Gas gauge issues... - Mustang Evolution
Old 03-27-2012, 05:05 AM   #1
2002VertGT's Avatar
Gas gauge issues...
K, so I was just wondering if a lot of ppl have this issue or if it's just the floater in my tank. But I will fill up and anywhere between 50-70 miles my needle will finally fall below the full mark. Within 10 more miles it will be on the 3/4 mark. Then it will sit there till about 90-100miles then drop to 1/2...so on and do forth. I normally get about 250 miles before u full up (not completely empty) normally averages 18-19 mpg when in do the math..
4.10 Gear/RPM thread
Old 03-27-2012, 06:24 AM   #2
BigB227's Avatar
Hey your kinda lucky lol because I'll take mine to the gas pump and go all the way full ad get in my car and the gauge will read half tank so I have to gauge how much has I use by that
BigB227 is offline   Reply With Quote
Old 03-27-2012, 08:35 AM   #3
2002VertGT's Avatar
Lol
Old 03-27-2012, 08:42 AM   #4
jjsg09's Avatar
Mine does the same exact thing but you get better mileage, I drive all city though.
Old 03-27-2012, 10:10 AM   #5
Re: Gas gauge issues...
mine (and my previous two mustangs with the same setup) always sat at full to half a tank longer than from half a tank to empty.
Old 03-27-2012, 11:41 AM   #6
Probably juSt your floater
Crunch9876 is offline   Reply With Quote
Old 03-27-2012, 08:32 PM   #7
JCOB72's Avatar
I have an 01 gt. A few places say it has a 15 gallon tank is that correct? When I fill up it only takes about 12. The needle gets really low but I have yet to see an oh sh*t light. I've only had it for a few months and I'm not sure there is a light?
JCOB72 is offline   Reply With Quote
Old 03-27-2012, 08:36 PM   #8
Yah there's definitely a low fuel light, I know from experience
My gauge does the same thing...I'll fill up to the first click, I'll get ~75 miles before the needle moves off the full mark, then it'll take about 20-30 miles and it'll be at 3/4...I think it's just something with our cars.
Currently I'm running off the tank of gas from storage...I've gone ~175 miles and I'm right on the 1/2 tank mark.
Old 03-27-2012, 08:42 PM   #9
2002VertGT's Avatar
Mines @ 199 @ 1/4
Old 03-27-2012, 08:45 PM   #10
JCOB72's Avatar
Think I should run it until the light comes on? I usually get about 200-210 on a tank but have never seen the low fuel light come on. My car is stock except for CAI.
Old 03-27-2012, 08:51 PM   #11
2002VertGT's Avatar
I wouldn't cause you risk getting the crap in the bottom of te tank clogging up your filter...
Old 03-27-2012, 08:53 PM   #12
Damn I never thought you 2v guys were that far behind fuel usage wise...when I dd the car I used to average 320 a tank...and that was mixed driving and in colder conditions too. But I did have low miles, 17k-45k when I dd it.
Old 03-27-2012, 08:56 PM   #13
JCOB72's Avatar
Like I said before when I fill up I can only put 12g in. I've never seen the light come on but the needle is very low. Could there be something wrong?
Old 03-27-2012, 09:06 PM   #14
2002VertGT's Avatar
Most likely not...next time you get that low run it a little farther...just be prepared to stop and get fuel as soon as you make sure it's working so you don't jam up ur filter
Old 03-27-2012, 09:09 PM   #15
JCOB72's Avatar
Cool. Thanks man. I'll give it a shot. Just hope I'm not walking!
Old 03-27-2012, 09:11 PM   #16
2002VertGT's Avatar
Lol me too brother..I know mine works, but I try to never let it get down that low. Before you try that see if the light comes on when you order start your car....I'm pretty sure mine does when it does the gauge check thing and all the lights light up..
Old 03-27-2012, 09:13 PM   #17
JCOB72's Avatar
Good idea!
Old 03-28-2012, 05:18 PM   #18
JCOB72's Avatar
My gas light Comes on when I turn the key but I haven't seen it when I'm low on gas. Could the light work but the gauge have something wrong and not actually give me a heads up?
Old 03-28-2012, 05:45 PM   #19
2002VertGT's Avatar
Doubt it. Our cars have a 15 gallon tank....you probally have to get down to 2 gallon left for it to turn on and you said you always fill up like 12 gal...so it has not gotten low enough. I fill up almost every time and it takes 11gal...try it if you want, I wouldn't recommend it if you know the bulb works...just asking for trouble
Old 03-28-2012, 07:16 PM   #20
BigB227's Avatar
My gas gauge only goes to half tank when I fill up and whenever it hits empty it actually means I have a half tank but I have seen the light come on many a times but only because my gauge is off alot
Old 03-28-2012, 07:18 PM   #21
2002VertGT's Avatar
Yeah I understand your dilemma but that does not mean someone should run their tank that low to see if their light works...
Old 03-31-2012, 08:07 PM   #22
2002VertGT's Avatar
In 52 mikes my gauge has dropped from just below full to almost half tank mark
Old 03-31-2012, 08:22 PM   #23
I filled up today I got 250 miles on a tank that's mostly city miles with one trip on the interstate doing 90mph I don't think that's to bad.
Ryan7racin is offline   Reply With Quote
Old 03-31-2012, 08:33 PM   #24
2002VertGT's Avatar
No, it's not...I usually get 250 miles before I fill up (11gal fillup) but my gauge doesn't drop off of full normally till 70...this is rediculous...it's at 90 and almost to half tank when it's usually at 100 when it's at 3/4 tank....I'm usually pushin 130-150 when it's where it is in that pic...and I thought it was dropping fast there...
Old 04-02-2012, 04:47 AM   #25
I only get 169 to 180 bearly hiting the ligth, maybe your floater, have u try to diagnost your speedometer gauges to see if there reading correctly, try these page it shows you how, bullittarchives.com
robertoortiz85 is offline   Reply With Quote
Old 04-02-2012, 05:45 AM   #26
2002VertGT's Avatar
No I haven't yet, didn't know how. My main issue is not gas mileage (I average 18mpg), but just wondering if everyone's needle drops like mine. It's no where near a steady motion...
45-70 miles before it drops off the full line then 10 miles from the full line to the 3/4 line, then 30 more miles till its at half then it will sit there for a minute.
I mean my work is 28 miles away. I can get gas before I come home. Drive home, back to work, back home and still be around full. When I drive back to work the next day I'll be below 3/4 web I get there and below half by the time I get home.
Old 04-02-2012, 07:02 AM   #27
my issue is I fill up till spills, drive for same around 70miles parked and couple hours later a hole 1/4 is gone and then I drive to work again 27miles needle sits at almost half mark then after i get off work turn car on needle is bellow half from there is around 100mile mark and another 60-70 miles till ligth pops on, is like is meant to last 70 miles for the first 1/4
Gas prices D: zeltik The Bar 134 04-28-2012 05:34 AM
those gasoline really evaporate from gas tank? robertoortiz85 1996-2004 Mustang GT 5 03-26-2012 09:27 PM
Rpm gauge install!! Help.. 89 Foxloco 1979-1995 Mustang GT 6 03-26-2012 07:20 PM
Gauge cluster swap or rebuilt? Stang99 Pre-2005 V6 Mustang 0 03-24-2012 11:11 AM
Car lurches forward without stwpping on gas pedal 813floridaracin Pre-2005 V6 Mustang 3 03-24-2012 08:50 AM
06:28 AM
