spring install - Mustang Evolution
Old 03-25-2012, 04:39 PM   #1
superboondee's Avatar
Region: Idaho
spring install
Just waiting on my steeda springs but I was wondering, Are they something a backyard mechanic can do at home? Is it very time consuming, and are there any special tools I will need? Just finished putting on my off road h pipe and love the sound. So much less drone than the off road x pipe. Plus it really turns heads.
---------- Post added at 04:39 PM ---------- Previous post was at 04:36 PM ----------
I forgot to ask, Do I have to have camber caster plates? Ran out of money so I couldn't get them.
If you can't beat them, Get a supercharger.
superboondee is offline   Reply With Quote
Old 03-25-2012, 04:51 PM   #2
Mile high JDF's Avatar
It's an afternoon job for sure. You'll need some spring compressors Goethe stock ones and that should be it. The plates aren't necessary but you'll eat through tires faster
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-25-2012, 05:01 PM   #3
02NightmareGT's Avatar
I have taken my suspension apart countless times.. I can take down and put together the whole front suspension in about an hour... It's freakin easy. Don't worry. Be ready for some sticking bolts in the rear shocks. U have to hammer them out. CC plates are usually necessary for proper alignment. How much are these springs supposed to lower?
02NightmareGT is offline   Reply With Quote
Old 03-25-2012, 05:31 PM   #4
imhooked's Avatar
Re: spring install
check this out...
i was watching this homemade vid and looks pretty good. there are others of course
imhooked is offline   Reply With Quote
Old 03-25-2012, 09:17 PM   #5
Re: spring install
Yah our mustang's suspension is fairly simple when you break it down. It seems complicated and intimidating since there's multiple parts all correlating to each other.
The hardest part is decompressing the spring, don't want a spring full of energy launching at you. Other than that and maybe some stubborn bolts it's not too bad.
This article helped me out a bit:
Installing Mustang Lowering Springs - Mustang Evolution
Old 03-26-2012, 07:19 PM   #6
Region: Idaho
Re: spring install
Thanks for all the help. They are going on this weekend.
Old 03-26-2012, 07:34 PM   #7
Re: spring install
i wrote a how to, its rather straight forward.... might take a bit of time and you need a friend for a couple things. Overall its not bad read over the how to here: Installing Mustang Lowering Springs - Mustang Evolution
Old 03-26-2012, 11:26 PM   #8
Mathew r Wright's Avatar
Re: spring install
Ya man I really liked that video, I knew was gonna be easy, but he made it look 10! Times easier... I even like how he showed the right way to turn the springs and everything...
Mathew r Wright is offline   Reply With Quote
Old 03-27-2012, 10:46 PM   #9
Region: Idaho
Re: spring install
The springs are going to lower the car 1.5 inches. Hope that gets the stance just right.
Old 03-27-2012, 11:09 PM   #10
ColeJohnson's Avatar
Re: spring install
I've tore 99-04 suspension apart so often that I can have everything apart and off the car in like 45 mins. The biggest thing I can say is work on the car when it's cooled off, and also shoot PB blaster on all the bolts and allow it to penetrate for a few minutes. You'll thank yourself later.
2016 Comp Orange GT (current)
CT: LMMC-CT 2012 Spring Cruise wheelman Regional Mustang Discussion 4 05-20-2012 12:28 PM
Spring! Siendly22 Pre-2005 V6 Mustang 7 03-28-2012 05:43 AM
Rpm gauge install!! Help.. 89 Foxloco 1979-1995 Mustang GT 6 03-26-2012 07:20 PM
Rear axel gear install cost? Arron's racecar 1996-2004 Mustang GT 15 03-21-2012 07:55 PM
Tips/advice for O/R X-Pipe install OrganDonor 2011-2014 Mustang GT 10 03-21-2012 06:47 AM
12:40 AM
