is the h&r number for them, says 2 in" front drop, if I take the isos out would it be more then? I measured tonight and my front gap is almost 4 inches and my rear is 3".
I actually have in my cart right now on AM the tokico d-spec shocks, h&r super sport vert coils, MM CC plates, and new Isos for a grand total of 1006.94 after discount. Just gotta wait till my cousin pays me for my truck!
Old 03-25-2012, 09:07 PM   #19
I'd have to say yes..taking them out would lower the car .25-.5" more, depending on how many you take out. It seems H&R is pretty accurate with their drop claims so I think I'd leave them in. Keep in mind that the new poly isos may raise the height or "lessen" the drop by .25" since the stock ones are probably smashed down and worn. If they aren't you could always re-use them. That's up to you.
front before:
front after taking both isos out:
I can't quite get two fingers between the tire and fender.
Old 03-25-2012, 09:13 PM   #20
2002VertGT's Avatar
front before:
Wait, that's after just taking Isos out??? Or after sprigs and removal of isos
That is soo what I'm looking for...
Old 03-25-2012, 09:20 PM   #21
No that's after the Super Sports and isos out, my bad..hell I wish just taking out isos did that, we'd all save $250
Old 03-25-2012, 09:21 PM   #22
2002VertGT's Avatar
Lol I love none the less!!! :thumbsup:
Old 03-25-2012, 09:26 PM   #23
Thanks, yah if you do decide to take them out wrap the ends with black electrical tape and slather them in grease...it will prevent squeaking and grinding, at least for a while I've had mine that way about a year and haven't had any issues.
But then if H&R claims 2" for your vert I might just leave them in. Or if you want to get extreme take just the top isos out in the front.
Old 03-25-2012, 09:29 PM   #24
2002VertGT's Avatar
I'm thinking about just leaving the old ones in
Old 03-25-2012, 09:40 PM   #25
Hell rock the stocks man...I think you'll be happy with the results...H&R does perform
Old 03-25-2012, 09:45 PM   #26
I had less than 8,000 miles on my Bullitt when I installed my H&R races springs, and my factory isolators were completely worn through. The factory isolators aren't made to last.
Old 03-25-2012, 09:48 PM   #27
That's funny, I've seen guys who have 80k miles and their isos looked barely worn, guess it all depends...
Old 03-25-2012, 09:52 PM   #28
Wow, that's crazy. I was really surprised to find how bad mine were with so few miles, but I wanted to upgrade to the polyurathane isolators so I wasn't too bothered by it.
Old 03-25-2012, 09:55 PM   #29
Yah those poly's will last way longer than the stock rubber ones.
Old 03-26-2012, 04:28 PM   #30
That's what I'm going with H and R springs. My car has 56k on it so I might just get new bushings as well
Old 03-26-2012, 08:50 PM   #31
You won't be disappointed.
Old 03-26-2012, 09:18 PM   #32
2002VertGT's Avatar
As soon as I get the down payment from my cousin on my truck ($1000) I'll be getting tokico d-spec shocks/struts, h&r super sport convertible springs, mm caster camber plates!! Can't wait!
Old 03-26-2012, 09:26 PM   #33
She's gonna look saweet!!!
You'll like those D-specs, they are nice shocks/struts...I would consider a bumpsteer kit if you can squeeze it in...it'll help get your tie rods and a-arms traveling at the same rate again after the drop..this will eliminate the excessive bumpsteer and keep you in control of the car when going over bumps at high speeds.
Old 03-26-2012, 09:30 PM   #34
I saved some cash by going with the eibach camber bolts instead of plates, but mainly because I didn't want to drill holes in my Bullitt. They gave me plenty of adjustment and have held my settings fine with no need to have them realigned.
Old 03-26-2012, 09:50 PM   #35
Ballard281's Avatar
I'd hate to kill yalls conversation but is it possible to have the rear springs upside down on the 06 GTs?
$95 Track day at Willow Springs- Streets of Willow-April 14-15 Extremespeed Regional Mustang Discussion 1 04-12-2012 05:03 AM
Lowering Springs Installed Napoleon85 Pictures and Videos 15 03-23-2012 05:42 PM
Lowering Springs Installed Napoleon85 2011-2014 Mustang GT 15 03-23-2012 05:42 PM
2002 Mustang V6 Springs and shocks records1981 Pre-2005 V6 Mustang 1 03-23-2012 09:11 AM
lowering 04 gt imhooked 1996-2004 Mustang GT 3 03-23-2012 08:34 AM
05:47 AM
