engine problem? - Mustang Evolution
Old 03-25-2012, 07:04 PM   #1
StackeStang's Avatar
engine problem?
I was driving the other day and my car acted like it was going to die, and as I pulled into the gas station it did die. I thought it may have just been bad gas in the car because I got gas and it ran fine. but today when i would accelerate I heard a strange knocking sound coming from the engine. any ideas?
StackeStang is offline   Reply With Quote
Old 03-25-2012, 08:09 PM   #2
Mathew r Wright's Avatar
Re: engine problem?
Sounds like a vacuum leak to me, cause when you have one, the motor will pings and peg like as if its air fuel is off... I found this was the problem when I first bought mine. It was just because the breather tube from the valve cover on the passenger side to the the plenum was dry rotted... You know how it's got that lil 90 degree hose that connects to the plug that connects to the valve cover ya that was it... Also the cold air intake was loose so had to tighten that up to... So I'd just look around or get it pressure checked, however ya wanna do it, hey maybe even ur runnin lean but I really don't wanna say that to worry ya. Try Changing the fuel filter, heck run it to auto store code check it see if they pull something up idnk just tryin to advise ya...
Mathew r Wright is offline   Reply With Quote
Old 03-25-2012, 08:21 PM   #3
Eturner's Avatar
1. If you have anyway of checking the codes, such as with a tuner, then do that!.. If not then go to AutoZone and ask them to run a scanner on your car!.. 2. Does your idle seem to be a bit rough?.. If so then it might be a bad coil or plug!.. 3. I also agree and say to check your hoses and intake fittings!..
Old 03-25-2012, 09:36 PM   #4
Re: engine problem?
the check engine light isn't coming on so i didn't think to check with my tuner... i may do that. and yeah I've had issues with the vacuum hose you mentioned, i'll check that. the intake should be fine i tightened it well just a couple months ago when i got my CAI. i plan on getting new plugs very soon too. thanks for the info guys!
Old 03-25-2012, 09:57 PM   #5
Eturner's Avatar
Some times your car will pickup a code but not throw the warning light I imeadiatly!..
Old 03-27-2012, 12:04 AM   #6
Yes that's true I was runnin lean and didn't even know it...
engine cleaning eswinty 2011-2014 V6 Mustang 9 03-31-2012 10:37 PM
check engine light 2002Gt 1996-2004 Mustang GT 48 03-31-2012 07:11 PM
1966 Mustang ammeter problem Gatorlee12 Classic Mustangs 2 03-30-2012 08:54 PM
Tranny problem? Eltwo 2011-2014 V6 Mustang 12 03-27-2012 08:50 PM
MAC ProChamber & V6 Engine robb15033 Pre-2005 V6 Mustang 8 03-24-2012 11:55 PM
01:41 PM
