those gasoline really evaporate from gas tank? - Mustang Evolution
Old 03-26-2012, 04:43 AM   #1
those gasoline really evaporate from gas tank went car just parked for a couple hours or a day or I could have a gas leak some were in system?
---------- Post added at 04:43 AM ---------- Previous post was at 04:25 AM ----------
because come on! is not feared that I get out from work at 7am(grave yard)fill my tank to just get home sleep and not filling before work at 1030pm around $55 91premium full tank but went I turn on the car at nigth to go to work half of a fourth is gone! but I fill it all the way till it spills, I only get around 200miles a tank sometimes less, that's from home to work three days around 168 miles and like 20 park or crusing whit 3year old son, so technicaly I only have gas for three days not good I could be getting atlease 4 1/2 but I keep loosing gas wile car is parked for around 6hours?
robertoortiz85 is offline   Reply With Quote
Old 03-26-2012, 06:36 AM   #2
meano1's Avatar
Could someone know your routine and be siphoning gas off you?
1998 Mustang Gt, MSD coils, Ford Racing lowering springs, KYB shocks, caster camber plates, Flow Tech exhaust, K&N CAI, auto trans with shift kit, Jet Performance module, full length sub frame connectors, Redline Tuning hood struts. Oh yea, forgot to mention the Plasti Dip stripes.
meano1 is offline   Reply With Quote
Old 03-26-2012, 06:49 AM   #3
2002VertGT's Avatar
It could evaporate if you have a hole....or you could have a hole and be leaking, have you checked the ground for puddles, or evidence of a leak, if it's a slow leak it would evaporate before you find it..
4.10 Gear/RPM thread
Old 03-26-2012, 07:30 AM   #4
I don't smell any gasoline, and there's no leak around, I douth it that someone could be stilling it because I put small traps like small black string in side treat of gas cap and hanging on the side very small to see and it will get lost ones cap is remove , my explorer used to do it to
Old 03-26-2012, 06:35 PM   #5
meano1's Avatar
Could it be a bad float/ sending unit in tank that can give you a false reading showing lower level than what's in there? I've experienced this before on other cars but haven't on the mustang.
Old 03-26-2012, 09:27 PM   #6
because I try differnt methods to get the correct reading, one was fill the tank till it spills since I was replacing my white gauges I place the gas needle althe way up whit ignition on to get all needles runing, the other I try these instrumental clusther test that shows in the little digital number bar in ur clusther it shows you all correct reading in differnt numbers value, is pretty need it even shows you your rpm as you drive I got it from these page call bullittarchives.com it shows you a lot of mods and do it your selfs you guys should try it.
Gas prices D: zeltik The Bar 134 04-28-2012 05:34 AM
Alabama anybody from Bama on here? dmax8709 Regional Mustang Discussion 9 04-19-2012 02:17 PM
Anyone around here from Arizona? FORDGT14 Regional Mustang Discussion 61 03-30-2012 05:34 PM
What year are these from? 02PONY General Mustang Discussion 12 03-29-2012 07:38 AM
New Member from Helena, AL onefst87 New Member Introductions & Greetings 15 03-25-2012 09:16 PM
02:00 AM
