need help... new tb&plenum - Mustang Evolution
Old 03-28-2012, 03:12 PM   #1
imhooked's Avatar
if anyone knows... i installed bbk 70mm and stack racing plenum today.
car fired right up (as expected!) and seems to idle fine. after car completely warmed up and driven about some, idle rests nicely at about 750 in neutral. it does first drop to 1000, and then takes second or to to drop to all the way 750. (was wondering if this is normal or not?). NOTE i have not tried adjusting idle (YET).
i did think i smelled something like exhaust (or maybe unburned gas?)in cockpit during my ride, which may be my imagination, but i am pretty sensitive to this stuff. after i parked car, opened hood revved engine couple times, went about 1/2 way to WOT and sounded like i almost got a little backfire?! did i miss something, computer need time to adjust, or nothing to be alarmed about?
also note: i am quite certain everything is reconnected, and tightened. i do have a K&N caik and no other current mods although the exhaust and SCT tuner are next. any help appreciated-
imhooked is offline   Reply With Quote
Old 03-28-2012, 03:22 PM   #2
BigB227's Avatar
I could be wrong but it could be due
To you not having the car tuned for the new throttle body, maybe putting the tune on will fix your problem
BigB227 is offline   Reply With Quote
Old 03-28-2012, 03:36 PM   #3
imhooked's Avatar
Re: need help... new tb&plenum
yup was wondering that myself.
also wasn't sure but on acceleration (even before i installed the parts) i had been having some 'vibration', which i had initially attributed to brakes or tires, but now am wondering if engine may be missing a little. maybe time for new plugs? car only has 55000 miles and pretty well cared for as i'm original owner, but who knows
Old 03-28-2012, 03:41 PM   #4
BigB227's Avatar
Yeah you never know and putting I new plugs wouldn't hurt
Old 03-29-2012, 04:55 AM   #5
imhooked's Avatar
was thinking... i didn't have a new egr valve gasket. the old one was either permatex gasket seal type, or just disintegrated. was wondering if that might have be a problem, but i will replace it anyway when get a chance
engine is running better. took it out and again last night and she goes pretty good! as far as the tuner goes, maybe it will help but as i only used 70mm tb figured engine would adjust a/f on it's own really not sure if necessary
i think the plugs, exhaust(o/r h and new cat back), and tuner will certainly wake 'er up a bit more!
New 2012 Ford Mustang 5.0 mods Sprintradc 2011-2014 Mustang GT 15 03-29-2012 08:24 AM
New rear look, good or bad Dmay65 Classic Mustangs 8 03-28-2012 11:21 PM
Need advise "again" !!! 89 coupe 1979-1995 Mustang GT 9 03-28-2012 05:07 PM
Pros or cons b&m hammer shifter 02utahgt 1996-2004 Mustang GT 5 03-28-2012 10:54 AM
Trade in 2010 for a new 2012 Teboidro 2011-2014 Mustang GT 31 03-28-2012 08:49 AM
04:21 AM
