HELP! - Mustang Evolution
Old 03-25-2012, 05:47 PM   #1
blackbetty99GT's Avatar
HELP!
Ok so i was getting on the interstate and smoke starting coming from behind my har (exhaust) so i kept going thinking it was just water hitting the hot pipes, bc it rained earlier that day, anyways kept going and smoke kept coming out. So i pulled over and opened my hood and there was anti frerze all over the my hood (undrtneath the hood) and smoke pured out when i opened it. So i work at a garage anyways and was on my way to work to i kept driving. It was smoking from my exhuast from 1st gear to 3rd then it stopped and ran like normal. Got to work and had my dad look at it, he said it could b a freeze plug. Then had another boy look at it and he said it could be the water pump...got the head mechanic to look at it and he said my lower intake manifold is busted bc undetneath the intake there is a puddle of anti freeze sitting on top of the block. Just wanting to know what yall think is wrong with it!
---------- Post added at 05:47 PM ---------- Previous post was at 05:44 PM ----------
Oh and some more info....looked like anti freeze was coming from the back of the driver side cylender head.
blackbetty99GT is offline   Reply With Quote
Old 03-26-2012, 06:48 PM   #2
Vegas97gt's Avatar
Region: Nevada
Did you check your oil? Make sure it's not a head gasket. Idk if it would smoke if it was your water pump they just leak when it goes bad. And as far as a freeze plug I had a freeze plug go on my 91 Lincoln with a 4.6 and it would only leak when the water would cycle through. I suggest putting it up on a lift and look at the back of the engine and see if there is a trail of burned antifreeze . My guess would be the intake manifold but checking and make sure before you start throwing parts at it.
Vegas97gt is offline   Reply With Quote
Old 03-26-2012, 11:35 PM   #3
Mathew r Wright's Avatar
Re: HELP!
Yep I'd agree... I can really see those plastic manifolds cracking easily. All they are good for is Savin weight and bein cheap... Top it off, let it warm up, cycle, then watch it to see where it's leakin...
Mathew r Wright is offline   Reply With Quote
Old 03-27-2012, 08:34 PM   #4
Turns out i blew my intake gasket and head gaskets. Should be fixed this weekend
Old 03-27-2012, 08:53 PM   #5
jjsg09's Avatar
Dang how did you do that. That sux!!!
Old 03-27-2012, 10:10 PM   #6
Vegas97gt's Avatar
Region: Nevada
So much power gaskets cant hang on!!!!! Lol
Old 03-28-2012, 04:30 PM   #7
Showed my *** getting on the interstate haha
Old 03-29-2012, 01:51 AM   #8
Region: North Dakota
Re: HELP!
And keeping intake temps down.. that's a big one..
K Twisted is offline   Reply With Quote
86 mustang gt help! Bubba_Misch Classic Mustangs 3 03-29-2012 05:54 PM
Need some help Mustangreazon50 Pictures and Videos 6 03-25-2012 09:41 PM
Looking for help SoCalKev Pre-2005 V6 Mustang 1 03-25-2012 05:03 PM
Transmission fluid help 95' gt manual 1995boss 1979-1995 Mustang GT 5 03-25-2012 02:33 PM
Steering wheel 1/4 turn off. Help? SnowWhtSnake Pre-2005 V6 Mustang 0 03-24-2012 10:35 PM
» Members Mustangs
"Red"
Labrat
Candy
cariacou
Add your Mustang
02:50 PM
