octane boost - Mustang Evolution
Old 04-03-2012, 01:01 PM   #1
imhooked's Avatar
octane boost
any of you guys with tuners ever tried lucas or torco with 87 octane fuel and had it run ok on a 91 or 93 octane tune???
imhooked is offline   Reply With Quote
Old 04-03-2012, 01:57 PM   #2
Re: octane boost
ive heard from many who run Torco (not sure on the concentration) and they seem to like it.
Old 04-04-2012, 02:09 AM   #3
Region: North Dakota
Re: octane boost
I trust Lucas before most other products besides Amsoil. My question is, why do you need octane boost? Are you not able to get 91 or 93 where you live? Or are you trying to save a little bit but still have the power?? Just curious. I never put much stock in octane boost, but I still have a lot of R+D to do with it...
K Twisted is offline   Reply With Quote
Old 04-04-2012, 05:56 AM   #4
imhooked's Avatar
Re: octane boost
no, i can get 91 or 93... was just curious and anxious to try the 91 tune, but have 87 in the tank. just thought i'd give it a try
btw, have you got a tuner? ( i don't remember) i know you have engineering background, and spark and a/f mixture are 2 things user can adjust. reason i ask is even on the 87 tune (which really impressed me) car goes like banshee, first through 3rd. in 4th and 5th still good, but it could use a little more power.
now that i thinking about it, as my car manual and not auto, probably wouldn't help. maybe better to get my exhaust in, and do the gears
Old 04-04-2012, 06:12 AM   #5
Re: octane boost
One thing you can do with your tuner is depending on your elevation, you can advance your ignition timing 1.5 degrees per 1000 feet above sea level. When you're in 4th, you're at a 1:1 ratio in your transmission (someone correct me on that if I'm wrong) so you're going on pure engine, and 5th is considered an overdrive gear. At this point when you're at high RPMs over 3500, you'll notice that aftermarket coils will start helping out. May be another option to consider. A full exhaust would CERTAINLY help as well, especially long tube headers.. and if you get them and can swing the cost, go with ceramic coated ones. Gears will also help it scream off the line, but will lower your top speed, however, since it takes a bit anyways for our cars to get up around 135 and over, a set of 3.73's will get you to 140 - 145 by the time your starting to max your RPM's in fifth. Hope all this helps!
Old 04-04-2012, 06:25 AM   #6
imhooked's Avatar
Re: octane boost
thanks as always... will do a little more reading, or bounce off the tuner, before i mess with it. long tubes are out, HOWEVER my new cat back shipped yesterday, and i think i am going to get the mac pro chamber, or just a straight h pipe
if you saw post in other thread, yes cop's and new plugs to be done very soon as well!
3.73 gears later this summer (i hate to have someone else work on my car!), but i really don't think i can handle it. 145 mph not an issue my friend. i got a phuk!ng ticket the other day on my way(not on the way back!) to pick up my tuner; 72 in 55, and saw troopers 10 times after that on the trip. including the same one issuing another ticket on the n.b. side, while i was traveling home! ARRRRRRRRRRRRRRRR!
Old 04-04-2012, 06:30 AM   #7
Re: octane boost
Sounds like one of those days where it was just bad timing to be having fun.. I'm sorry to hear that man!! I would go straight H, but that's just me and I don't have the lame emissions laws here
Old 04-04-2012, 06:40 AM   #8
imhooked's Avatar
Re: octane boost
thanks for the sympathy. mine own fault actually, as i got between 2 cars, and was hanging in the left lane by myself. came over crest, started down hill, he spotted me, and shot. i immediately moved to right lane, hit blinker and started to slow as i knew he was gonna come.
messed up thing is i wasn't even in a hurry, and it's damn hard to stay at 55 on the parkway when there's is next to no one on the road.
Old 04-04-2012, 10:38 AM   #9
Re: octane boost
just wait until you run out and fill back up with premium
Old 04-04-2012, 12:24 PM   #10
Dylanbest's Avatar
What would happen if you ran low grade fuel on a 93 octane or custom "race" tune
Dylanbest is offline   Reply With Quote
Old 04-04-2012, 01:09 PM   #11
imhooked's Avatar
Re: octane boost
that no-no... make engine not happy!
Old 04-04-2012, 01:45 PM   #12
Re: octane boost
I basically did this.... I purchased 93 gas and believe I received bad gas or lower octane than I purchased.
this caused detonation (was using to much timing for to low octane). My car has no knock sensor so it wont stop detonation.
It sounds like marbles bouncing around. I had to simply stay out of boost and not put any load on the car (drive it easy) until the gas was gone.
Old 04-06-2012, 09:26 AM   #13
Dylanbest's Avatar
That sounds horrible definitely wouldn't wanna put my car through that, thanks for the feedback
kenne bell boost a pump syrupsaleen Saleen & SMS Mustang 128 04-12-2012 11:26 AM
1996 v6 boost question dhktactical Pre-2005 V6 Mustang 14 03-09-2012 11:04 PM
Stock boost? 93_347foxbody 1979-1995 Mustang GT 3 02-19-2012 10:56 PM
boost Black99Snake SVT Mustang 11 02-12-2012 10:16 AM
93 octane gas in phoenix? angelofrat42 2005-2010 V6 Mustang 0 02-07-2012 06:02 PM
07:49 AM
