Offroad pipe install - Mustang Evolution
Old 03-29-2012, 03:45 PM   #1
BigB227's Avatar
This project turned out to be a nightmare the lower passenger mid pipe to header bolt was a pain in the @$$ to get to and when I did it was so stuck on that it started rounding off
BigB227 is offline   Reply With Quote
Old 03-29-2012, 03:51 PM   #2
same here, I ended up whit a soured shoulder by holding the stock pipe wile unbolting it, and had to make my own gasket for that pass side flange
robertoortiz85 is offline   Reply With Quote
Old 03-29-2012, 04:00 PM   #3
BigB227's Avatar
Hell I couldn't even get past that one stupid nut after 3 days and over 10 hours of trying different ways to get at it and I'm about to break down and pay someone to do it
Old 03-29-2012, 04:07 PM   #4
clark98gt's Avatar
Re: Offroad pipe install
On mine it was easiest to remove the oxygen sensor then use a series of swivels and extensions to get to it. The nice thing is once the stock h pipe is gone all of those bolts are much easier to get to.
1998 Gt- current progress
Engine back in car some reassembly required
clark98gt is offline   Reply With Quote
Old 03-29-2012, 04:09 PM   #5
did u use one of those twistable extentions not sure what its called but that was the only way I got it off,
Old 03-29-2012, 04:10 PM   #6
BigB227's Avatar
I tried that but the bolt started rounding off and I got the craftsman damaged nut/bolt remover kit and nothing with that either, it actually kinda made the situation worse
---------- Post added at 05:10 PM ---------- Previous post was at 05:09 PM ----------
Also the 98's are a lil bit different then my 03
Old 03-29-2012, 04:12 PM   #7
did u used a gasket on the pass side, do you hear a leak on that side,
Old 03-29-2012, 07:04 PM   #8
superboondee's Avatar
Region: Idaho
Just changed mine this past Saturday and it sucked. Had to get a deep well socket and cut it with a hacksaw just enough so I could fit a swivel joint in there. Finally got it and had to buy more replacement nuts for the header because they were a bit rounded.
If you can't beat them, Get a supercharger.
superboondee is offline   Reply With Quote
Old 03-29-2012, 07:29 PM   #9
imhooked's Avatar
hey guys,
man! i was thinking about doing mine myself, and heard the same thing about that friggin p.s. header flange. God, your scaring me... think i might just pay someone to do mine.
and yes, also saw repeatedly(even from manu's) that the p.s. flange gasket is kind of needed.
hope you all managed to get it done!!!
imhooked is offline   Reply With Quote
Old 03-29-2012, 07:43 PM   #10
BigB227's Avatar
Originally Posted by imhooked
hey guys,
Well I would say man it doesn't hurt to try but I'm going to have to get someone to do mine because I've absolutely tried everything and I don't want to completely strip the nut
Old 03-29-2012, 08:09 PM   #11
imhooked's Avatar
ya know, i dont know if i should even go through with it cause i have to get car inspected every year(in NY). i imagine the tuner or mil elim's would help, (or i could just register in FL) but don't feel like going through THAT hassle changing pipe every year just for a state insp!
Old 03-29-2012, 08:47 PM   #12
jjsg09's Avatar
These cars are not easy to change the exhaust mid pipe. If you have patients on the passenger side it can be done easily. If you get in a hurry with these bolts you will end up damaging these bolts and a 1hr job turns into a weekend long ordeal. It sucks when that happens, my first time doing this job I did the same thing. I had to hack saw along the side of the bolt through the fender weld and it finally broke free. I know it sounds crazy but it worked. I hate it for you man and hope you get to put on the pro chamber exhaust. Even though it was a horrible disaster it was totally worth it and all the looks my car got!
Old 03-30-2012, 01:12 AM   #13
Vegas97gt's Avatar
Region: Nevada
I know I'm jumpin in late but when I swapped mine I took the starter out of the way and had a variety of extensions and swivels at all angles to get them unbolted didn't know if any one already did that
Vegas97gt is offline   Reply With Quote
Old 03-30-2012, 05:15 AM   #14
imhooked's Avatar
removing the starter was something i thought might help too... so you got some more clearance and it made access to the nuts easier?
Old 03-30-2012, 06:34 AM   #15
wolfstang03's Avatar
when i did mine the manifold stud snapped! long story short.. cut it off with a sawz-all, bought headers and had a shop install the headers with the mid pipe!
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 03-30-2012, 06:51 AM   #16
imhooked's Avatar
so all ended up good!
seriously i'm going to pull car up on ramps later today and just take another look and maybe attempt to see if i can actually got at those buggers.
otherwise will call dealer(they actually install aftermarket parts bought elsewhere!) and a couple local shops for an install quote.
btw, any of you guys used or know someone that likes dynomax or mac cat backs(i know the prochamber mid pipe is the cat's meow!). was wondering about their rep. as most everybody uses flows or magna/borla/slp etc
Old 03-30-2012, 07:07 AM   #17
2002VertGT's Avatar
I have Mac catbacks I love them....quite at idle but at WOT they scream..nice deep rumble
4.10 Gear/RPM thread
Old 03-30-2012, 08:50 AM   #18
CodyNelson's Avatar
Region: West Virgina
I have longtubes installed so changing midpipes is super easy for me!!
Old 03-30-2012, 10:07 AM   #19
BigB227's Avatar
Man I'm telling you if I could afford long tubes I would get them
Old 03-30-2012, 10:44 AM   #20
CodyNelson's Avatar
Here is a tip....Craigslist! I bought a set of htc coated (similar to ceramic) Hedman Tork-step LT headers for $200. They were still in the box and had never been installed because the guy didnt realize the work involved when he purchased them. They sat in his garage for a year and he just wanted rid of them. They are right at $800 brand new. I put my whole exhaust together off craigslist (LT's, O/R Prochamber, flow 40 catback, and 3.5" polished tips) for $500. All the parts were like new and in great shape. The key is to ask lots of questions and get lots of pics.
Old 03-30-2012, 10:48 AM   #21
BigB227's Avatar
Thanks man yeah when I save up the money I'm going to get some
Old 03-30-2012, 11:33 AM   #22
imhooked's Avatar
hey cody,
what co. did you buy the prochamber from? i'll check them out-
thx-
joe
Old 03-30-2012, 11:43 AM   #23
CodyNelson's Avatar
Originally Posted by imhooked View Post
hey cody,
thx-
joe
Its a Mac Prochamber, but i bought it "used" off of Craigslist.
Old 03-30-2012, 12:21 PM   #24
imhooked's Avatar
yeah, none out there on cl near me. think i'm just gonna break down and order new/direct as that's what i really want! (or as my little nephew used to say... "I NEED that!!!")
just placed the order on my cat back!
psyche!
Old 03-30-2012, 12:24 PM   #25
2002VertGT's Avatar
psyche!
You need to post some pics in your album...
Old 03-30-2012, 12:30 PM   #26
02NightmareGT's Avatar
+1
I wanna see ur Stang. Unless that f-18 is ur mustang. Transformer?
02NightmareGT is offline   Reply With Quote
Old 03-30-2012, 01:07 PM   #27
imhooked's Avatar
u guys killin me
will post some up as soon as i get new dig cam... old one broke, and phone and 'puter don't like each other for some reason
p.s. blue angel not mine! just love to go to the shows any chance i get when they're less than 3 or 4 hour drive from home. took my Mom and Dad to show in Rhode Island last summer. NOW THAT"S POWER!!!
later-
Old 03-30-2012, 04:49 PM   #28
stay away from upr products .com I got these one for $140 but went I got it all the weldings were mest up leak holes call them they refund me $50 I got the holes weded but went I installed it the passenger side hits the frame side had to bang it in a curve to make it fit correctly,
Old 03-30-2012, 04:51 PM   #29
plus its not even an x-pipe because it those not joint in the middle like a bbk or pypes, worse part ever
Old 03-30-2012, 06:58 PM   #30
Gobabygo67's Avatar
I sprayed my bolts well with wd40 broke off easily but was a pain to get to
Gobabygo67 is offline   Reply With Quote
Old 03-30-2012, 07:02 PM   #31
BigB227's Avatar
Yeah I tried that also but the bolt started rounding off
Old 03-30-2012, 07:07 PM   #32
MiGT01's Avatar
BBk o/r X pipe, 60$ to have it installed! LoL
01 Black Beauty GT
Eibach pro kit,Tokico shocks/struts,BBK CAI,75mm TB/ Plenum,4.10 FRPP gears,BBK o/r X pipe,Magnaflow Catback,SCT Tuner running 91 Tune,Bama Tunes for Life Member,RAM HD Clutch,BM shifter with MGW "GT" knob,AM smoked Headlights/Sylvania zXe bulbs,VHT smoked tails/3rd brake,Redtop Optima,Mach 1 grille delete,Mach 1 chin spoiler,BULLITT Pedals,20% tint all round,4.6 High Performance Badges
MiGT01 is offline   Reply With Quote
Old 03-30-2012, 07:08 PM   #33
BigB227's Avatar
Seriously? Where's that at??
Old 03-30-2012, 07:09 PM   #34
Gobabygo67's Avatar
That's crazy! All I used was that a swivel extension and socket and a big rachet only took about a solid hour
Old 03-30-2012, 07:25 PM   #35
BigB227's Avatar
Man I wish lol I used swivels,extensions and loads of ratchets nothing and the bolt rounded when I got them on
x-pipe GrabberBlue5.0 2011-2014 Mustang GT 25 03-30-2012 08:19 AM
X-pipe question? WhiteCobra94 1979-1995 Mustang GT 2 03-28-2012 03:25 PM
spring install superboondee 1996-2004 Mustang GT 9 03-27-2012 11:09 PM
Rpm gauge install!! Help.. 89 Foxloco 1979-1995 Mustang GT 6 03-26-2012 07:20 PM
X or h pipe? Whitestang93 Pre-2005 V6 Mustang 19 03-26-2012 10:45 AM
02:25 AM
