1996 diferntial. - Mustang Evolution
Old 04-02-2012, 01:24 PM   #1
96gt BOY's Avatar
1996 diferntial.
hey guys,
ive been haveing a problem with my rear end, after i driven the car for 50 miles, i start to hear a grinding noise in the back and it starts to crack, they recomended me to change the oild but its still do the same. its a 96 gt. thanks.
96gt BOY is offline   Reply With Quote
Old 04-02-2012, 01:30 PM   #2
Re: 1996 diferntial.
sounds like you need to take the rear cover off and inspect the differential, see what might be up.
it could also be something else but might need to let a mechanic take it for a spin and listen at it. Does it make the noise if you just turn the rear wheels (jacked up in the air of course) in the middle or on the sides, might can track it down.
Old 04-02-2012, 03:46 PM   #3
96gt BOY's Avatar
It makes a noise in the middle rear and the side rears, one if the things i noticed when the oil got changed, was that theirs some kind of scraping going on inside the the differential. Also, one of the teeth's is a little worn out. It spins freely by hand but in the road after it warms up, heat expands and thats when you start to hear it, i also noticed that its a little bit loose inside the cover.
Old 04-02-2012, 04:56 PM   #4
2002VertGT's Avatar
You need new gears or new spindles or both
4.10 Gear/RPM thread
Old 04-02-2012, 05:18 PM   #5
96gt BOY's Avatar
Hmmm thanks man, ill try that
Dmurstang :: 1996 Ford Mustang GT murraydylan1993 Member Garages 0 03-31-2012 08:43 PM
1996 v6 boost question dhktactical Pre-2005 V6 Mustang 14 03-09-2012 11:04 PM
For Sale: 1996 4.6L Gt murraydylan1993 Mustangs for Sale and Wanted 0 03-09-2012 01:52 PM
Lincoln Mark 8 DOHC Motor swap to 1996 mustang gt AN03COBRA 1996-2004 Mustang GT 1 02-26-2012 01:21 AM
1996-1998 donor Dgibson 1996-2004 Mustang GT 0 01-28-2012 04:38 PM
11:06 AM
