trans problem or tob - Mustang Evolution
Old 04-03-2012, 09:02 PM   #1
Sonicblue03gt's Avatar
Whats up hopefully you guys can help me out,2003 gt 91k miles 373s,Still has the stock clutch,Since i installed my bullits with the 315/35/17 tire,i get this small vibration when the cars parked its coming from my transmission,i know mu clutch is on its way out,i have to let the pedal almost all the way out for it to engage...plus my t.o.b chatters,but the car shifts perfectly and no grinds or pop outs,jus a small vibration.at around 1000rpm till like 1500rpm only when clutch is engaged,let me know what you guys think it is
Sonicblue03gt is offline   Reply With Quote
Old 04-03-2012, 09:04 PM   #2
Region: Nevada
Have u tried changing out the cable?
importkiller is offline   Reply With Quote
Old 04-03-2012, 09:10 PM   #3
Nope im planning on doing all that in about a month,adjustable cable n quad,clutch,pilot bearing,and throwout bearing,i just wanna know if its my clutch going out,or something in the transmission thats bad so i can get it looked at asap
Old 04-04-2012, 05:45 AM   #4
Region: North Dakota
Re: trans problem or tob
More than likely it's not an internal issue with your transmission. The way the internals of a transmission are designed with the rotating assemblies, a vibration would be due to an unbalanced part. Since most of the parts inside the tranny don't move much (except rotational movement) and are balanced upon creation, it's more than likely something else. Since you said that your car is a manual (clutch being all the way out and all that) and you said it has a vibration "when parked" it may be due to an engine problem. If it's vibrating after you let the clutch out and start rolling, I would say your clutch is going out, or at least the frition plate is, and you're getting whats called clutch chatter. This is when the clutch's friction materials skip across the surface of the flywheel because either they are non existant, or heat damaged, or the flywheel has heat spots on it's surface. If the car is rolling, during that RPM range it could indicate another set of problems altogether such as a bad u-joint, a very slightly bent driveshaft, or an inbalanced tire. Typically it's a tire or u-joint. I hope all this helps.
K Twisted is offline   Reply With Quote
2012 or 2013 Mord Fustang Boss Mustang 6 04-13-2012 09:16 AM
347 stroker or trick flow kit and a v3 supercharger Sambrostang General Mustang Discussion 15 04-10-2012 07:02 AM
get rid of body kit or?? Sonicblue03gt 1996-2004 Mustang GT 29 04-07-2012 08:51 AM
Boss Intake or Fuel Problem? SilverBullet12 2011-2014 Mustang GT 14 04-05-2012 11:15 AM
slp problem br10301 1996-2004 Mustang GT 4 04-02-2012 10:45 PM
06:41 AM
