What should i get? - Mustang Evolution
Old 04-03-2012, 07:42 AM   #1
RUNNWLD's Avatar
Region: Utah
I'm 16 years old and I have an 04 mustang gt. what are some good exterior parts??
RUNNWLD is offline   Reply With Quote
Old 04-03-2012, 08:28 AM   #2
Doe_Rae_mi's Avatar
Rims lol
Old 04-03-2012, 08:30 AM   #3
RUNNWLD's Avatar
Region: Utah
Wish I had that money lol!! But what is some cheaper exterior parts?
Old 04-03-2012, 09:33 AM   #4
Mathew r Wright's Avatar
If not lowers then lower it, Mach chin spoiler, cal hood, black out valance cover... Man just go to a&m you'll find everything exterior there lol...
Mathew r Wright is offline   Reply With Quote
Old 04-03-2012, 09:36 AM   #5
Horseplay's Avatar
+100 right on
Low2v
Old 04-03-2012, 09:44 AM   #6
RUNNWLD's Avatar
Region: Utah
Im always on american muscle and that was everything I was thinking. If I go with h&r sports do I need the camber plates and shocks to or just the lowering springs?
Old 04-03-2012, 09:55 AM   #7
Re: What should i get?
lowering the car and rims are the best way to change the look then front bumper~ hood~ rear and sides
Old 04-03-2012, 10:02 AM   #8
No as far as I know ya don't need all that, but if shock are old then replace them all at once. You know like take old ones off so they'll be out of the way, then put ur springs in then new shock lol get me? Caster plates are not necessary till later, yes when you get them threw tire shop will really thank you for having them makes their job easier. But! I do recommend getting a bushing kit with your springs, they should offer a "you might also like" to the side for t he bushing kit lol if not put it in search coary... Helpful?
Old 04-03-2012, 10:10 AM   #9
RUNNWLD's Avatar
Region: Utah
Thank you I will be ordering the springs and the bushing kit thank you!!
Old 04-03-2012, 05:55 PM   #10
Mile high JDF's Avatar
Do you care about tire wear? If you lower it then C/C plates are very handy so that you don't burn through tires. I vote Mach 1 grill delete and chin spoiler.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-03-2012, 08:20 PM   #11
RUNNWLD's Avatar
Region: Utah
So go with h&r sports with camber plates?
Old 04-03-2012, 08:34 PM   #12
It's up to you. I'd vote the C/C plates over bushings so that you don't have a bad alignment.
Old 04-03-2012, 08:58 PM   #13
RUNNWLD's Avatar
Region: Utah
Alrighty thanks man!!
Old 04-03-2012, 10:22 PM   #14
Vegas97gt's Avatar
Region: Nevada
I say yes on the chin spoilers and grille delete and I say paint your wheels if they aren't chrome smoke or tint your headlights and taillights shorty antenna cheap but stylish lil
Vegas97gt is offline   Reply With Quote
Old 04-03-2012, 10:58 PM   #15
No problem
Old 04-04-2012, 02:06 AM   #16
Region: North Dakota
At this point.. I think it would be easier to post pics of what people have done to their exteriors that SHOULDN'T have been done rather than giving ideas of what you 'could' do LOL. I see too many stangs out there that I'm embarrassed to call a mustang because their owner wanted to get all 'lo-rider' or 'gangsta' or (god forbid) 'rice'...
K Twisted is offline   Reply With Quote
Old 04-04-2012, 12:38 PM   #17
CodyNelson's Avatar
Region: West Virgina
With the H&R Sports you dont NEED anything else, but you will never get your car into proper allignment and you will eat your tire right off the car. To get it alligned properly it is recommended that you get springs, shocks, struts, CC Plates, and bump steer kit.
Old 04-05-2012, 12:16 AM   #18
Jdf ur point is right on, but chances are you got miles on ur car so tire ware is already an issue. Most need is really the bushings because they are supporting the springs, they see most wear which all has influence on suspension. Caster are not mandatory, because the car can be aligned without them, but yes casters does still help suspension, and makes it easier for alignment...
Old 04-05-2012, 12:31 AM   #19
Ford designed the mustang to have a non-adjustable camber and caster, hence the reason there's an aftermarket for C/C plates. It's not possible to set it correctly. It may be possible to get close to a correct alignment with caster bolts but it won't be dead on. I agree that bushings are necessary but tires get expensive when you have to keep replacing them because you have inner tire wear
Old 04-05-2012, 01:00 AM   #20
Lmao yah but still dead on or not, close or not, you can align any car bro. And if ya get it that close it is not gonna wear near as bad as ur making it sound. Besides why would ford make it to where you cant align ur car that just doesn't make sense? Ford knows what they are doing they've been doing it for a long time, so why would they make a car like that... Let's put it this way he will get his springs and whatever else and 6 months down the road he'll be just fine, with or without the c/c's... Then he can buy them, put em on, then have it aligned lol sorry to argue...
---------- Post added at 02:00 AM ---------- Previous post was at 01:57 AM ----------
Well never mind you didn't say you can't align the car sorry...
Old 04-05-2012, 01:14 AM   #21
I prefer the term debate, and yes you can do it down the road but it's just easier to do it right the first time. Most car manufacturers nowadays design their cars to have non-adjustable caster and camber because when either of those is out, that means you have a part that broke somewhere in your suspension. it's been a long time since I've been under a car on an alignment rack
---------- Post added at 07:14 AM ---------- Previous post was at 07:11 AM ----------
Stupid iPod. It's been a while since I've done an alignment but usually on cars like mustangs the tech will just set the toe and let it go because the C and C should check out just fine unless you managed to break something.
Old 04-05-2012, 01:33 AM   #22
Lol but he's sixteen right, I remember when I was sixteen, lol made more money those years than I do now, but was still on a tight budget, because I spent a lot of it and had nothing to show for it. Shoot still am on a tight budget because got a family now... Lol but ain't giving up the stang. If hes on a tight budget hell have to wait. Now go to bed lol masterbater lol just kidding...
Old 04-05-2012, 05:54 AM   #23
jjsg09's Avatar
I thought you only need cc plates and bump steer when you lower the car past 1.5".......right?
Old 04-05-2012, 06:25 AM   #24
WheelStander's Avatar
Nice thread.
I think my GT only has H&R springs and tokico struts, shocks I don't think it has anything else that has been discussed.
I have probably 10000 miles on tires.
I'll do a tread check and report back.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 04-05-2012, 07:11 AM   #25
I'll sleep when I'm dead not really actually, I'm quite fond of sleep. But you do brig up a good point, of he has the money then I would vote do everything he could find related to the suspension just to be safe. If not then it just comes down to what he can and can't afford, I honestly don't know how much that bushing kit costs but I'd assume it's around the same price as C/C plates correct?
Old 04-05-2012, 01:16 PM   #26
Originally Posted by WheelStander
Nice thread.
My tread wear is consistent across width on front.
Old 04-05-2012, 05:18 PM   #27
Do you have a tread depth gauge? Tread wear wont show up on fairly new tires for a while
Old 04-05-2012, 07:37 PM   #28
I just checked my milage and I only have 5k on the fronts.
So hard to tell then.
Old 04-05-2012, 10:55 PM   #29
Ok. Just make sure to keep an eye on it.
Old 04-06-2012, 06:46 AM   #30
Op, how about a shorty antenna?
I have a 14 and reception has not suffered.
The 14 lines up nicely with roofline.
Find em at AM.
Old 04-06-2012, 08:14 AM   #31
jjsg09's Avatar
It sounds silly to some people but the shorty antenna does make a difference to the look of the car.
Old 04-06-2012, 08:18 AM   #32
Yeah looks great on your car too.
It eliminates that sail mast look.
Old 04-06-2012, 10:32 AM   #33
Find em at AM.
Hey here's a question how do ya get a whole new antenna, because my stereo was so jacked and rigged... And to top it off some idiot jacked. Up whole antenna wire, everything, the to make it sound even better the whole base and everything was replaced with some cheap Walmart one that looked like it had been broke for a while. I just pulled it all out, and there's a hole in the finder now. I look all over online, even tried eBaying it, but can't seem to be able to find what I'm looking for???
Old 04-06-2012, 04:31 PM   #34
Dealership or auto salvage item I think.
Old 04-06-2012, 08:03 PM   #35
Yah I actually just took the time and looked through 20 pages on eBay, and found what I was looking for. Lol I found a salvage company on eBay, that I shoulda just contacted first, they hooked me up...
What Grinds Your Gears? deadsp0t The Bar 21642 03-07-2018 10:18 AM
What did you do today? Qwik Four Six The Bar 20466 01-14-2017 03:24 PM
What are you currently listening to? Brent The Bar 11215 09-07-2016 06:12 PM
What are you eating...? deadsp0t The Bar 2139 06-26-2014 12:01 PM
What it takes for forced induction and much more... dreamstang 1979-1995 Mustang GT 2687 10-31-2012 11:50 AM
03:32 AM
