98 gt (NPI) choking on top end of rpm's - Mustang Evolution
Old 03-27-2012, 04:44 PM   #1
leviz79's Avatar
I had this problem before- after the car got hot from alot of city driving when I have it loaded in like 1st, 2nd or 3rd gear and heavy on the gas the motor would choke out on me (stutter) around 5-6k rpms, it runs smooth any other time or when its been sitting fir a long time. Ive changed the plugs, wires, did a fuel injection clean at the ford dealership, all 4 new 02 sensors, fixing to change out my charcoal canister. Please help if any tips on whats going on. Thank you.
leviz79 is offline   Reply With Quote
Old 03-27-2012, 06:23 PM   #2
1quick4.6's Avatar
Mine did the same and i changed the egr vacuum solenoid and cleaned the mass airfloe with mass air cleaner and fixed it
1quick4.6 is offline   Reply With Quote
Old 03-27-2012, 06:42 PM   #3
Is there any possibility of the engine flooding?
Chaise33 is offline   Reply With Quote
Old 03-27-2012, 07:02 PM   #4
1quick4.6's Avatar
What do u mean? Too much fuel?
Old 03-27-2012, 08:34 PM   #5
leviz79's Avatar
I dont think its flooding out cause its fine at all ranges of the rpm's except around 5-6k, it runs smooth and even on normal to mildly hard throttle it responds well ots just when I get on it HARD, she's good up untill those high rpm's. It did it to me about a couple months back and was good up untill today is when it started up. I do need to look into changing out some emission items like that egr solenoid, and valve ect... Could that be a victim since they are original, not throwing up any codes for them items either.
Old 03-27-2012, 08:58 PM   #6
1quick4.6's Avatar
Certainly
Old 03-27-2012, 09:16 PM   #7
leviz79's Avatar
Ill go ahead tomorrow and change out at least the egr valve and solenoid and let you know how that goes. Thanks alot for your help 1quick4.6.
Old 03-27-2012, 10:02 PM   #8
1quick4.6's Avatar
Anytime let me know hiw it goes
Old 03-28-2012, 08:17 AM   #9
leviz79's Avatar
Hey there 1quick4.6 just letting you know I went to auto zone this morning and bought my new egr and vacc. Slnd, indtalled and my idle is alot smoother and top end power situation has not been acting up so far. I greatly appreciate your help. Thank you.
Old 03-28-2012, 04:35 PM   #10
1quick4.6's Avatar
Your welcome, anytime
Old 04-05-2012, 11:42 PM   #11
leviz79's Avatar
Well its doing it again. Next im gonna clean my mass air flow sensor.
Old 04-05-2012, 11:48 PM   #12
1quick4.6's Avatar
Clean your mass airflow with maf cleaner only, then clean out your throttle body with cleaner, could also be evap purge valve solenoid
Old 04-12-2012, 12:08 AM   #13
leviz79's Avatar
once again your right. i cleaned out the MAF and scrubbed my T/B and its running strong. thanks alot again.
Old 04-12-2012, 12:14 AM   #14
1quick4.6's Avatar
Anytime man
Old 04-12-2012, 08:14 AM   #15
Supersnake4.6's Avatar
Also the stock coil packs in 96 thru 98 gt only only good toabout 5700 rpm msd would help alot
Supersnake4.6 is offline   Reply With Quote
Extensively Modified 1993 GT For Sale Trojan Horse FYI Ads | Recently Listed 5 04-06-2012 06:22 PM
Go Pro On A Mustang GP3GT 1996-2004 Mustang GT 20 04-01-2012 11:51 AM
Loss of horsepower? Doe_Rae_mi 1996-2004 Mustang GT 6 03-29-2012 08:34 PM
17" tires recommendations for 1999 Mustang GT magnum1331 1996-2004 Mustang GT 13 03-28-2012 06:45 PM
2010 axle backs on 2005 tc x 4 2005-2010 Mustang GT 4 03-27-2012 03:49 PM
08:18 AM
