Cutting rear springs - Mustang Evolution
Old 03-25-2012, 08:36 PM   #1
FastEddie03GT's Avatar
I put a set of SVE lowering springs on my 03 GT around a month ago. I can tell over time the springs have settled down more but the rear still has more fender gap than I would like. I thought about cutting the rear springs some to lower the rear one more inch. But I have no idea how much to cut off to get what I want. Has anyone cut aftermarket springs before?
FastEddie03GT is offline   Reply With Quote
Old 03-25-2012, 08:47 PM   #2
Mathew r Wright's Avatar
Re: Cutting rear springs
Man whatever you do do not! Cut more than just small little bits off! I seen my buddy eff up his springs by cuttin a hole loop off! So I would start with half inches... And remember they are Progressive rate springs so what ya cut off will settle even mor... So if ya think about it half an inch, then over time when they settle they'll be right where you want em... And if it doesn't get ya there pull em back off and cut another quarter maybe, that should be it for sure...
Mathew r Wright is offline   Reply With Quote
Old 03-25-2012, 09:08 PM   #3
Thats what I was afraid of. I might just try to just take the isolators off and see what happens.
Old 03-25-2012, 09:26 PM   #4
Eturner's Avatar
I strongly suggest not to cut your springs!.. I know to many that cut their springs and later regretted it!.. Plus it just might take your rear springs a bit more time to settle in!.. Remember there is more weight over the front of your car than the rear!..
Old 03-25-2012, 09:35 PM   #5
I agree...a lot of guys cut their springs and don't have problems (right away) but it's like piecing together a CAI out of PVC and putting in your engine bay, yah it works but the right way is simply better
Plus as said progressive springs, as well as any spring have a preset load. Once you start cutting off coil, you change that load rate...obviously with less coil for the load to be distributed thru you're creating more stress on the remainder of the spring, which can cause more sagging, squeaking and worst case, a destroyed spring.
Taking out your iso's will lower the car some more...probably ~.5" if you take out both the top and bottom isos. I'd try that, let the car settle for a week or 2 then decide whether it's dropped enough.
Old 03-25-2012, 09:47 PM   #6
if they are not progressive they can be cut with a cutoff wheel... but you must be carefule and cut the top of the rears as the pigtail cant be cut off. I would not cut much.... very little.
Old 03-27-2012, 01:09 AM   #7
Yah really I wouldn't cut em either I didn't even think about the spring rate changing... Heck here's an idea, lol just through some extra weight in the trunk, like kids, cinder block or whatever ya got lol just a thought...
Old 03-27-2012, 11:06 AM   #8
you can use your OEM ones and cut them if the rate isnt that much off (stock are around 250 linear I believe)
New leaf springs Seattle66 Classic Mustangs 1 03-27-2012 08:35 AM
Lowering springs 03fastblack 1996-2004 Mustang GT 34 03-26-2012 10:50 PM
Lowering springs Blackgtcs2012 2011-2014 Mustang GT 16 03-25-2012 08:43 PM
7.5 to 8.8 rear end Kflynn318 Pre-2005 V6 Mustang 3 03-25-2012 06:25 PM
Rear end gears jwhayne0001 1979-1995 Mustang GT 18 03-24-2012 11:57 PM
06:12 AM
